node-red-contrib-netio 2.1.11
netio node-red
npm install node-red-contrib-netio
node-red-contrib-netio is node-red node that for Netio devices dashboard using JSON in first version.
Use the package manager pip to install node-red-contrib-netio.
pip install node-red-contrib-netio
  1. install Netio package in your node-red.
  2. open node-red and add netio node from network section to your flow.
  3. Double click on node to view options and set the inputs with your device information.
  4. add your actions to your flow and connect them to netio node.
  5. Finally Deploy your flow and enjoy your dashboard.
Options
In node options you see many inputs that described below :
Option Descrioption Defualts
name the name that shows on node in flow netio
URL the URL/IP-Adress of your device withou protocols(http/https) or any port and path none
port the port number of JSON config in device nune
path the path or name of json that set in config, starts with /, .e.g (/netio.json) none
intervall the time inervall that node get data from device 1000 ms
Username username that you set in device config none
Password password that you set in device config none
ISC
Version: 2.1.11
Updated 5 years, 8 months ago
3 in the last week
  • netio
  • netio
  • power sockets node
  • power metring
  • PDU Control
