node-red-contrib-mtconnect-mqtt-data-logger 0.0.1
A Node-RED node designed for taking data from MTConnect MQTT Agents and creating payload that is given as input to INfluxDB node
npm install node-red-contrib-mtconnect-mqtt-data-logger
A Node-RED node designed for processing and formatting data from MTConnect MQTT Agents. This node parses the incoming MQTT message and transforms it into a {MQTT Topic: Value} format, suitable for input to the InfluxDB node. Once stored in InfluxDB, users can visualize the parameter data using Grafana.
  1. Connect the output of your MQTT node (configured for the MTConnect MQTT Agent) to the input of the MTConnectMQTTAgent_DataLogger node.
  2. Connect the output of the MTConnectMQTTAgent_DataLogger node to the input of the InfluxDB node.
  3. Store and visualize the data in Grafana.
Grafana Dashboard
You can find a pre-configured Grafana dashboard JSON in this repository. Import this JSON to your Grafana instance for a ready-to-use dashboard tailored for this data.
  • Parse MTConnect MQTT Agent data.
  • Convert data to {MQTT Topic: Value} format. This node will create seperate measurements for every MQTT Topic.
  • Seamless integration with InfluxDB and Grafana.
Issues & Feedback
If you encounter any issues or would like to provide feedback, please open an issue here.
Author
Harshad Joshi (github.com/hj91)
This project is licensed under the GPL-3.0 License. See the LICENSE file for details.
Important Note
This node is in experimental stage - while it can log data correctly - certain things can get changed in next versions as per user feedback. All trademarks are acknowledged as property of their repective owners.
Version: 0.0.1
Updated 3 years, 4 months ago
License: GPL-3.0
Rating: 5.0 3
1 in the last week
  • MTConnectMQTTAgent_DataLogger
  • MTConnect
  • MQTT
  • Agent
  • Data
  • Logger
  • CNC
  • Industrial Machine
