node-red-contrib-mqtt-tdengine 1.0.3
A Node-RED node for writing MQTT data to TDengine database with batch insert support and enhanced error handling
npm install node-red-contrib-mqtt-tdengine
Node-RED MQTT to TDengine
A Node-RED custom node for writing MQTT message data to TDengine time-series database. Uses the official TDengine WebSocket connector for efficient data transmission with batch insert support.
  • ๐Ÿ”„ MQTT Subscription: Subscribe to MQTT topics and receive real-time data
  • ๐Ÿš€ TDengine Integration: Uses official @tdengine/websocket connector, supports local and cloud TDengine
  • โšก Batch Insert: High-performance batch insert mode with configurable batch size and timeout
  • ๐ŸŽฏ Smart Variable Replacement: Supports JSON field extraction from MQTT payloads
  • โš™๏ธ Flexible Configuration: Custom SQL templates with variable substitution
  • ๐Ÿ“Š Real-time Status: Connection status and data processing results display
  • ๐Ÿ›ก๏ธ Enhanced Error Handling: Comprehensive error handling with retry mechanisms and fallback strategies
Method 1: Install via Node-RED Palette Manager
  1. Open Node-RED management interface
  2. Click the menu in the top right corner โ†’ Manage palette
  3. Select the "Install" tab
  4. Search for node-red-contrib-mqtt-tdengine
  5. Click Install
Method 2: Install via npm
MQTT Configuration
  • MQTT Server: MQTT broker server address, e.g., mqtt://localhost:1883
  • Topic: MQTT topic to subscribe to, e.g., sensor/temperature
  • QoS: Message quality level (0, 1, 2)
TDengine Configuration
  • WebSocket URL: TDengine WebSocket connection address
    • Local deployment: ws://localhost:6041
    • TDengine Cloud: wss://your-instance.cloud.tdengine.com
  • Database: TDengine database name
  • Table: Target data table name
Batch Insert Configuration
  • Enable Batch: Toggle batch insert mode for better performance
  • Batch Size: Number of records to batch together (1-1000, default: 10)
  • Batch Timeout: Maximum time to wait before executing batch (1-60 seconds, default: 1)
SQL Template Configuration
SQL templates support the following variable substitutions:
  • ${payload}: Complete MQTT message content
  • ${topic}: MQTT topic
  • ${table}: Configured table name
  • ${database}: Configured database name
  • ${fieldname}: JSON field values from payload (e.g., ${co2}, ${pm25})
Example Templates:
Single insert mode:
INSERT INTO ${table} (createtime, co2, pm25) VALUES (NOW, ${co2}, ${pm25})
For JSON payload like: {"co2": 400, "pm25": 35}
Usage Examples
1. Basic Configuration
  1. Drag the mqtt-tdengine node to the workspace
  2. Double-click the node to configure:
    • MQTT Server: mqtt://localhost:1883
    • Topic: sensor/data
    • TDengine WebSocket URL: ws://localhost:6041
    • Database: iot_data
    • Table: air_sensor_001
    • SQL Template: INSERT INTO ${table} (createtime, co2, pm25) VALUES (NOW, ${co2}, ${pm25})
2. Batch Insert Mode
Enable batch insert for high-throughput scenarios:
  • Enable Batch: โœ“
  • Batch Size: 100
  • Batch Timeout: 5 seconds
This will collect up to 100 records or wait 5 seconds before executing a batch insert.
3. Performance Comparison
Based on testing:
  • Single Insert: ~100 records/second
  • Batch Insert: ~14,700 records/second (147x improvement)
  • Batch Processing: 1000 records in 68ms
TDengine Table Structure Example
-- Create database
CREATE DATABASE IF NOT EXISTS iot_data;
-- Use database
USE iot_data;
-- Create table for air sensor data
CREATE TABLE IF NOT EXISTS air_sensor_001 (
    createtime TIMESTAMP,
    co2 INT,
    pm25 INT
-- Create super table for multiple sensors
CREATE STABLE IF NOT EXISTS air_sensors (
    co2 INT,
    pm25 INT,
    temperature FLOAT,
    humidity FLOAT
) TAGS (
    device_id NCHAR(32),
    location NCHAR(64)
Output Message Format
The node outputs messages containing execution results:
Success (Single Insert)
  "payload": {
    "success": true,
    "message": "ๆ•ฐๆฎๆ’ๅ…ฅๆˆๅŠŸ",
    "sql": "INSERT INTO air_sensor_001 (createtime, co2, pm25) VALUES (NOW, 400, 35)",
    "result": {...},
    "originalTopic": "sensor/air",
    "originalPayload": "{\"co2\": 400, \"pm25\": 35}"
Success (Batch Insert)
  "payload": {
    "success": true,
    "message": "ๆ‰น้‡ๆ’ๅ…ฅๆˆๅŠŸ: 100 ๆกๆ•ฐๆฎ",
    "table": "air_sensor_001",
    "count": 100,
    "result": {...}
Error
  "payload": {
    "success": false,
    "error": "TDengineๆ‰ง่กŒๅคฑ่ดฅ: Invalid SQL",
    "sql": "INSERT INTO air_sensor_001 VALUES (NOW, 400, 35)",
Troubleshooting
Common Issues
  1. MQTT Connection Failed
    • Check MQTT server address and port
    • Verify network connectivity
    • Check firewall settings
  2. TDengine Connection Failed
    • Ensure TDengine service is running
    • Check WebSocket port (default 6041)
    • Verify username and password
  3. SQL Execution Failed
    • Check if database and table exist
    • Verify SQL syntax correctness
    • Ensure data type matching
  4. Variable Replacement Issues
    • Ensure MQTT payload is valid JSON for field extraction
    • Check variable names match JSON field names exactly
    • Use debug node to inspect actual payload content
Debugging Methods
  1. Check Node-RED debug panel log output
  2. Monitor node status indicators
  3. Test SQL statements directly with TDengine client
  4. Use the included test scripts to verify functionality
Dependencies
  • Node.js: >= 14.0.0
  • Node-RED: >= 2.0.0
  • @tdengine/websocket: ^3.1.0
  • mqtt: ^4.3.7
  • axios: ^1.12.2
MIT License
Contributing
Issues and Pull Requests are welcome to improve this project.
Changelog
v1.0.0
  • ๐ŸŽ‰ Initial release
  • ๐Ÿ“ก MQTT subscription and TDengine integration
  • โšก Batch insert support with configurable parameters
  • ๐ŸŽฏ Smart JSON field variable replacement
  • ๐Ÿ›ก๏ธ Enhanced error handling and retry mechanisms
  • ๐Ÿ”„ Automatic connection management and recovery
  • ๐Ÿ“Š Real-time status monitoring
  • ๐Ÿงช Comprehensive test coverage
Version: 1.0.3
Updated 1 year, 1 month ago
4 in the last week
  • mqtt-tdengine
  • tdengine-config
  • mqtt-broker-config
  • mqtt
  • tdengine
  • iot
  • timeseries
  • database
  • batch-insert
  • websocket
  • time-series
