node-red-contrib-neo4j-connector 1.0.2
Neo4j package (work in progress)
npm install node-red-contrib-neo4j-connector
Neo4j Bolt with shareable driver
A Node-RED node with the shareable server configuration that lets you run generic cypher queries on a Neo4j graph database and receive all types of Neo4j records.
Run the following command in the root directory of your Node-RED install or home directory (usually ~/.node-red) and will also install needed libraries.
npm install node-red-contrib-neo4j-bolt
First, you define the Neo4j bolt URL and the basic authentication username and password in the configuration node. This node creates a driver which will be shared across all Neo4j-Bolt nodes. Each node creates its own driver session.
You can specify a cypher query in the node configuration or pass to the node as msg.query. The parameters for the query (if needed) are read from msg.params.
  • Example of hard coded query in the configuration of the node.
MATCH (m:Movie {title: "Forrest Gump"}) return m
  • Example of a parameterized query. Query in the configuration:
MATCH (m:Movie {title: $moviename}) return m
msg.params:
{"moviename": "Forrest Gump"}
  • Example of both query and params being passed in msg
msg.query:
msg.params:
The node has two outputs. If the query returns only 1 record, the requested properties of the node are sent to output #1. If the query returns multiple records, an array of requested properties of the nodes are sent to output #2.
This node uses the neo4j-driver package to communicate with Neo4j.
Runtime information
This node was tested to Node.js v7.4.0 and NPM 5.6.0 on Node-Red v0.18.4
Credits
This node is based on node-red-contrib-nulli-neo4j by Nulli.
Version: 1.0.2
1 in the last week
  • neo4j-connector
  • neo4j-connector-server
  • nodered
  • neo4j
  • cypher
