node-red-contrib-nmea 0.0.4
Node-RED node for parsing NMEA 0183 sentences
npm install node-red-contrib-nmea
A Node-RED node to decode NMEA format messages.
npm i node-red-contrib-nmea
A node that parses NMEA sentences into a JavaScript objects containing the data.
Specify the input property containing an NMEA sentence (default msg.payload).
Latitude and longitude values will be parsed into decimal degrees. If the NMEA sentence contains a date and timestamp, the property dateTime will be a JavaScript Date object representation of the date and time.
Example output object for a RMC sentence (as JSON):
    "sentence":"RMC",
    "type":"nav-info",
    "timestamp":"163948.00",
    "status":"valid",
    "lat":44.617677,
    "latPole":"N",
    "lon":-87.93293367,
    "lonPole":"W",
    "speedKnots":7.143,
    "trackTrue":31.54,
    "date":"111020",
    "variation":0,
    "variationPole":"",
    "talker_id":"GP",
    "dateTime":"2020-10-11T16:39:48.000Z"
Version: 0.0.4
Updated 6 years, 6 months ago
53 in the last week
  • nmea
  • node-red-contrib
  • NMEA
