node-red-contrib-msal 0.0.2
Login node using msal
npm install node-red-contrib-msal
Node RED node to authenticate using MSAL.
Mainly based on Azure docs and samples
Installation via the Web-Interface
  1. Open the menu in the upper right corner
  2. Choose Manage Palette
  3. Under Install, search for: node-red-contrib-msal
Installation via the command line
  1. Navigate to your Node RED user directory, usally $HOME/.node-red
  2. Run the following command:
Prerequisites
Already registered App on Azure Portal.
This node is using Redirect Method of msal
Enter:
  • Scopes : e.g. user.read or https://management.azure.com/.default...
  • Init URL : Url that will lead to Azure Login: /login2azure
  • Local Redirect URL : RedirectUrl that will listen on Azure Login Response: /redirect
    Note: On Azure Portal you have to add the complete REDIRECT URL !!!
    Running NR on http://localhost:1880 then you have to add http://localhost:1880/redirect for your app in Azure Portal !
    This node will patch up the complete REDIRECT URL on its own and pass it to msal!
Node can receive msg.update = true object to do a silent renewal of token.
Node will send msal processed response object. The included accessToken can be use to trigger http node to do REST call on Azure API
Config Node
  • Application (client) ID
  • Application (client) Secret
  • Authority (https://login.microsoftonline.com/<tenantId> or https://login.microsoftonline.com/common ...)
Version: 0.0.2
Updated 4 years, 8 months ago
2 in the last week
  • msal-auth
  • msal-config
  • msal
  • azure
