node-red-contrib-mqtt-gem 1.0.0
MQTT nodes with environment variables support for dynamic enable and parameters
npm install node-red-contrib-mqtt-gem
npm version Node-RED
Add little features to Standard MQTT nodes for Node-RED using environment variables support and dynamic configuration capabilities.
Library extension developed by GEM srl - Sant'Agata sul Santerno (RA), Italy derived from Original Node-red core library
Params
๐Ÿš€ Features
node-red-contrib-mqtt-gem extends the standard Node-RED MQTT nodes with powerful dynamic configuration capabilities:
โœ… Dynamic Broker Control
  • Enable/Disable connections dynamically via environment variable (use "Auto connect" to enable/disable)
  • Automatic connection management based on runtime configuration
  • Visual status indicators (disabled nodes show "disabled" in gray)
๐ŸŒ Environment Variables Support
  • Port Configuration: Use any environment variable for port numbers
  • Auto-Connect Control: Dynamic connection behavior via custom variable names
  • TLS Configuration: Runtime TLS enablement via any environment variable
  • Protocol Version: Support for custom MQTT protocol versions (3.1, 3.1.1, 5.0)
  • Complete Broker Settings: All broker parameters can be configured via any environment variable names
๐Ÿ”ง Enhanced Protocol Support
  • MQTT v3.1 (legacy)
  • MQTT v3.1.1 (standard)
  • MQTT v5.0 (latest)
  • Custom Protocol Selection: Text input for environment variable-based protocol selection
๐ŸŽฏ Smart Node Behavior
  • Disabled brokers prevent IN/OUT nodes from processing messages
  • Visual feedback with status indicators
  • Seamless integration with existing Node-RED flows
  • No conflicts with core MQTT nodes
๐Ÿ“ฆ Installation
Via Node-RED Palette Manager (Recommended)
  1. Open Node-RED editor
  2. Go to Menu โ†’ Manage palette
  3. Select Install tab
  4. Search for node-red-contrib-mqtt-gem
  5. Click Install
Via npm
Manual Installation
๐Ÿ”ง Configuration
Environment Variables Setup
launch.json
You can use ANY variable names you prefer. The examples below use common naming conventions:
# Example with standard names
export MQTT_HOST="broker.example.com"
export MQTT_PORT="1883"
export MQTT_AUTOCONNECT="true"
export MQTT_USETLS="false"
export MQTT_PROTOCOL="5"
# Example with custom names
export MY_BROKER_ADDRESS="broker.example.com"
export MY_BROKER_PORT="1883"
export ENABLE_MQTT="true"
export USE_SSL="false"
export MQTT_VERSION="5"
# Example with company-specific names
export COMPANY_MQTT_SERVER="internal.company.com"
export PRODUCTION_MQTT_PORT="8883"
export MQTT_CONNECTION_ENABLED="true"
# Start Node-RED
node-red
Docker Configuration
# Dockerfile
FROM nodered/node-red:latest
# Install the plugin
RUN npm install node-red-contrib-mqtt-gem
# Set environment variables (use any names you prefer)
ENV MY_MQTT_HOST=broker.example.com
ENV MY_MQTT_PORT=1883
ENV MQTT_ENABLED=true
ENV USE_TLS=false
ENV PROTOCOL_VERSION=5
Docker Compose
version: '3.8'
services:
  node-red:
    image: nodered/node-red:latest
    ports:
      - "1880:1880"
    environment:
      - MY_MQTT_HOST=broker.example.com
      - MY_MQTT_PORT=1883
      - MQTT_ENABLED=true
      - USE_TLS=false
      - PROTOCOL_VERSION=5
    volumes:
      - node-red-data:/data
    command: >
      bash -c "npm install node-red-contrib-mqtt-gem &&
               npm start -- --userDir /data"
volumes:
  node-red-data:
๐ŸŽฎ Usage Examples
Basic Broker Configuration
Static Configuration:
Server: broker.example.com
Port: 1883
Auto Connect: true
Use TLS: false
Protocol: MQTT V3.1.1
Dynamic Configuration with Environment Variables (use any variable names):
Server: ${MY_BROKER_HOST}
Port: ${MY_BROKER_PORT}
Auto Connect: ${MQTT_ENABLED}
Use TLS: ${USE_SSL_CONNECTION}
Protocol: Custom โ†’ ${MQTT_VERSION}
Conditional MQTT Publishing
// In a Function node before mqtt-gem out
if (env.get("MY_MQTT_ENABLED") === "true") {
    return msg; // Send message
} else {
    return null; // Block message
Multi-Environment Setup
# Development Environment
export DEV_MQTT_HOST="dev-broker.internal"
export DEV_MQTT_PORT="1883"
export DEV_MQTT_ENABLED="true"
# Production Environment
export PROD_MQTT_HOST="prod-broker.company.com"
export PROD_MQTT_PORT="8883"
export PROD_MQTT_ENABLED="true"
export PROD_USE_TLS="true"
# Staging Environment
export STAGING_BROKER="staging.company.com"
export STAGING_PORT="1883"
export STAGING_CONNECTION="false"  # Disabled in staging
Protocol Version Examples
# MQTT v3.1 (legacy)
export MY_PROTOCOL="3"
# MQTT v3.1.1 (standard)
export BROKER_PROTOCOL="4"
# MQTT v5.0 (latest)
๐Ÿ“‹ Node Types
mqtt-gem-broker (Configuration Node)
Enhanced broker configuration with environment variable support for all parameters.
mqtt-gem in (Input Node)
MQTT subscriber with dynamic broker configuration. Shows "disabled" status when broker is disabled.
mqtt-gem out (Output Node)
MQTT publisher with dynamic broker configuration. Blocks messages when broker is disabled.
๐Ÿ” Environment Variables Reference
Important: You can use any variable names you prefer. The table below shows common examples, but you have complete freedom in naming:
Example Variable Description Default Example Values
MY_MQTT_HOST Broker hostname/IP localhost broker.example.com
BROKER_PORT Broker port 1883 1883, 8883
MQTT_ENABLED Auto-connect on startup (enable/disable connection and nodes) true true, false
USE_SSL Enable TLS/SSL false true, false
PROTOCOL_VERSION MQTT protocol version 4 3, 4, 5
Configuration Examples:
# Company-specific naming
export COMPANY_MQTT_BROKER="internal.company.com"
export COMPANY_MQTT_PORT="1883"
# Project-specific naming
export PROJECT_A_BROKER="project-a.broker.com"
export PROJECT_A_ENABLED="true"
# Environment-specific naming
export PROD_MQTT_HOST="prod-broker.com"
export DEV_MQTT_HOST="dev-broker.com"
๐Ÿงช Testing
Test Flow Example
  1. Create test brokers:
    • Active broker with MY_MQTT_ENABLED=true
    • Disabled broker with MQTT_CONNECTION=false
  2. Add MQTT nodes:
    • Input nodes for both brokers
    • Output nodes for both brokers
  3. Verify behavior:
    • Active broker: nodes work normally
    • Disabled broker: nodes show "disabled" status and don't process messages
Environment Variables Test
# Set test variables (use any names you prefer)
export TEST_MQTT_HOST="test.mosquitto.org"
export TEST_MQTT_PORT="1883"
export TEST_CONNECTION_ENABLED="true"
export TEST_PROTOCOL_VERSION="5"
# Start Node-RED and verify configuration
node-red
๐Ÿ”ง Development
Local Development Setup
# Clone repository
git clone https://github.com/lucagem/node-red-contrib-mqtt-gem.git
cd node-red-contrib-mqtt-gem
# Install dependencies
npm install
# Setup development environment
npm run dev-setup
# Start development Node-RED instance
npm run dev
Development Commands
# Start development server
npm run dev
# Debug mode
npm run dev-debug
# Run tests (when available)
npm test
๐Ÿ“ Migration from Standard MQTT Nodes
  1. Replace node types in your flows:
    • mqtt in โ†’ mqtt-gem in
    • mqtt out โ†’ mqtt-gem out
    • mqtt-broker โ†’ mqtt-gem-broker
  2. Update broker configurations to use environment variables:
    • Replace static values with ${VARIABLE_NAME}
    • Set corresponding environment variables
  3. Deploy and test the updated flow
โ“ Troubleshooting
Common Issues
Q: Nodes show "disabled" status
A: Check that your auto-connect variable (e.g., MY_MQTT_ENABLED) is set to "true" (as string)
Q: Environment variables not resolving
A: Ensure variables are set before starting Node-RED and use correct syntax: ${YOUR_VARIABLE_NAME}
Q: Protocol version not working
A: For custom protocols, select "Custom..." in dropdown and enter ${YOUR_PROTOCOL_VAR} in text field
Q: TLS connection failing
A: Verify your TLS variable (e.g., USE_TLS="true") and correct port (usually 8883 for TLS)
Debug Mode
Enable Node-RED debug logging:
DEBUG=mqtt-gem* node-red
๐Ÿค Contributing
Contributions are welcome! Please:
  1. Fork the repository
  2. Create a feature branch
  3. Make your changes
  4. Add tests if applicable
  5. Submit a pull request
๐Ÿ“„ License
MIT License - see LICENSE file for details.
๐Ÿ”— Links
๐Ÿ“Š Compatibility
  • Node-RED: >= 2.0.0
  • Node.js: >= 14.0.0
  • MQTT: Versions 3.1, 3.1.1, 5.0
Developed by GEM srl - Sant'Agata sul Santerno (RA), Italy
Author: Luca Tralli
Version: 1.0.0
Updated 1 year, 2 months ago
367 in the last week
  • mqtt-gem-broker
  • mqtt-gem in
  • mqtt-gem out
  • mqtt
  • environment
  • variables
  • dynamic
  • configuration
  • gem
  • broker
  • tls
  • protocol
