node-red-contrib-multi-stat 1.0.1
Node-RED multi-source statistics - calculates min/max/avg across multiple topics
npm install node-red-contrib-multi-stat
Node-RED Multi-Source Statistics - calculates Min/Max/Avg across multiple topics.
  • Aggregates values from multiple sources (topics)
  • Calculates Min/Max/Avg in real-time
  • Configurable decimal places
  • Minimum topic count before first output
  • Reset and remove via msg
Behavior
  • Each source is identified by msg.topic
  • Stores only the latest value per topic (no history)
  • On each input: update value → recalculate statistics → output
Example
Input: topic="room1", payload=21.5
Input: topic="room2", payload=19.8
Input: topic="room3", payload=23.1
Output:
  min: 19.8,
  max: 23.1,
  avg: 21.47,
  count: 3,
  values: { room1: 21.5, room2: 19.8, room3: 23.1 }
Property Description Default
Decimals Decimal places for min/max/avg 2
Min. Topics Minimum topics before first output 1
Input
  • msg.payload - Numeric value
  • msg.topic - Required - Unique source ID
Runtime Overrides
msg.reset true = clear all values
msg.remove true = remove this topic
Output
  "min": 19.8,
  "max": 23.1,
  "avg": 21.47,
  "count": 3,
  "values": { "room1": 21.5, "room2": 19.8, "room3": 23.1 }
Use Cases
Application Description
Room temperatures Min/Max/Avg across all rooms
Sensor network Aggregated readings
Load balancing Min/Max across multiple servers
Node Status
  • Idle - Waiting for data
  • Waiting (1/3 Topics) - minTopics not yet reached
  • 3 Topics | Min 19.8 Max 23.1 Avg 21.5 - Active statistics
Author
sr.rpo
MIT
Version: 1.0.1
Updated 7 months, 3 weeks ago
133 in the last week
  • multi-stat
  • statistics
  • min
  • max
  • average
  • multi
  • aggregate
