node-red-contrib-mqtt-dynamictopic 1.0.2
Default MQTT in node, but with msg.topic support.
npm install node-red-contrib-mqtt-dynamictopic
This is a node module for node-red that is identical to the default MQTT node. The difference with the MQTT node is that this dynamic node supports topics/channels passed through msg.topic.
Installing
Simply install using the palette in node-red.
Creds
I have used node-red-contrib-mqtt-env as a raw base for this node. Thank you.
Version
This is a fork of node-red-contrib-mqtt-dynamictopic => correct multi subscriptions usage and unsubscriptions.
Version: 1.0.2
Updated 7 years, 5 months ago
Rating: 1.0 3
17 in the last week
  • mqtt-dynamic in
  • mqtt-dynamic-broker
