node-red-contrib-myuplink 2.0.3
A Node-Red Node for collecting data from myUplink.
npm install node-red-contrib-myuplink
Platform
During setup of config you will be guided on how to sign up for an API key to your own account. For an easy start import the example.
How to import: Menu top right -> Import -> Examples -> node-red-contrib-myuplink -> basic
The node
The config
List of supported functions
Documentation of functions are found here https://api.myuplink.com/swagger/index.html
Help with app setup
For node-red access you need to register an app on you user profile at: https://dev.myuplink.com/apps
Guide text inside node-red config setup should help you fill in any specific details needed.
What is offline access
This question might come to you when during the setup you are asked for the one time auth code. If you press the wrong button here, clear browser history and try again.
Remember to check the offline access checkmark after login to myUplink from the popup Else you will need generate a new one time auth code every hour! I know the offline access statement seems worrisome but that just means that your auth codes can be refreshed without you needing to login and approve it each time/aka every hour.
alt
Version: 2.0.3
Updated 2 years, 3 months ago
3 in the last week
  • myuplink-config
  • myuplink
  • myuplink
