node-red-contrib-node-email-state-notification 0.0.1
Node-RED nodes to send and receive simple emails (added an output payload to the email-output node containing the email state)
npm install node-red-contrib-node-email-state-notification
node-red-node-email
Node-RED nodes to send and receive simple emails.
Pre-requisite
You will need valid email credentials for your email server. For GMail this may mean getting an application password if you have two-factor authentication enabled.
Note : Version 1.x of this node requires Node.js v8 or newer.
Version 0.x of this node is usually installed by default by Node-RED. As long as you have at least version 0.19.x of Node-RED you can install the new version by using the Menu - Manage Palette option, or running the following command in your Node-RED user directory - typically ~/.node-red
    npm i node-red-contrib-email-state-notification
GMail users
If you are accessing GMail you may need to either enable an application password, or enable less secure access via your Google account settings.
Nodes to send and receive simple emails.
Contribution
What have been added in the contribution :
  • output payload containing the node status (email sent, email failed, ...) and info from smtp serveur.
Input
Repeatedly gets emails from an IMAP or POP3 server and forwards them onwards as messages if not already seen.
The subject is loaded into msg.topic and msg.payload is the plain text body. If there is text/html then that is returned in msg.html. msg.from and msg.date are also set if you need them.
Additionally msg.header contains the complete header object including to, cc and other potentially useful properties.
Note: this node only gets the most recent single email from the inbox, so set the repeat (polling) time appropriately.
Uses the imap npm module.
Output
Sends the msg.payload as an email, with a subject of msg.topic.
The default message recipient can be configured in the node, if it is left blank it should be set using the msg.to property of the incoming message.
You may optionally override the from email address by setting msg.from, otherwise the node will use the userid setting from the server connection.
The payload can be html format.
If the payload is a binary buffer then it will be converted to an attachment.
The filename should be set using msg.filename. Optionally msg.description can be added for the body text.
Alternatively you may provide msg.attachments which should contain an array of one or more attachments in nodemailer format.
Uses the nodemailer npm module.
Version: 0.0.1
Updated 5 years, 9 months ago
Rating: 1.0 1
7 in the last week
  • email out
  • email in
  • email
  • gmail
  • imap
  • pop
  • state
  • notification
