node-red-contrib-netatmo-energy 0.9.2
A node-red to interact with Netatmo thermostat
npm install node-red-contrib-netatmo-energy
Node-RED nodes to talk to the Netatmo thermostat
npm version Downloads Build Status
Version 0.9.1 - The client Credentials grant type removal.
Switch to Netatmo OAUTH2 authorization. Netatmo is removing username and password authorization at the end of September 2022 - https://dev.netatmo.com/apidocumentation/oauth#authorization-code. So it was necessary to switch from the "Client credentials grant type" to the "Authorization code grant type" method.
You must obtain a Netatmo API refresh token to make this node work. You can get it manually or use the simple command line program Netatmo Auth CLI.
After setting up the refresh token, the node already obtains and renews the access token itself.
Tested with:
  • Node 16 LTS
  • macOS Monterey
  • Armbian
Run command on Node-RED installation directory:
for global installation:
npm install -g node-red-contrib-netatmo-energy
Node HOMESDATA
This node returns the user's homes and their topology associated with this netatmo account.
Documentation: https://dev.netatmo.com/resources/technical/reference/energy/homesdata
Homesdata node config
Node config
  • home_id - (Optional) Id of the home
  • gateway_types - (Optional) Array of desired gateway. For Energy app, use NAPlug
Node config can be overwritten by message payload.
Node HOMESTATUS
This node returns current status and data measured for all home devices.
Documentation: https://dev.netatmo.com/resources/technical/reference/energy/homestatus
Homestatus node config
Node config
  • home_id - (required) Id of the home
  • device_types - (Optional) Array of device type, eg. NAPlug
Node GETROOMMEASURE
This node returns the history of data associated to a room.
Documentation: https://dev.netatmo.com/apidocumentation/energy#getroommeasure
Getroommeasure node config
Node config
  • room_id - (required) Id of the room
  • scale - (required) Timeframe between two measurements {30min, 1hour, 3hours, 1day, 1week, 1month}
  • type - (required) Type of data to be returned {temperature, sp_temperature (temperature setpoint)), min_temp, max_temp, date_min_temp, date_max_temp}, date_min_temp & date_max_temp are only available for large scales ({1day, 1week, 1month}).
Node SETTHERMMODE
This node set the home heating system to use schedule/ away/ frost guard mode.
Documentation: https://dev.netatmo.com/resources/technical/reference/energy/setthermmode
Setthermmode node config
Node config
  • mode - (required) Heating mode, schedule or away or hg ...
  • endtime - (Optional) End time in seconds, eg. 180
Node SETROOMTHERMPOINT
This node set a manual temperature to a room.
Documentation: https://dev.netatmo.com/resources/technical/reference/energy/setroomthermpoint
Setroomthermpoint node config
Node config
  • mode - (required) The mode you are applying to this room - manual OR home
  • temp - (Optional) Manual temperature to apply
  • endtime - (Optional) End time in second, eg. 180
Node GETROOMMEASURE
This node returns data from a Room.
Node config
  • scale - (required) Step between measurements. Values: 30min, 1hour, 3hours, 1day, 1week, 1month, max
  • type - (required) Type of requested measurements. Values: temperature, sp_temperature, min_temp, max_temp, date_min_temp
  • date_begin - (Optional) Timestamp of the first measure to retrieve. Default is null.
  • date_end - (Optional) Timestamp of the last measure to retrieve (default and max are 1024). Default is null.
  • limit - (Optional) Maximum number of measurements (default and max Are 1024)
  • optimize - (Optional) Determines the format of the answer. Default is true. For mobile apps we recommend True and False if bandwidth isn't an issue as it is easier to parse.
  • real_time - (Optional) If scale different than max, timestamps are by default offset + scale/2. To get exact timestamps, use true. Default is false
Node SWITCHHOMESCHEDULE
This node switches the home schedule to the given schedule.
Documentation: https://dev.netatmo.com/apidocumentation/energy#switchhomeschedule
Node config
  • schedule_id - (required) Id of the schedule to switch on
Library using forked netatmo library - https://github.com/karbassi/netatmo.
The Apache License, Version 2.0
Version: 0.9.2
Updated 4 years, 2 months ago
Rating: 5.0 2
16 in the last week
  • netatmoconfig
  • homesdata
  • homestatus
  • setthermmode
  • setroomthermpoint
  • getroommeasure
  • switchhomeschedule
  • netatmo
  • energy
