node-red-contrib-node-homie-red 5.0.1
Integrate Node-RED with homie convention devices on MQTT.
npm install node-red-contrib-node-homie-red
Provides nodes to interact with devices published on mqtt following the Homie 5.0 convention.
works with MQTT Homie
This package is based on node-homie and hc-node-homie-smarthome.
Usage scenarios
The Homie convention differentiates between Devices and Controllers:
  • Device
    "An instance of a physical piece of hardware is called a device. For example, a car, an Arduino/ESP8266 or a coffee machine. It publishes Nodes and Properties to the MQTT broker." (see https://homieiot.github.io/implementations)
  • Controller
    "A controller does not announce anything to the MQTT broker, but discovers and interacts with Devices. There can be more than one Controller interacting with the different devices on the same broker." (see https://homieiot.github.io/implementations)
This node package provides nodes to support both device (virtual devices) and controller (discover and interact with existing devices) scenarios.
Controller Nodes
Configuration Nodes:
  • homie-config
Palette Nodes:
  • Device (homie-device)
  • Device Log (homie-device-log)
  • Device Alert (homie-device-alert)
  • Property (homie-property)
  • Property Target (homie-property-target)
homie-config
Here you specify the connection to your mqtt broker. Please note that also for controller mode the user needs publish rights at least for the properties {topicRoot}/5/<device>/<node>/<property>/set topic.
homie-config-editor
Please find the documentation for the fields below:
Name
  • name of the configuration node
MQTT Url
  • the connection address of the mqtt broker. This can be a mqtt:// protocol address or ws:// | wss:// address depending on your scenario. If no port is specified defaults will be assumed. (mqtt: 1883, ws: 80, wss: 443)
Homie topic root
  • MQTT topic under which all homie devices are published. By convention this defaults to homie, however for your testing or developing reasons this can be changed here as not to disturb productive usage. The actual MQTT topics will be {topicRoot}/5/{device-id}/... following the Homie 5.0 convention.
Username
  • Username for the MQTT connection. If the MQTT broker is unsecured this can be left empty.
Password
  • Password for the MQTT connection. If the MQTT broker is unsecured this can be left empty.
node-homie-device
Represents a homie device.
Input
If a message is sent to the node the current device state will be emitted.
Output
Will send outgoing messages with the device state (init, ready, disconnected, sleeping, lost).
Outgoing messages include device state in the payload and device id as separate field:
    "payload": "ready",
    "device": "security"
TODO: Implement dynamic device selection via topic like for homie-property.
node-homie-property
Represents a property of a homie device. The node will send property value updates as outgoing messages.
Input
Message payload will be sent to the homie property via .../set topic requesting the value update. If a topic is included in the incoming message it will be used to dynamically select the property to act on. (format: <deviceId>/<nodeId>/<propertyId>).
TODO: Implement a switch in the node which controls if the topic should be used or not. There are scenarios where a topic is present but should not be used.
If no payload is included and the property is a retained property the node will emit only the current value.
Special case: If the property is non-retained and the property was selected dynamically via the topic attribute a value message will be sent out immediately with the input value (without it being received from the property as there is no subscription to it due to the dynamic selection)
TODO: Maybe this behaviour should be optional.
Output
Will send outgoing messages with the property's value as payload. Besides that the message will include additional metadata about the property:
    "payload": "false",
    "topic": "group-3/switch/state",
    "homieDevice": "group-3",
    "homieNode": "switch",
    "homieProperty": "state",
    "propertyAttrs": {
        "settable": true,
        "retained": true,
        "id": "state",
        "datatype": "boolean",
        "name": "On/Off state"
    "payload": "22.5",
    "topic": "meq0006971/climate/temperature",
    "homieDevice": "meq0006971",
    "homieNode": "climate",
    "homieProperty": "temperature",
    "propertyAttrs": {
        "settable": false,
        "retained": true,
        "id": "temperature",
        "datatype": "float",
        "name": "Current temperature",
        "unit": "°C"
Represents alert messages of a discovered homie device under $alert/<alertId>.
Input
If a message is sent to the node, all active alerts are emitted as an array in payload.
Output
Will emit alert events from the selected device.
    "device": "security",
    "alertId": "$lowbattery",
    "topic": "security/$alert/$lowbattery",
    "payload": "battery below 10%",
    "cleared": false,
    "action": "set"
If an alert is cleared, payload becomes null and action is clear.
Represents log messages of a discovered homie device under $log/<level>.
Output
Will emit log events from the selected device.
    "level": "warn",
    "topic": "security/$log/warn",
    "payload": "battery voltage unstable",
    "message": "battery voltage unstable"
Represents the $target value of a discovered homie property.
Input
If a message is sent to the node the current target value is emitted. If no property is configured, msg.topic can be used with <deviceId>/<nodeId>/<propertyId>.
Output
Will output target value changes and target snapshots.
    "topic": "heater-1/thermostat/temperature",
    "payload": "22.5",
    "target": "22.5",
    "homieDevice": "heater-1",
    "homieNode": "thermostat",
Virtual Device
  • homie-vdevice-config
Palette Nodes:
  • Virtual Device (homie-vdevice)
  • vprop value (homie-vproperty-value-update)
  • vprop /set (homie-vproperty-set-command)
  • vdevice log (homie-vdevice-log-update)
  • vdevice alert (homie-vdevice-alert-update)
  • vprop target (homie-vproperty-target-update)
A configuration node that creates a virtual device owned by Node-RED. The specification of a device is too complex to build a nice user interface around it. Therefore the spec has to be provided as JSON input. The datamodel is more or less straight forward with some specials to it. In general you can more or less model the devices, nodes and properties as they would be published via the mqtt topic structure with the following differences:
  • attributes are written without the "$" prefix for ease of use (name instead of $name)
  • ids have to be specified as fields, nodes and properties are arrays (lists) instead of dictionaries/maps like you would expect in the topic hierarchy.
Explanation
This will show the tree structure level by level.
Device:
nodes:
    - node1
    - node2
    - node3
For each node:
type: node type
properties:
    - property1
    - property2
    - property3
For each property:
datatype: boolean
settable: true
All together this looks like this:
nodes:
    - id: nodeId
      type: node type
      properties:
        - id: propertyId
          datatype: boolean
          settable: true
        - id: propertyId
          datatype: boolean
          settable: true
    - id: nodeId
      type: node type
      properties:
        - id: propertyId
          datatype: boolean
          settable: true
        - id: propertyId
          datatype: boolean
          settable: true
Below you find an actual JSON example that can be used directly for testing.
    "id": "node-red-virtual-device-1",
    "name": "Virtual a test device",
    "nodes": [
            "id": "switch",
            "name": "Virtual switch",
            "type": "virtual-switch",
            "properties": [
                    "id": "state",
                    "passThrough": false,
                    "name": "Virtual switch state",
                    "settable": true,
                    "propertyOpts": {
                        "readValueFromMqtt": true
In Homie 5.0, the device publishes a $description JSON document and a $state topic on MQTT under {topicRoot}/5/{device-id}/.... Property values are published as individual topics under the device's topic tree.
General note The following fields on the device cannot be specified:
  • state
  • homie
  • extensions
As you can see in the example above there are a few extra configuration options that can be used. Below you can find them listed by homie structure element.
Node level extra configuration
passThrough (boolean, default false):
  • when set to true, all properties below this node will 'autoconfirm' /set messages sent to them. Which means they will simply update their value state with the value sent to /set.
  • when set to false, you have to take care to update the property value in your flow yourself using the vprop value (homie-vproperty-value-update) node.
fromSmarthome (object):
  • node-homie-red uses the node-homie and hc-node-homie-smarthome libraries under the hood. The latter defines a set of standard node types for smarthome usage in the homie-homecontrol smarthome system. This option offers easy specification of these default nodes in your devices. For more details see the section Smarthome Spec.
propertyOpts (object, default { "readValueFromMqtt": true, "readTimeout": 3000 }):
  • node-homie offers to read the current value of a property from mqtt when creating the device. Basically using mqtt as persistent storage itself. This is useful to retain the last value of the property in case of a Node-RED restart for example.
  • readValueFromMqtt: Default is to read the last value in on device initialization - if you set this to false make sure to take care of setting the initial value for the property after a Node-RED restart.
  • readTimeout: max time in milliseconds to wait for a message to be received from mqtt for the property topic. Please note for new empty properties this leads to a delay of readTimeout milliseconds before the device finishes initializing (transitions to state ready).
  • data format:
        "readTimeout": 3000
Property level extra configuration
  • when set to true, the property will 'autoconfirm' /set messages sent to it. Which means it will simply update its value state with the value sent to /set.
  • this will overwrite any setting on node level per property
  • data format:
        "readTimeout": 3000
Smarthome Spec
The smarthome spec offers quick definition of nodes and properties according to the hc-smarthome node definition without having to specify every single property manually. (see hc-node-homie-smarthome)
For example, if you only need a simple switch the following device spec:
    "id": "node-red-virtual-device-2",
    "name": "Virtual switch device",
    "nodes": [
            "id": "switch",
            "fromSmarthome": {
                "type": "hc-smarthome/v2/cap/switch"
Would result in a device with a switch node containing state (boolean, settable) and action (enum, non-retained) properties.
Data format for fromSmarthome:
    "type": "hc-smarthome/v2/cap/<typename>",
    "config": {
        // typespecific node configuration
type
  • The following types are supported:
    • hc-smarthome/v2/cap/battery
    • hc-smarthome/v2/cap/switch
    • hc-smarthome/v2/cap/contact
    • hc-smarthome/v2/cap/climate
    • hc-smarthome/v2/cap/button
    • hc-smarthome/v2/cap/tilt
    • hc-smarthome/v2/cap/motion
    • hc-smarthome/v2/cap/thermostat
    • hc-smarthome/v2/cap/mediaplayer
    • hc-smarthome/v2/cap/powermeter
    • hc-smarthome/v2/cap/maintenance
    • hc-smarthome/v2/cap/level
    • hc-smarthome/v2/cap/shutter
    • hc-smarthome/v2/cap/color
    • hc-smarthome/v2/cap/text
config
  • Each type has its own configuration. For more details see the technical spec of the data model.
Overriding or extending on default nodes
You can still provide a properties field in combination with fromSmarthome. Any matching property ids will overwrite the default ones where supported. You can also extend the node with additional properties (however then it is not adhering to the standard any more)
node-homie-vdevice
Update virtual device state.
Input
If a message is sent to the node the device will be set to the payload value. If no payload is specified only the current state will be emitted via the output.
Output
    "payload": "ready",
node-homie-vproperty-value-update
Update virtual device's property value.
Input
If a message is sent to the node the property's value will be set to the payload value. Please note that this is different from the homie-property node as it will update the internal value of the property which will be then published to mqtt. The homie-property will send a /set message which is different.
node-homie-vproperty-set-command
Emits when a message is published under the virtual device's property '/set' topic.
Output
Message with /set value that was sent to the device via mqtt.
Outgoing messages include the /set value as payload and a topic and property field with the property path:
    "payload": "true",
    "topic": "lamp-1/switch/state",
    "property": "lamp-1/switch/state"
Sets or clears virtual device alerts by publishing to $alert/<alertId>.
Input
Uses configured alertId (or msg.alertId if set).
  • If msg.payload contains a value, the alert is set.
  • If msg.payload is null/undefined, or msg.clear === true, the alert is cleared.
Publishes virtual device log messages to $log/<level>.
Input
Uses configured level (or msg.level if set).
  • msg.payload is converted to string and published as log message.
Updates the $target value of a virtual property.
Input
  • If msg.payload contains a value, the target is updated.
  • If msg.payload is null/undefined, the target is cleared.
Breaking changes (v4 → v5)
Homie protocol
  • Topics now use {topicRoot}/5/{device-id}/... format (includes /5/ version segment)
  • Device metadata is a single JSON $description document instead of individual MQTT topics
  • Device states remain init, ready, disconnected, sleeping, lost; alerts are exposed via $alert/<id>
  • Properties in output messages no longer include tags and meta fields (removed in v5)
Smarthome namespace
All fromSmarthome type strings changed from homie-homecontrol/v1/type=X to hc-smarthome/v2/cap/X:
  • homie-homecontrol/v1/type=switch → hc-smarthome/v2/cap/switch
  • homie-homecontrol/v1/type=dimmer → hc-smarthome/v2/cap/level
  • homie-homecontrol/v1/type=colorlight → hc-smarthome/v2/cap/color
  • homie-homecontrol/v1/type=weather → hc-smarthome/v2/cap/climate
  • homie-homecontrol/v1/type=motionsensor → hc-smarthome/v2/cap/motion
  • homie-homecontrol/v1/type=tiltsensor → hc-smarthome/v2/cap/tilt
  • and all other types follow the same hc-smarthome/v2/cap/{name} pattern
API changes (from underlying libraries)
  • setAttributes() → patchAttributes()
  • addInitNode() → add() (nodes added synchronously before onInit())
  • HomieProperty.parent → HomieProperty.node
  • Model type renames: BaseItemAttributes → BaseAttributes, HomieNodeAttributes → NodeAttributes, HomiePropertyAttributes → PropertyAttributes
Version: 5.0.1
Updated 6 months, 3 weeks ago
247 in the last week
  • homie-device
  • homie-device-log
  • homie-device-alert
  • homie-property
  • homie-property-target
  • homie-config
  • homie-vdevice
  • homie-vproperty-value-update
  • homie-vproperty-set-command
  • homie-vdevice-log-update
  • homie-vdevice-alert-update
  • homie-vproperty-target-update
  • homie
  • node-homie
  • homie-homecontrol
  • smarthome
  • mqtt
  • iot
