node-red-contrib-natsstreaming 0.3.4
NATS streaming with Node-RED
npm install node-red-contrib-natsstreaming
Node-RED nodes for nats streaming
Or in NodeRED Manage palette and serarch for node-red-contrib-natsstreaming
Requirements
Needs an instance of nats streaming to publish messages or subscribe to a topic https://nats.io/
Publish
publish new
Every publish node needs
  • a nats server
  • a channel name
  • a client id
If everything is correct the node shows a green dot otherwise an error messege will show what is missing and the dot is red.
publish connected
Subscribe
subscribe new
The subscribe node needs the same basic settings
  • a nats server
  • a channel name
  • a client id
This node will also show a green dot if it is connected and a red one if not.
publish connected
Server
publish connected The configuration for a nats streaming server is saved in an NodeRED configuration node. Adding a new one can be done from a publish or subscribe node by clicking selecting Add new nat-straming-server... and clicking on the pen icon.
server new
The server needs
  • a nats server adress - default is localhost
  • a port number - default is 4233
  • a name of the cluster - default is test-cluster
Version: 0.3.4
Updated 5 years, 2 months ago
19 in the last week
  • nats-streaming-publish
  • nats-streaming-subscribe
  • nats-streaming-server
  • nats-streaming-acknowledge
  • nats
  • nats-streaming
