node-red-contrib-myhome-bticino 0.2.2
Collection of nodes for the BTicino MyHome system using OpenWebNet.
npm install node-red-contrib-myhome-bticino
Control Bticino MyHome™ components from NodeRED.
Intro
node-red-contrib-myhome-bticino is a Node-RED nodes pack to interact with Bticino MyHome™ devices with OpenWebNet protocol through a supported gateway (in my case I use unexpensive MH201 Gateway). Based on unpublished (into NPM repository, but it's on GitHub) work of Ralph Vigne: https://github.com/vigne/node-red-bticino-myhome
Bug & Fix
On november 2020 I developed the password (and no password) management (versions > 0.2.1)
Nodes that are now working
  • Switches -- ON/OFF
  • Covers -- UP/DOWN/STOP
  • Event Session -- Listen for any message on the bus and sends it as payload
  • Command Session -- Send arbitray message provided in payload to bus. E.g. *1*1*16## to turn on light 16
Node not tested but probably it works (test it!)
  • Lights -- ON/OFF
    • Dimming (providing a fixed percentage)
Improvement and changes from original sources
  • Gateway's password management that is usually set to 12345
  • Two outputs on node
    1. default 'payload' output with 'ON' / 'OFF' value
    2. boolean 'payload.On' output to manage the state in homekit-bridge node
Installation & Usage
Easy Install
If you have Node-RED already installed the recommended install method is to use the editor. To do this, select Manage Pallette from the Node-RED menu (top right), and then select install tab in the pallette. Search for and install this node (node-red-contrib-myhome-bticino).
Using NPM
If you have not yet installed Node-RED then run following command or go to Node-RED Installation Guide.
    npm install -g --unsafe-perm node-red
Next, to install node-red-contrib-myhome-biticino node run the following command in your Node-RED user directory - typically ~/.node-red
First touch
In order to easy starting to test the nodes copy this flow in Node-RED selecting Import in the menu.
[{"id":"ab97f24d.b82ae","type":"inject","z":"e389524d.5c9b","name":"","topic":"cmd/switch","payload":"ON","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":180,"y":100,"wires":[["eb9f8904.d99788"]]},{"id":"c26ad40e.e21b48","type":"inject","z":"e389524d.5c9b","name":"","topic":"cmd/switch","payload":"OFF","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":180,"y":140,"wires":[["eb9f8904.d99788"]]},{"id":"eb9f8904.d99788","type":"myhome-switch","z":"e389524d.5c9b","switchid":"16","topic":"switch","gateway":"85cc3f4e.d14b8","name":"LightTest","x":400,"y":120,"wires":[["548fd2fb.a0a68c"],[]]},{"id":"548fd2fb.a0a68c","type":"debug","z":"e389524d.5c9b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":630,"y":80,"wires":[]},{"id":"85cc3f4e.d14b8","type":"myhome-gateway","z":"","name":"MH201","host":"192.168.1.44","port":"20000","pass":"12345","timeout":"60"}]
After that you have to change the IP address in the Gateway configuration and of course the light number in switch node.
Usage of Switch Node
Put Switch node on your flow and set the switch number inside it. Configure your Gateway if not configured yet. Test the Switch injecting payload string message 'ON' (or 'OFF') and setting Topic property as 'cmd/topic' where topic is the Switch Topic.
Tips
How to discover device
  1. Put myhome-eventsession Node connect to a Debug Node on your flow
  2. Deploy the project and open Debug messages window
  3. Click on the switch that you want to know the number
  4. Watch at debug window to see the right message generated
Remeber that the message will be as *1*1*xx## if on or *1*0*xx## if off, where xx is the number of the switch you are trying to discover
Bticino Gateway & OpenWebNet
Bicino is using a proprietary protocol (SCS) to comunicate from/to the devices in MyHome network system. There are a many gateways able to convert SCS protocol to OpenWebNet protocol that is well documented (follow this link for more details) and quit easy to use. I suggest to buy MH201 Gateway that is for hotel room management and it's cheap.
Contact me
mail to Fabio
Version: 0.2.2
Updated 6 years, 6 months ago
12 in the last week
  • myhome-gateway
  • myhome-eventsession
  • myhome-commandsession
  • myhome-light
  • myhome-switch
  • myhome-cover
  • BTicino
  • MyHome
  • OpenWebNet
  • SCS
