node-red-contrib-msg-repeater 1.0.8
A Node-RED node that can capture and repeat messages
npm install node-red-contrib-msg-repeater
A Node-RED node that can capture and repeat messages.
  • Capture any message flowing through the node
  • Replay the captured message on demand without clearing it from memory
  • Visual status indicator showing capture state
  • Button on the node to trigger message replay
  • Button in the configuration panel to trigger capture mode
Local Installation
npm install /path/to/node-red-contrib-msg-repeater
From NPM (Once Published)
The node has two modes of operation:
  1. Normal mode: All regular messages pass through unchanged.
  2. Capture mode: When a message with msg.capture = true is received, the node enters capture mode. The next message will be stored for later replay and also passed through unchanged.
Control messages:
  • Messages with msg.capture = true put the node in capture mode but do not pass through
  • Messages with msg.repeat = true trigger replay of the stored message but do not pass through
The captured message remains in memory until a new message is captured (by entering capture mode again).
UI Buttons
  • The main button on the node triggers a replay of the captured message
  • The "Capture" button in the configuration panel triggers capture mode
Status Indicators
  • No status: Normal mode, no message captured
  • Blue dot "Capturing": Node is in capture mode, waiting for next message
  • Green dot "Captured": A message has been captured and is available for replay
Example Flow
        "id": "425c2ffc692b6f08",
        "type": "msg-repeater",
        "z": "f6f2187d.f17ca8",
        "x": 530,
        "y": 580,
                "c4daf6e907b0b923"
        "id": "e402feb314f26bb1",
        "type": "inject",
        "name": "Capture",
        "props": [
                "p": "capture",
                "v": "true",
                "vt": "bool"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 350,
        "y": 540,
                "425c2ffc692b6f08"
        "id": "f73f2541e25985fb",
        "type": "inject",
        "name": "Test Message",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
                "p": "timestamp",
                "v": "",
                "vt": "date"
                "p": "jsonPayload",
                "v": "{\"key1\":\"value1\", \"list\": [\"first\", \"second\"]}",
                "vt": "json"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Great day to be alive",
        "payload": "Hello World",
        "payloadType": "str",
        "x": 330,
        "y": 580,
                "425c2ffc692b6f08"
        "id": "f6423e902816d493",
        "type": "inject",
        "name": "Repeat",
        "props": [
                "p": "repeat",
                "v": "true",
                "vt": "bool"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 350,
        "y": 620,
                "425c2ffc692b6f08"
        "id": "c4daf6e907b0b923",
        "type": "debug",
        "name": "Output",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 690,
        "y": 580,
        "id": "666071d5abaca966",
        "type": "comment",
        "name": "Start Capture",
        "info": "",
        "x": 530,
        "y": 540,
MIT
Version: 1.0.8
Updated 11 months, 2 weeks ago
Rating: 5.0 2
95 in the last week
  • msg-repeater
  • message
  • repeater
  • capture
