node-red-contrib-mrsmart-ihost-fcu 0.3.7
Mr Smart iHost FCU controller for TYBAC-006 via Zigbee2MQTT, with native eWeLink CUBE Web and CAST custom UI support for SONOFF iHost
npm install node-red-contrib-mrsmart-ihost-fcu
Mr Smart FCU integration for SONOFF iHost / Node-RED, designed for the Tuya TYBAC-006 fan-coil thermostat (_TZE204_mpbki2zm) through Zigbee2MQTT.
  • Native Node-RED node for iHost
  • Zigbee2MQTT device auto-discovery
  • FCU temperature, setpoint, operating mode and fan-speed control
  • Bidirectional state synchronization
  • eWeLink CUBE Web custom UI registration
  • CUBE CAST custom UI registration
  • Installer-supplied iHost address and MQTT port; no site-specific IP or MQTT port is pre-filled
Install the package from Node-RED Manage palette, or install the packaged .tgz file for local testing.
The installer must configure the iHost connection and the MQTT broker port used by the iHost Mosquitto container. The MQTT host can be left blank to use the configured iHost address.
Supported thermostat
Initial validated target: TYBAC-006 / Tuya TS0601, manufacturer fingerprint _TZE204_mpbki2zm.
MIT
Version: 0.3.7
Updated 1 month, 3 weeks ago
  • mrsmart-ihost-fcu-config
  • mrsmart-ihost-fcu
  • sonoff
  • ihost
  • zigbee2mqtt
  • fcu
  • thermostat
  • mrsmart
