node-red-contrib-mysql2-ts 1.0.23
A Node-RED node to connect to a MySQL or a MariaDB database, using TLS (SSL) and compatible with "Caching SHA2 password" authentication method (MySQL >= 8).
npm install node-red-contrib-mysql2-ts
Node-RED node to read and write to a MySQL or a MariaDB database.
It uses TLS (SSL) encryption and is compatible with "Caching SHA2 password" authentication method (MySQL >= 8).
Remember: if you like it, please star it! 🥰
Official repository: https://github.com/modbus2mqtt/node-red-contrib-mysql2-ts
Example of use
Sponsors
node-red-contrib-mysql2-ts was created as a fork of node-red-contrib-stackhero-mysql which was developed by Stackhero. If you are looking for powerful managed services, like Node-RED, MySQL or MariaDB, you should seriously consider Stackhero 🤓
This node is really simple.
Put your query in the topic variable and, if you have arguments, put them in an object in the payload variable. You will get the result in the payload output variable.
Example:
msg.topic = 'SELECT * FROM `users` WHERE `name` = :name AND `age` > :age;';
msg.payload = { name: 'Adrien', age: 30 };
If you have multiple arguments, put them in an array of objects in the payload variable. You will get the result in the payload output variable.
Example:
msg.topic = 'INSERT INTO `users` (`name`,  `age`) VALUES( :name, :age) ;';
msg.payload = [
  { name: 'Adrien', age: 30 },
  { name: 'Maria', age: 62 }
Avoid SQL injections!!
Do not NEVER EVER put variables content in topic directly! Always use the payload variable to pass your arguments.
Troubleshooting
Error "Connections using insecure transport are prohibited while --require_secure_transport=ON"
You have to connect using TLS encryption. Simply check the box in this node configuration.
Error "ER_NOT_SUPPORTED_AUTH_MODE: Client does not support authentication protocol requested by server; consider upgrading MySQL client"
You are probably using another node than node-red-contrib-mysql2-ts and tryin to connect to a MySQL >= 8 server using "Caching SHA2 password" authentication method.
To resolve that issue, simply use this node node-red-contrib-mysql2-ts.
Version: 1.0.23
Updated 1 year, 2 months ago
License: AGPL-3.0
150 in the last week
  • MySQL-Query
  • MySQL-Server
  • stackhero
  • mysql
  • mariadb
