node-red-contrib-nextcloud-talk 1.0.0
Nextcloud Talk connector for Node-RED
npm install node-red-contrib-nextcloud-talk
Node-RED Nextcloud talk
license: LGPLv3 GitHub release GitHub Lint Workflow Status GitHub Publish Workflow Status npm
Nextcloud Talk connector for Node-RED without any third-party dependencies
Key features
  • Send message to room as bot,
  • Listen for messages in room.
Search node-red-contrib-nextcloud-talk within the palette manager or install with npm from the command-line (within your user data directory):
As with every node installation, you may need to restart Node-RED for it to pick-up the new nodes.
Nextcloud Talk
Install a bot by providing the following three pieces of information (see docs):
  • bot name,
  • secret (between 40 et 128 characters),
  • full URL of your Node-RED instance (including the access path)
occ talk:bot:install mybotname mySup3rSecret https://node-red-instance.domain.ltd:1880/talk
Node-RED
[!IMPORTANT]
In order to verify the message signature, you will need to modify the httpAdminRoot attribute in the setting.js file so that it is not at the root.
    // uncomment to ensure that admin does not use "/"
    httpAdminRoot: '/admin',
Configure your node with the shared secret, nextcloud URL.
Versioning
node-red-contrib-nextcloud-talk is maintained under the semantic versioning guidelines.
See the releases on this repository for changelog.
  • Nioc - Initial work
See also the full list of contributors to this project.
This project is licensed under the GNU Lesser General Public License v3.0 - see the LICENSE file for details
Version: 1.0.0
Updated 10 months, 2 weeks ago
License: LGPL-3.0-or-later
  • nextcloud-talk-bot
  • nextcloud-talk-send
  • nextcloud-talk-webhook
  • nextcloud
  • talk
