node-red-contrib-nextcloud-info 0.6.2
Nextcloud monitor node-red node for Nextcloud Administrators only
npm install node-red-contrib-nextcloud-info
Nextcloud external monitoring tool node let Administrator get information on Nextcloud instance. Editor image
Install from PALETTE Manager or run the following command in your NODE-RED user directory typically: ~/.node-red
This node is for Nextcloud Administrators. To get your external monitor URL from your Nextcloud instance use: SETTINGS > SYSTEM > External monitoring tool. Self Signed Certs can be enabled at your own risk. Nextcloud System Settings image
News
Other Nextcloud EndPoint url are now available to get information about users, capabilities and more.
Tested only on Nextcloud 18, should work on version 15 or greater.
Version: 0.6.2
Updated 5 years, 3 months ago
18 in the last week
  • nextcloud-info
  • cloud
  • nextcloud
  • monitor
  • administrator
