node-red-contrib-myskoda 2.3.5
Node-RED nodes for interacting with MySkoda (formerly Skoda Connect)
npm install node-red-contrib-myskoda
NPM version Downloads
MySkoda nodes for Node-RED
Simple nodes for getting car information from the MySkoda platform and sending remote commands to your vehicle.
v2.2.0 - Shared credentials via config node (enter email/password once, use in all nodes). Includes complete example flow with all operations.
v2.0.0 - Complete rewrite using the new MySkoda API (replaces the legacy Skoda Connect / VW Group API that stopped working). All Skoda vehicles supported by the MySkoda app are compatible.
Requirements
  • Node.js >= 16
  • A MySkoda account (the same credentials you use in the MySkoda mobile app)
  • Your vehicle must be visible and functional in the MySkoda app
  1. Add any myskoda-get or myskoda-set node to your flow
  2. In the node config, click the pencil icon next to Account to create a new MySkoda Account config node
  3. Enter your MySkoda email and password once — all nodes sharing the same config will use these credentials
Usage: myskoda-get node
Select your MySkoda Account. Any input triggers the API call. Output is a JSON object with information for each vehicle in your account.
Always returned:
  • Vehicle info (model, nickname, connectivity generation)
  • Vehicle status (doors, windows, lights, odometer)
  • Driving range (fuel level, battery SoC, estimated range)
Optional (select in node config):
  • Parking position
  • Air conditioning status
  • Charging information (EV/PHEV)
  • Maintenance report
Example output
  "vehicles": [
      "vin": "TMBJXXXXXXXXXXXXXXX",
      "info": { ... },
      "status": { ... },
      "drivingRange": { ... },
      "positions": { ... },
      "airConditioning": { ... },
      "charging": { ... },
      "maintenance": { ... }
Example flow
A complete example flow with all operations is included. Import it via: Menu → Import → Examples → node-red-contrib-myskoda → complete-flow
Usage: myskoda-set node
Select your MySkoda Account and a command from the dropdown. Each command requires msg.vin with the vehicle VIN.
Available commands
Command msg.payload Other required fields
Start Air Conditioning - -
Stop Air Conditioning - -
Set Target Temperature number (Celsius, e.g. 21.5) -
Start Window Heating - -
Stop Window Heating - -
Start Charging - -
Stop Charging - -
Set Charge Limit number (%, e.g. 80) -
Lock Vehicle - msg.spin (S-PIN)
Unlock Vehicle - msg.spin (S-PIN)
Honk and Flash - msg.latitude, msg.longitude
Wake Up Vehicle - -
Example input
  "payload": 22
Credits
  • Thanks to skodaconnect/myskoda for reverse-engineering the new MySkoda API
  • Thanks to Martin Gris for original inspiration
Disclaimer
This is an unofficial integration. The MySkoda API is not publicly documented and may change without notice. Use at your own risk.
Buy me a beer
Find it useful? Please consider buying me or other contributors a beer.
Buy Me A Beer
Version: 2.3.5
Updated 5 months, 3 weeks ago
  • myskoda-credentials
  • myskoda-get
  • myskoda-set
  • skoda
  • myskoda
  • connect
