node-red-contrib-myq 0.0.15
Node-Red node to control MyQ (Chamberlain) devices
npm install node-red-contrib-myq
Node-Red node to control MyQ (Chamberlain) devices. Based on awesome myq library.
Drop the myq device node to your flow. Provide your MyQ credentials (Username, Password and Region), set Serial number or Name (if both are set then Serial number will be used to identify the device) in properties. That's it.
Inputs
payload (optional) - string
Action to perform on device. If payload is null, empty or info then it will trigger retrieval of status information. Any other payload will be sent as is to the API (for example, there are actions for doors open and close, for lights on and off, for lamps lamp_on and lamp_off).
Outputs
  • Status output
payload - object
Returns extended status information about device in payload
  • Action output
payload - boolean
Confirmation of successful action execution
  • Standard error
payload - string
The standard error of the command
Version: 0.0.15
Updated 3 years, 4 months ago
Rating: 5.0 2
21 in the last week
  • myq-device-node
  • myq-credentials
  • myq
  • chamberlain
  • liftmaster
