node-red-contrib-mssql-plus-box 0.1.4
Node for node-red to connect to a Microsoft MS SQL Database
npm install node-red-contrib-mssql-plus-box
A Node-RED node for connecting to Microsoft MS SQL Databases.
Importantly, this package comes with pre-built linux drivers for communicating with the Azure & MS SQL services (using TDS protocal), removing the need to set-up environment level MSSQL (or similar) drivers.
Added disconnect of database on each message input
Easiest
Use the Manage Palette > Install option from the menu inside node-red
Harder
Alternatively in your Node-RED user directory, typically ~/.node-red, run
This node based on node-red-contrib-mssql-plus. Thanks to Redconnect.io.
Version: 0.1.4
Updated 7 years, 11 months ago
20 in the last week
  • MSSQL-CN
  • MSSQL
  • odbc
  • unixodbc
  • mssql
  • sql
  • Microsoft
  • database
