node-red-contrib-mysql-config 1.0.4
Fork of node-red-contrib-stackhero-mysql that allows config to be set via environment variables.
npm install node-red-contrib-mysql-config
Node-RED node to read and write to a MySQL or a MariaDB database.
Foreword
Note: All credit for this work goes to the original creator(s): https://github.com/stackhero-io/node-red-contrib-stackhero-mysql
This is a fork for the purpose of configuring a connection using environment variables.
Use Case
The primary use case for using this version is in instances where NodeRED changes are being deployed using CI/CD pipelines across multiple environments and credentials need to be configured using environment variables as opposed to manually setting them in the NodeRED UI.
In order to configure this node, set each of the inputs with it's environment variable name.
This node is really simple.
Put your query in the topic variable and, if you have arguments, put them in an object in the payload variable. You will get the result in the payload output variable.
Example:
msg.topic = 'SELECT * FROM `users` WHERE `name` = :name AND `age` > :age;';
msg.payload = { name: 'Adrien', age: 30 };
Avoid SQL injections!!
Do not NEVER EVER put variables content in topic directly! Always use the payload variable to pass your arguments.
Version: 1.0.4
Updated 4 years, 6 months ago
License: AGPL-3.0
1266 in the last week
  • MySQL-Server-Connector
  • MySQL-Connector
  • mysql
  • mariadb
