node-red-contrib-netatmo-cloud 1.0.0
Node-RED nodes for the Netatmo cloud API (weather station and any endpoint) with built-in OAuth2 refresh-token rotation and persistent token storage. No extra flow needed.
Node-RED nodes for the Netatmo cloud API, with OAuth2 token handling built in. No extra authentication flow, no global context, no token file nodes: drop in one node, set three environment variables, done.
- weather station node: reads
getstationsdata(indoor station, outdoor, wind, rain and extra indoor modules). Output either the unchanged API response or one message per module. - netatmo api node: calls any other endpoint (
getmeasure,gethomecoachsdata,homesdata,homestatus, ...) with the same account. - Netatmo account config node: handles the rotating refresh token and stores it safely on disk.
Requires Node.js 18 or newer and Node-RED 3 or newer (tested with Node-RED 4.1 and 5.0).
Why another Netatmo node?
Since Netatmo switched to OAuth2 with rotating refresh tokens, the existing Node-RED Netatmo packages (last published 2017 to 2022) no longer keep a working login: every refresh issues a new refresh token and invalidates the old one. If that new token is not stored, the login is lost after the next restart.
This package keeps the token chain alive:
- the access token is refreshed on demand (5 minutes before it expires, or when Netatmo rejects it), parallel requests share a single refresh;
- the new token pair is written to a token file atomically (temp file, fsync, rename), so a restart, a container update or a power cut in the middle of a write does not lose the token;
- if the stored token is rejected, the initial refresh token from the configuration is tried as fallback; a newly configured initial token is preferred over an old stored chain, so re-authorising only means setting a new token;
- after a rejected token the node pauses 15 minutes instead of hammering the Netatmo API; network errors never count as authorisation errors.
In the Node-RED editor: Menu → Manage palette → Install, search for node-red-contrib-netatmo-cloud.
Or on the command line in your Node-RED user directory (usually ~/.node-red):
npm install node-red-contrib-netatmo-cloud
Setup
Create an app on dev.netatmo.com/apps. Note the client ID and client secret.
In the app, use the token generator: choose the scopes you need (
read_stationfor weather stations,read_homecoach,read_thermostat, ... for other products) and generate a token. Copy the refresh token.Provide the three values as environment variables of Node-RED:
Variable Value NETATMO_CLIENT_IDclient ID NETATMO_CLIENT_SECRETclient secret NETATMO_REFRESH_TOKENrefresh token (only needed for the first start or to re-authorise) Add a weather station node, create a Netatmo account in it (the defaults already point to the variables above) and deploy.
The fields of the account node contain only references like ${NETATMO_CLIENT_SECRET}, so the secrets
never end up in your flow file or in flow exports. If you type a secret directly into a field, the node
logs a warning.
Docker, balena and similar
Set the variables in the container environment, e.g. as fleet or device variables on balena or under
environment: in a compose file. Make sure the token file lies on a persistent volume. By default it
is <userDir>/netatmo/tokens-<node id>.json; set an absolute path if your user directory is not
persistent.
Several Node-RED instances
A token chain must be used by one Node-RED instance only. Two instances refreshing the same chain invalidate each other's tokens. Use one Netatmo app (or at least one generated token) per instance.
weather station
Triggered by any input message, or by its own timer (Poll every, 0 = only on input).
| Setting | Meaning |
| Station | MAC address of the main station (70:ee:50:...) or ${VAR}. Empty: all stations of the account |
| Include favourite stations | also return stations marked as favourites |
| Output | API response or One message per module |
API response (default): msg.payload is the response exactly as Netatmo delivers it:
"body": {
"devices": [{
"_id": "70:ee:50:00:00:01", "type": "NAMain", "station_name": "My station (Indoor)",
"reachable": true, "wifi_status": 39,
"dashboard_data": { "time_utc": 1795442972, "Temperature": 23.9, "CO2": 1145, "Humidity": 47,
"Noise": 36, "Pressure": 1005.5, "AbsolutePressure": 954.3, "...": "..." },
"modules": [{
"_id": "02:00:00:00:00:02", "type": "NAModule1", "module_name": "Outdoor",
"battery_percent": 65, "rf_status": 39, "reachable": true,
"dashboard_data": { "time_utc": 1795442947, "Temperature": 2.8, "Humidity": 91, "...": "..." }
"user": { "...": "..." }
"status": "ok", "time_exec": 0.08, "time_server": 1795443481
One message per module: the main station and each module as a separate message:
"topic": "My home/Outdoor",
"payload": { "time_utc": 1795442947, "Temperature": 2.8, "Humidity": 91, "min_temp": 1.6, "...": "..." },
"netatmo": {
"module_id": "02:00:00:00:00:02", "module_name": "Outdoor", "type": "NAModule1",
"reachable": true, "battery_percent": 65, "battery_vp": 5362, "rf_status": 39,
"station_id": "70:ee:50:00:00:01", "station_name": "My station (Indoor)",
"home_id": "...", "home_name": "My home", "place": { "...": "..." }
Values and units are those of the Netatmo API (time_utc in Unix seconds). Module types: NAMain
indoor station, NAModule1 outdoor, NAModule2 wind, NAModule3 rain, NAModule4 extra indoor module.
Netatmo stations upload about every 5 to 10 minutes; polling more often than once a minute brings no new values. Netatmo allows 500 requests per hour and user.
netatmo api
Calls https://api.netatmo.com/api/<endpoint>. Parameters come from the node configuration (JSON) merged
with msg.params (or an object in msg.payload). msg.endpoint overrides the endpoint.
msg.payload of the output is the unchanged Netatmo response.
Example, temperature history of the last day in 30 minute steps:
{ "params": { "device_id": "70:ee:50:00:00:01", "scale": "30min", "type": "Temperature",
"date_begin": 1795360000, "optimize": "false" } }
Errors
Network and API errors are thrown to Node-RED, so a catch node receives them; msg.error holds
message, code and status. If the authorisation fails for good (refresh token revoked or used by
another instance), the node status turns red: generate a new refresh token, set it as
NETATMO_REFRESH_TOKEN and restart or redeploy.
Example
Menu → Import → Examples → node-red-contrib-netatmo-cloud contains a ready-made flow.
Migrating from a hand-made OAuth2 flow
If you kept the token in a JSON file with an http request / file node flow, you can point the
Token file setting to that file: any JSON file with a refresh_token field is accepted, and the chain
continues without a new token. Remove the old flow in the same deploy, otherwise both refresh the same
chain.
Development
npm install
npm test
The tests run against a fake Netatmo server that rotates refresh tokens like the real one, and load the
nodes into a real Node-RED runtime with node-red-node-test-helper.
Kurzfassung auf Deutsch
Node-RED-Nodes für die Netatmo-Cloud mit eingebauter OAuth2-Token-Verwaltung: kein separater
Authentifizierungs-Flow mehr nötig. App auf dev.netatmo.com anlegen, mit dem Token-Generator ein
Refresh-Token erzeugen und NETATMO_CLIENT_ID, NETATMO_CLIENT_SECRET und NETATMO_REFRESH_TOKEN als
Umgebungsvariablen setzen (auf balena als Flotten- oder Gerätevariablen). Der Node speichert das sich bei
jedem Refresh ändernde Token selbst auf dem persistenten Speicher. Ausgabe: die Netatmo-Antwort
unverändert oder eine Nachricht pro Modul.
Apache License 2.0, see LICENSE.
Not affiliated with or endorsed by Netatmo. Netatmo is a trademark of its owner.
