node-red-contrib-nomos 1.0.72
nomos Node-RED Connector
npm install node-red-contrib-nomos
A Node-RED node to connect with nomos Controller.
With this Nodes you can connect nomos Controller and Node-RED. Minimum requirement is you have nomos Controller 2.0 up and running.
Run command on Node-RED installation directory.
or use the palette manager.
- Add a nomos node
- Add a new nomos-hub if not done already
nomos Components
With this nodes you can connect directly to nomos Controller components/devices. The nodes are bound to certain properties. For example components with Level/Brightness property. Component and Generic nodes are more flexible in the way you can control or query component properties.
nomos Extras
Direct access to Events, Timers, Scenes and Notifications you have configured on your nomos Controller. Triggers are working as well. For example: You can use a Scenes node as trigger and attach for additional execution other Node-RED nodes to it.
nomos API
The complete nomos API available as Node-RED nodes. See the documentation of each node for further informations.
Changelog
v1.0.0
- Initial release
MIT (c) nomos system AG
nomos-hub
nomos-reachable
nomos-battery
nomos-state
nomos-level
nomos-hue
nomos-motion
nomos-contact
nomos-openwindow
nomos-humidity
nomos-temperature
nomos-setpoint
nomos-isheating
nomos-iscooling
nomos-volume
nomos-position
nomos-angle
nomos-raw
nomos-component
nomos-event
nomos-timer
nomos-scene
nomos-notificationprofile
nomosapi-onaddonprofileadded
nomosapi-addaddonprofile
nomosapi-getaddonprofiles
nomosapi-onaddonprofileremoved
nomosapi-removeaddonprofilebyid
nomosapi-removeaddonprofilebyname
nomosapi-addaddondevice
nomosapi-setaddondevice
nomosapi-getonlinelibraryprofiles
nomosapi-importonlinelibraryprofile
nomosapi-getaddonlimit
nomosapi-createbackup
nomosapi-restorebackup
nomosapi-getbackups
nomosapi-removebackup
nomosapi-downloadbackup
nomosapi-getcameras
nomosapi-getcamera
nomosapi-getcameraname
nomosapi-oncameranamechange
nomosapi-setcameraname
nomosapi-oncameraupdated
nomosapi-setcamera
nomosapi-oncameraadded
nomosapi-addcamera
nomosapi-oncameraremoved
nomosapi-removecamera
nomosapi-getcameraerror
nomosapi-getclients
nomosapi-renameclient
nomosapi-removeclient
nomosapi-getcloudstatus
nomosapi-resetcloud
nomosapi-enablecloud
nomosapi-unregistercloud
nomosapi-disablecloud
nomosapi-getsyncstatus
nomosapi-autodetectionchange
nomosapi-oncomponentadded
nomosapi-oncomponentremoved
nomosapi-oncomponentnamechange
nomosapi-oncomponentmetachange
nomosapi-oncomponenttagschange
nomosapi-setcomponentname
nomosapi-addcomponenttag
nomosapi-removecomponenttag
nomosapi-getallcomponents
nomosapi-getcomponentsbyid
nomosapi-getcomponentsbyroom
nomosapi-getcomponentsbyprofile
nomosapi-getcomponentsbytag
nomosapi-oncomponentattached
nomosapi-attachcomponent
nomosapi-oncomponentdetached
nomosapi-detachcomponent
nomosapi-startbatchmode
nomosapi-stopbatchmode
nomosapi-getcomponentassociations
nomosapi-geteverything
nomosapi-oncomponentupdate
nomosapi-componentupdate
nomosapi-getcomponentdata
nomosapi-getcomponentinitdata
nomosapi-getenginestartlog
nomosapi-getengineprojects
nomosapi-getengineconfiguration
nomosapi-setengineconfiguration
nomosapi-oneventtriggered
nomosapi-cloneevent
nomosapi-seteventname
nomosapi-addevent
nomosapi-addspecialevent
nomosapi-setevent
nomosapi-setspecialevent
nomosapi-removeevent
nomosapi-enableevent
nomosapi-disableevent
nomosapi-lockevent
nomosapi-unlockevent
nomosapi-getevent
nomosapi-getevents
nomosapi-geteventsbytag
nomosapi-getexternalaccessstatus
nomosapi-disableexternalaccess
nomosapi-enableexternalaccess
nomosapi-revokeexternalaccessclienttokens
nomosapi-getexternalaccessclienttoken
nomosapi-onfloorimageupload
nomosapi-getfloorimage
nomosapi-removefloorimage
nomosapi-getfloors
nomosapi-getfloorname
nomosapi-onfloornamechange
nomosapi-setfloorname
nomosapi-setfloor
nomosapi-onflooradded
nomosapi-addfloor
nomosapi-onfloorremoved
nomosapi-addfreeathomedevice
nomosapi-getfreeathomeaps
nomosapi-removefreeathomeap
nomosapi-authorizefreeathomeap
nomosapi-getfreeathomedevices
nomosapi-getfreeathomeapvirtualdevices
nomosapi-addfreeathomeapvirtualdevice
nomosapi-removefreeathomeapvirtualdevice
nomosapi-gethapstatus
nomosapi-gethaplasterror
nomosapi-gethapsettings
nomosapi-resethap
nomosapi-huestatechange
nomosapi-addhuelight
nomosapi-gethuedevices
nomosapi-gethuelights
nomosapi-gethuegroups
nomosapi-createhuegroup
nomosapi-removehuegroup
nomosapi-identifyhue
nomosapi-onhusqvarnaauthorization
nomosapi-inithusqvarnaauthorization
nomosapi-addhusqvarnadevice
nomosapi-gethusqvarnadevices
nomosapi-knxstatechange
nomosapi-knxremoveprogress
nomosapi-downloadknxproject
nomosapi-removeknxproject
nomosapi-getknxprojects
nomosapi-getknxmaingroups
nomosapi-getknxmiddlegroups
nomosapi-addknxgroupaddress
nomosapi-removeknxgroupaddress
nomosapi-setknxgroupaddress
nomosapi-getknxgroupaddresses
nomosapi-getknxaddresstypes
nomosapi-getknxdatapointtypes
nomosapi-addknxdevice
nomosapi-setknxdevice
nomosapi-getknxgateways
nomosapi-getlibraryindex
nomosapi-getlibrarybyprofile
nomosapi-getlibrarybyid
nomosapi-getlinks
nomosapi-onlinkupdated
nomosapi-setlink
nomosapi-onlinkadded
nomosapi-addlink
nomosapi-onlinkremoved
nomosapi-removelink
nomosapi-enablelogging
nomosapi-getloggingsettings
nomosapi-getallloggingsettings
nomosapi-disablelogging
nomosapi-resetlogging
nomosapi-getloggingdata
nomosapi-lutronimporterror
nomosapi-lutronimportprogress
nomosapi-lutronimportfinished
nomosapi-importremotelutronproject
nomosapi-setlutronproject
nomosapi-setlutronprojecthost
nomosapi-setlutronprojectcredentials
nomosapi-getlutronprojects
nomosapi-removelutronproject
nomosapi-downloadlutronproject
nomosapi-onmieleauthorization
nomosapi-initmieleauthorization
nomosapi-addmieledevice
nomosapi-getmieledevices
nomosapi-removelogo
nomosapi-getlicenseconfig
nomosapi-getproductprofile
nomosapi-getversion
nomosapi-getmqttstatus
nomosapi-addnetatmodevice
nomosapi-getnetatmodevices
nomosapi-getnetatmouser
nomosapi-getssids
nomosapi-getnetworkconfig
nomosapi-testinternetconnection
nomosapi-setnetworkhostname
nomosapi-setnetworkconfig
nomosapi-resetnodered
nomosapi-onnotification
nomosapi-getnotificationprofiles
nomosapi-addnotificationprofile
nomosapi-setnotificationprofile
nomosapi-setnotificationposition
nomosapi-enablenotificationprofile
nomosapi-disablenotificationprofile
nomosapi-removenotificationprofile
nomosapi-resetsystemnotificationprofiles
nomosapi-sendnotification
nomosapi-getnotifications
nomosapi-removeallnotifications
nomosapi-addpingdevice
nomosapi-setpingdevice
nomosapi-removepingdevice
nomosapi-getprofilemeta
nomosapi-setprofilemeta
nomosapi-enableprofile
nomosapi-disableprofile
nomosapi-getproperty
nomosapi-getpropertyname
nomosapi-onpropertynamechange
nomosapi-setpropertyname
nomosapi-addremotedevice
nomosapi-getremotedevices
nomosapi-startremotepairing
nomosapi-stopremotepairing
nomosapi-onroomimageupload
nomosapi-getroomimage
nomosapi-removeroomimage
nomosapi-getrooms
nomosapi-getroomname
nomosapi-onroomnamechange
nomosapi-setroomname
nomosapi-setroom
nomosapi-onroomadded
nomosapi-addroom
nomosapi-onroomremoved
nomosapi-removeroom
nomosapi-onroomattached
nomosapi-attachroom
nomosapi-onroomdetached
nomosapi-detachroom
nomosapi-onscenefinished
nomosapi-onscenetriggered
nomosapi-clonescene
nomosapi-getscenes
nomosapi-onsceneadded
nomosapi-addscene
nomosapi-onsceneupdated
nomosapi-onscenenamechange
nomosapi-onscenepositionchange
nomosapi-setscenename
nomosapi-setsceneposition
nomosapi-setscene
nomosapi-onsceneremoved
nomosapi-removescene
nomosapi-lockscene
nomosapi-unlockscene
nomosapi-hidescene
nomosapi-enablescene
nomosapi-disablescene
nomosapi-executescene
nomosapi-restartservice
nomosapi-enginelogupdate
nomosapi-startenginelogging
nomosapi-stopenginelogging
nomosapi-executeenginecommand
nomosapi-getexecutecommandshistory
nomosapi-removeexecutecommandshistoryentry
nomosapi-flushexecutecommandshistory
nomosapi-onsomfyauthorization
nomosapi-initsomfyauthorization
nomosapi-addsomfydevice
nomosapi-getsomfydevices
nomosapi-addsonosdevice
nomosapi-getsonosdevices
nomosapi-storageset
nomosapi-storageget
nomosapi-storagedel
nomosapi-getsupportvpninfo
nomosapi-enablesupportvpn
nomosapi-disablesupportvpn
nomosapi-getportforwardings
nomosapi-addportforwarding
nomosapi-setportforwarding
nomosapi-removeportforwarding
nomosapi-setsystemunits
nomosapi-getsystemunits
nomosapi-setfeatureflag
nomosapi-getfeatureflag
nomosapi-setsystemconfigured
nomosapi-getsystemconfigured
nomosapi-setsystemdiagnostic
nomosapi-getsystemdiagnostic
nomosapi-setsystemlanguage
nomosapi-getsystemlanguage
nomosapi-setsystemname
nomosapi-getsystemname
nomosapi-setsystemdatetime
nomosapi-getsystemdatetime
nomosapi-gettimezoneconfig
nomosapi-settimezoneconfig
nomosapi-getsystemslist
nomosapi-getoperatingsysteminfos
nomosapi-getoperatingsystemload
nomosapi-getsystemtemperatures
nomosapi-migratesystem
nomosapi-restartsystem
nomosapi-getsystemserialports
nomosapi-getcountries
nomosapi-getsystemvariablevalue
nomosapi-getsystemvariables
nomosapi-onsystemvariableadded
nomosapi-addsystemvariable
nomosapi-onsystemvariablenamechange
nomosapi-setsystemvariable
nomosapi-onsystemvariableupdated
nomosapi-onsystemvariableremoved
nomosapi-removesystemvariable
nomosapi-ontadoauthorization
nomosapi-inittadoauthorization
nomosapi-addtadodevice
nomosapi-gettadodevices
nomosapi-ontimertriggered
nomosapi-gettimers
nomosapi-addtimer
nomosapi-settimername
nomosapi-settimerposition
nomosapi-settimer
nomosapi-removetimer
nomosapi-enabletimer
nomosapi-disabletimer
nomosapi-addtvdevice
nomosapi-gettvdevices
nomosapi-getimportedupdatedetails
nomosapi-callimportedupdate
nomosapi-licenseupdatecheck
nomosapi-softwareupdatecheck
nomosapi-installsoftwareupdates
nomosapi-getautosoftwareupdateinfo
nomosapi-enableautosoftwareupdate
nomosapi-disableautosoftwareupdate
nomosapi-softwareupdateprogress
nomosapi-getusergroups
nomosapi-removeuser
nomosapi-adduser
nomosapi-setuser
nomosapi-getuser
nomosapi-getcurrentuser
nomosapi-getuserauth
nomosapi-enableuserauth
nomosapi-disableuserauth
nomosapi-getusers
nomosapi-addwebhook
nomosapi-getwebhooks
nomosapi-removewebhook
nomosapi-enablewebhook
nomosapi-disablewebhook
nomosapi-setzeptrionsmartbutton
nomosapi-addzeptriondevice
nomosapi-getzeptriondevices
nomosapi-zwavestatechange
nomosapi-addzwavedevice
nomosapi-getzwavedevices
nomosapi-startzwaveincludemode
nomosapi-stopzwaveincludemode
nomosapi-startzwaveexcludemode
nomosapi-stopzwaveexcludemode
nomosapi-getzwavedeviceinfos
nomosapi-getzwaveassocgroups
nomosapi-addzwaveassociation
nomosapi-removezwaveassociation
nomosapi-getzwaveconfigparams
nomosapi-setzwaveconfigparams
nomosapi-resetzwavecontroller
nomosapi-updatezwavenetwork
nomosapi-getzwaveconfigxmls
nomosapi-loadzwaveconfigxml
nomosapi-removezwavenode
nomosapi-interviewzwavenode
nomosapi-resetzwavealarm
nomosapi-getzwavecontrollerfrequencies
nomosapi-getzwavecontrollerfrequency
nomosapi-setzwavecontrollerfrequency
nomosapi-getzwavewakeupinterval
nomosapi-setzwavewakeupinterval
nomosapi-systemregistration
- node-red
- nomos
- iot
