node-red-contrib-nordpool-chargecheap 1.0.2-rc.1
Nordpool price analyzer with smart night/day, rolling 24h and HA override integration for Node-RED
npm install node-red-contrib-nordpool-chargecheap
A Node-RED node for analyzing Nordpool electricity prices and automatically selecting the cheapest (or most expensive) time periods for charging, discharging, load shifting or other automation purposes.
โœ… Key Features
  • Selects the cheapest or most expensive price intervals within a configurable time window.
  • Two selection strategies:
    • Discrete selection: pick the N best (cheap) or worst (expensive) intervals.
    • Contiguous block mode: find one continuous block of length N with lowest (cheap) or highest (expensive) average price.
  • Supports overnight windows (start > stop) and rolling 24h mode (start == stop).
  • Rolling 24h mode provides a dynamic 24h window anchored to the most recent occurrence of the chosen start hour.
  • Home Assistant integration via service-style payload (e.g. input_number.set_value).
  • Dynamic runtime override via incoming msg.start, msg.stop, msg.count.
  • Automatic unit normalization (ร–re / SEK / EUR โ†’ ร–re).
  • HA override (msg.ha_enable="off") keeps calculating selection but sends a fixed fallback (force_value) to HA.
  • Full context reset using msg.reset.
  • Detects interval length (15 / 30 / 60 minutes or other).
  • Rich diagnostic attributes (block averages, reference thresholds, data completeness).
  • Inverted mode for high-price alerting or battery discharge strategy.
  • Additional semantic attributes clarifying override mode, selection purpose and next effective reference.
  • Slot alignment logic: If you select e.g. start=23, stop=0 with 15-minute slots, you will get the slots starting at 23:00, 23:15, 23:30, and 23:45 (not slots starting at 00:00 or later). This ensures interval selection is intuitive and matches human expectations.
๐Ÿง  Selection Logic Summary
Mode What is selected reference_price meaning reference_price_role
Cheap (default) Lowest priced intervals Highest price among selected cheap intervals (upper cheap boundary) upper_bound_for_charging
Expensive (invert) Highest priced intervals Lowest price among selected expensive intervals (lower expensive boundary) lower_bound_for_discharging
Why this reference logic?
  • In cheap mode, the selected cheap set forms a โ€œprice corridorโ€ โ‰ค reference_price. The reference becomes a ceiling you still accept for charging.
  • In expensive mode, the selected expensive set forms a corridor โ‰ฅ reference_price. The reference becomes a floor beyond which discharging / shedding may occur.
You also get reference_price_numeric (pure number) and reference_price_effective (null during HA override).
In contiguous block mode the node finds the single block (length = count) with:
  • Lowest average (cheap mode)
  • Highest average (expensive mode)
๐Ÿ”„ Rolling 24h vs Normal Periods
  • Normal period (start != stop):
    • If start < stop: same-day window (e.g. 07โ†’15).
    • If start > stop: overnight window crossing midnight (e.g. 22โ†’06).
  • Rolling 24h (start == stop):
    • A 24h dynamic span beginning at the most recent occurrence of that hour.
    • If current time is earlier than the start hour, the window anchors to yesterdayโ€™s occurrence.
    • Example: At 21:30 with start=16 (rolling) โ†’ window = today 16:00 โ†’ tomorrow 15:59:59.
    • Attribute: rolling_24h = on.
โš™๏ธ Node Configuration (Editor Fields)
Field Description
Name Display name for the node
Start hour Start of selection window (0โ€“23)
Stop hour End of selection window (0โ€“23); if same as start โ†’ rolling 24h
Count Number of intervals to select (N price slots)
Invert selection Choose expensive instead of cheap intervals
Contiguous block mode Select one continuous block instead of distinct intervals
Payload ON Output 1 payload when current time is inside a selected slot
Payload OFF Output 2 payload when outside/idle
Force value outside period Value pushed to HA when not active or under override
Home Assistant entity HA entity ID (e.g. input_number.elpris)
Debug Enables verbose node.debug logs
๐Ÿ”Œ Outputs (4)
Output Purpose Example Payload
1 Active slot indicator (ON) "on" (configurable)
2 Inactive indicator (OFF) "off" (configurable)
3 State + attributes object { "state": 153.22, "attributes": { ... } }
4 Home Assistant service message (optional) { "action": "input_number.set_value", "data": { "entity_id": "input_number.elpris", "value": 153.22 } }
If HA override (msg.ha_enable="off") is active, output 4 sends the configured force_value instead of reference_price.
๐Ÿ’ฌ Runtime Inputs
Property Type Description
msg.data object Nordpool data wrapper (see format below)
msg.start number/string Override start hour (0โ€“23)
msg.stop number/string Override stop hour (0โ€“23)
msg.count number/string Override count (number of intervals)
msg.ha_enable string "on" (normal) or "off" (HA override)
msg.reset any Full reset of internal context
Example injection:
  "start": 22,
  "stop": 6,
  "count": 8,
  "ha_enable": "on",
  "data": {
    "attributes": {
      "raw_today": [
        { "start": "2025-10-28T00:00:00+01:00", "value": 94.35 },
        { "start": "2025-10-28T00:15:00+01:00", "value": 92.12 }
      "raw_tomorrow": [
        { "start": "2025-10-29T00:00:00+01:00", "value": 101.44 }
      "unit_of_measurement": "SEK/kWh"
Reset:
{ "reset": true }
Disable HA dynamic updates:
{ "ha_enable": "off" }
Re-enable:
{ "ha_enable": "on" }
๐Ÿ“ฆ Expected Nordpool Data Structure
Minimal attributes:
  • raw_today: Array of objects with start and value (or price).
  • Optional raw_tomorrow: Same shape.
  • unit_of_measurement: e.g. ร–re/kWh, SEK/kWh, EUR/kWh.
  • Optional price_in_cents: true (already ร–re).
  • Deduplication performed on timestamp.
๐Ÿงฎ Interval Detection
The node infers interval_minutes from the smallest positive gap between consecutive timestamps.
Attributes: interval_minutes, expected_points, actual_points, missing_points, and partial_period (true if incomplete data).
If interval โ‰ฅ 55 minutes, count is capped at 23.
๐Ÿ” Reference Price Semantics (Detailed)
Attributes:
  • reference_price: Formatted ร–re string (e.g. 153.22ร–re).
  • reference_price_numeric: Pure number (e.g. 153.22).
  • reference_price_mode: cheap_selection_max or expensive_selection_min.
  • reference_price_role: upper_bound_for_charging or lower_bound_for_discharging.
  • reference_price_effective: Equals reference_price unless HA override is active (then null).
  • next_reference_when_enabled: Shows future effective reference during override (HA disabled).
Use cases:
  • Charging logic: Activate when current spot price โ‰ค reference_price_numeric (cheap mode).
  • Discharging logic: Activate when current spot price โ‰ฅ reference_price_numeric (expensive mode).
๐Ÿ“Š Attribute Overview (Output 3 payload.attributes)
Attribute Meaning
time_01, time_02, ... Selected intervals (localized time + price)
count Number of selected intervals
selection_mode cheap or expensive
selection_strategy discrete_slots or contiguous_block
reference_price Threshold string
reference_price_numeric Numeric threshold
reference_price_mode Semantics of selection boundary
reference_price_role Domain-oriented purpose
reference_price_effective Null when override active
next_reference_when_enabled Future reference if override off later
max_time, min_time Extremes within selected set
search_period Localized start โ†’ end label
data_source Merged sets used (e.g. today + tomorrow)
interval_minutes Detected slot length
contiguous_mode on / off
rolling_24h on if rolling 24h logic used
block_mode_start / block_mode_stop Bounds of contiguous block
block_mode_average Average price of block
total_hours_span Duration of evaluated window
expected_points / actual_points Diagnostics
missing_points Count of missing slots
partial_period True if incomplete data
single_selection True if only one slot selected
ha_override on if HA override active
control_mode override or normal
ha_sent_value Value pushed to HA entity this cycle
calculated_at ISO timestamp of calculation
slot_alignment First/last selected slot time
๐Ÿ  Home Assistant Integration
If ha_entity is set (e.g. input_number.elpris), output 4 sends service-style payloads:
Active slot:
  "data": { "entity_id": "input_number.elpris", "value": 153.42 }
Outside slot OR override:
  "data": { "entity_id": "input_number.elpris", "value": -600 }
Disable dynamic updates (override battery logic but still preview future reference):
Re-enable:
During override:
  • ha_override = on
  • reference_price_effective = null
  • next_reference_when_enabled shows what would be used if re-enabled now.
๐Ÿ” Reset Behavior
Sending any truthy msg.reset:
  • Clears stored data (today_data, yesterday_data, tomorrow_data)
  • Clears selection parameters (start_time, stop_time, count_hour)
  • Clears ha_enabled
  • Emits status โ€œFull context resetโ€
Example:
{ "reset": true }
๐Ÿ”Œ Example Battery Use Case
Cheap mode:
  • Select e.g. 12 cheapest 15-min slots (3h total) in evening for charging.
  • Use Output 1 to turn charger relay ON only when active slot.
  • Use reference_price_numeric in HA automation to decide dynamic pre-charging threshold.
Expensive mode:
  • Invert selection to mark high-price windows.
  • Use Output 1 to trigger battery discharge or load shedding when inside expensive window.
Override:
  • Temporarily force HA entity to a known fallback (e.g. -600) while still previewing future thresholds.
๐Ÿงช Example Flow Outline
  1. Nordpool upstream node fetches raw_today/raw_tomorrow.
  2. Function/Change nodes send dynamic overrides (msg.count, msg.start, msg.stop).
  3. This node calculates selection and outputs:
    • Output 1 โ†’ charger control
    • Output 2 โ†’ fallback/off
    • Output 3 โ†’ attributes for dashboards / DB
    • Output 4 โ†’ HA reference value injection
  4. Optional UI to toggle ha_enable.
๐Ÿš€ Installation
From Node-RED editor:
  1. Menu โ†’ Manage palette โ†’ Install
  2. Search: node-red-contrib-nordpool-chargecheap
Or via npm in Node-RED user directory:
Restart Node-RED if needed.
โš ๏ธ Notes & Edge Cases
  • Missing tomorrow data โ†’ partial_period: true.
  • Rolling 24h mode may show partial data until future hours arrive.
  • count auto-clamped if more than available intervals.
  • Large gaps or malformed timestamps are ignored after dedupe.
  • Interval detection outside 15/30/60 still supported (custom sources).
  • Slot alignment: If your selection window does not align with slot boundaries, the node will include all slots starting at or after the start time and strictly before the stop time. For example, with 15-minute slots and start=23, stop=0, the slots chosen will be 23:00, 23:15, 23:30, and 23:45.
๐Ÿž Troubleshooting
Symptom Possible Cause Fix
Waiting for Nordpool data raw_today empty Check upstream feed
partial_period true Incomplete tomorrow data Wait for publication
Unexpected reference_price_effective = null HA override active Send {"ha_enable":"on"}
Charger not turning on Not in active selected slot Inspect time_XX + system clock
Price mismatch Unit conversion discrepancy Verify unit_of_measurement
Selection seems to shift during day New tomorrow data appended Consider lock logic (future enhancement)
Unexpected slot times Selection window does not align with slot boundaries Adjust your start/stop times to match slot intervals (e.g., use start=23:00 if slots start at 23:00)
๐Ÿ“ License & Contributions
Open to:
  • Performance improvements
  • New selection heuristics
  • HA-specific enhancements
(Insert license statement here, e.g. MIT.)
๐Ÿ–ผ Screenshots
Screenshot 2025-10-29 at 21 10 16 Screenshot 2025-10-29 at 21 12 33 Screenshot 2025-10-29 at 21 12 49
๐Ÿ”„ Quick Reference Cheat Sheet
Task Payload
Override window { "start": 7, "stop": 23 }
Change count { "count": 12 }
Enable HA { "ha_enable": "on" }
Disable HA { "ha_enable": "off" }
Full reset { "reset": true }
Switch to expensive mode Toggle invert selection in node config
Rolling 24h mode Set start == stop (e.g. both 16)
๐Ÿ“˜ Suggested HA Automations (Example)
Cheap mode charge trigger:
alias: Charge when cheap slot active
trigger:
  - platform: state
    entity_id: sensor.nordpool_chargecheap_active   # If you map output 1 โ†’ on/off helper
condition:
  - condition: template
    value_template: "{{ state_attr('sensor.nordpool_chargecheap','selection_mode') == 'cheap' }}"
action:
  - service: switch.turn_on
    target: { entity_id: switch.charger }
Expensive mode discharge trigger:
alias: Discharge when expensive slot active
trigger:
  - platform: state
condition:
    value_template: "{{ state_attr('sensor.nordpool_chargecheap','selection_mode') == 'expensive' }}"
action:
    target: { entity_id: switch.discharge_relay }
Override awareness:
alias: Notify HA override
trigger:
  - platform: state
condition:
    value_template: "{{ state_attr('sensor.nordpool_chargecheap','ha_override') == 'on' }}"
action:
  - service: persistent_notification.create
    data:
      title: "Nordpool Override Active"
      message: >
        Dynamic pricing paused. Future reference would be:
        {{ state_attr('sensor.nordpool_chargecheap','next_reference_when_enabled') }} ร–re.
โ„น๏ธ Versioning Notes
If you upgrade from an earlier version:
  • New attributes (reference_price_role, reference_price_numeric, override diagnostics) are additive.
  • No breaking changes in output ordering or fundamental logic.
Enjoy smarter price-based automation! Contributions and suggestions are welcome.
Version: 1.0.2-rc.1
Updated 1 year, 1 month ago
747 in the last week
  • nordpool-chargecheap
  • nordpool
  • electricity
  • energy
  • price
  • automation
  • smart-charging
  • load-shifting
  • battery
  • home-assistant
