node-red-contrib-mssql-plus 0.13.1
A node-red node to execute queries, stored procedures and bulk inserts in Microsoft SQL Server and Azure Databases SQL2000 ~ SQL2022
npm install node-red-contrib-mssql-plus
A Node-RED node to execute queries, stored procedures and bulk inserts in Microsoft SQL Server and Azure Databases SQL2000 ~ SQL2022.
Importantly, this package comes with pre-built linux drivers for communicating with the Azure & MS SQL services (using TDS protocol), removing the need to set-up environment level MSSQL (or similar) drivers.
Screen shot
Features include...
  • Connect to multiple SQL Servers and Azure databases from SQL2000 ~ 2022
  • Perform multiple queries in one go & get back multiple recordsets (depends on the queries sent)
  • Supports Stored Procedure execute
  • Supports Bulk Insert
  • Built in examples (node-red hamburger menu → import → examples → node-red-contrib-mssql-plus)
    • TVP - A demo of calling a stored procedure and passing in a table valued parameters
    • BULK - A demo of inserting a large amount of data in bulk mode
  • Use env vars in the config node for all fields (including credentials). e.g...
    • Server {{{SQL_IP}}}
    • Password {{{SQL_PW}}}
  • Use mustache in your SQL queries including msg, flow and global context. e.g...
    • SELECT TOP {{{payload.maxRows}}} * FROM [MyTable] WHERE Name = '{{{flow.name}}}' AND quantity <= {{{global.maxQty}}}
    • View the final query (mustache rendered into values) in msg.query to understanding what happened to your {{{mustache}}} parameters
  • Enter parameters in the UI or send parameters in via msg, flow or global variables for use in your SQL queries e.g...
    • SELECT * FROM [MyTable] WHERE Name = @name AND quantity <= @maxQty
    • View the final parameters (rendered with final values) in msg.queryParams that were used in the query to aid debugging
    • View output parameters values in msg.queryParams after the query has executed
  • Choose between throwing an error to the catch node or outputting an error property in msg.error
  • Additional properties are in the msg object (use a debug node with "complete msg object" set to see whats available)
Easiest
Use the Manage Palette > Install option from the menu inside node-red
Harder
Alternatively in your Node-RED user directory, typically ~/.node-red, run
Please refer to the built in help in the info panel in node red.
Sample flow
Demonstrating mustache rendering, input parameters, mutliple queries, print info...
  • Payload: {"count": 5, "age": 35}
  • Parameters
    • name, varchar(20), stephen
    • age, int, msg.payload.age
  • Query:
      PRINT @name
      SELECT TOP {{{payload.count}}} *
      FROM testdb.dbo.[MyTable] WHERE Name = @name
      FROM testdb.dbo.[MyTable] WHERE Age = @age
      PRINT 'complete'
  • After Rendering Mustache:
      PRINT @name
      SELECT TOP 5 *
      SELECT TOP 5 *
      PRINT 'complete'
flow...
[{"id":"61625aaf.479d84","type":"inject","z":"595a5dd5.a963a4","name":"{\"count\": 5, \"age\": 35}","topic":"","payload":"{\"count\": 5, \"age\": 35}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":220,"y":320,"wires":[["6e09980a.127878"]]},{"id":"6e09980a.127878","type":"MSSQL","z":"595a5dd5.a963a4","mssqlCN":"a51e405c.10f64","name":"","outField":"payload","returnType":"1","throwErrors":"0","query":"PRINT @name\n\nSELECT TOP {{{payload.count}}} * \nFROM testdb.dbo.[MyTable] WHERE Name = @name\n\nSELECT TOP {{{payload.count}}} * \nFROM testdb.dbo.[MyTable] WHERE Age = @age\n\nPRINT 'complete'","modeOpt":"","modeOptType":"query","queryOpt":"","queryOptType":"editor","paramsOpt":"","paramsOptType":"editor","params":[{"output":false,"name":"name","type":"VarChar(20)","valueType":"str","value":"stephen"},{"output":false,"name":"age","type":"int","valueType":"msg","value":"payload.age"}],"x":260,"y":380,"wires":[["babb6d0.5ae7e9"]]},{"id":"babb6d0.5ae7e9","type":"debug","z":"595a5dd5.a963a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":270,"y":440,"wires":[]},{"id":"a51e405c.10f64","type":"MSSQL-CN","z":"","tdsVersion":"7_4","name":"My SQL Server","server":"192.168.1.38","port":"1433","encyption":false,"database":"testdb","useUTC":false,"connectTimeout":"15000","requestTimeout":"15000","cancelTimeout":"5000","pool":"5","parseJSON":false}]
This node based on node-red-contrib-mssql.
Thanks to Redconnect.io.
Version: 0.13.1
Updated 1 year, 7 months ago
Rating: 4.6 13
5296 in the last week
  • MSSQL-CN
  • MSSQL
  • odbc
  • unixodbc
  • mssql
  • sql
  • Microsoft
  • database
  • sql-server
  • azure
  • Shao Yu-Lung
  • Olli Kasari
  • Steve McLaughlin
