node-red-contrib-mqrest-client 0.2.0
MQ REST Clients
npm install node-red-contrib-mqrest-client
These nodes provides Node-RED messaging clients making use of the MQ REST messaging API.
Use the manage palette option to install these nodes.
Fourteen nodes are provided.
mqrest-channel
retrieves channel information
mqrest-installation
retrieves installation information
mqrest-login
can be used to log in, log out and query a user
mqrest-messaging
provides messaging functionality (put, get, pub)
mft-agent
retrieves MFT agent details
mft-monitor
performs MFT monitor operations
mft-transfer
retrieves details of, and creates transfers
mqrest-qmgr
retrieves details of queue managers
qmgr-mqsc
runs an MQSC command
mqrest-queue
creates, deletes, modifies and retrieves details of a queue
mqrest-sub
retrieves details of subscriptions
Use the configuration to enter user and server details. Once created the user and server details can be reused with other mqrest nodes.
In user:
username
is the username of a user with authentication to use the REST API
password
the password for this user
In server:
host
could be `localhost` if running MQ in a local docker image.
port
is typically 9443
Input
Each node expects parameters via a msg object (e.g. the message to place on a queue to be in msg.payload). See the configuration panel of a node to see its expected parameters.
Output
If a node can give an output, it will have a connector on the right. The output will almost always be the json string returned from MQ.
Contributing
For simple typos and fixes please just raise an issue pointing out our mistakes. If you need to raise a pull request please read our contribution guidelines before doing so.
Copyright and license
Copyright 2022 IBM Corp. under the Apache 2.0 license.
Example flows
Linking queue depth to a UI gauge
[{"id":"a341b09eb8c81942","type":"tab","label":"Flow 9","disabled":false,"info":"","env":[]},{"id":"7f7cae7a622b0f17","type":"ui_gauge","z":"a341b09eb8c81942","name":"","group":"68eb6cca3fbe9d5d","order":0,"width":0,"height":0,"gtype":"gage","title":"DEV.QUEUE.1 Queue Depth","label":"Messages","format":"{{msg.payload.currentDepth}}","min":0,"max":"5000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","className":"","x":820,"y":640,"wires":[]},{"id":"1198a593d53e0ff9","type":"mqrest-queue","z":"a341b09eb8c81942","name":"","user":"8bb2a9c81bae9f00","server":"c813686f07868d8b","apiv":"v1","operation":"GET","x":390,"y":640,"wires":[["78cf75c68ef6505c"]]},{"id":"2ae88e3dd11cc21b","type":"inject","z":"a341b09eb8c81942","name":"","props":[{"p":"mqparams.qmgr","v":"QM1","vt":"str"},{"p":"mqparams.qname","v":"DEV.QUEUE.1","vt":"str"},{"p":"mqparams.status","v":"status.currentDepth","vt":"str"},{"p":"mqparams.attributes","v":"storage.maximumDepth","vt":"str"}],"repeat":"20","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":170,"y":640,"wires":[["1198a593d53e0ff9"]]},{"id":"78cf75c68ef6505c","type":"function","z":"a341b09eb8c81942","name":"","func":"msg.payload.currentDepth = msg.payload.queue[0].status.currentDepth;\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":640,"wires":[["7f7cae7a622b0f17"]]},{"id":"68eb6cca3fbe9d5d","type":"ui_group","name":"Default","tab":"440c82d8f94d11fb","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"8bb2a9c81bae9f00","type":"user-config","name":"ADMIN","username":"mqadmin","password":"mqadmin"},{"id":"c813686f07868d8b","type":"server-config","name":"","host":"localhost","port":"9443","allowSelfSigned":true},{"id":"440c82d8f94d11fb","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Sending QM status to twitter DM
[{"id":"c9634fa8db54069b","type":"tab","label":"Flow 11","disabled":false,"info":"","env":[]},{"id":"33966ca71ec197f6","type":"twitter out","z":"c9634fa8db54069b","twitter":"","name":"Tweet","x":690,"y":480,"wires":[]},{"id":"5fe8c2fa916dbbbb","type":"mqrest-qmgr","z":"c9634fa8db54069b","name":"","user":"8bb2a9c81bae9f00","server":"c813686f07868d8b","qmgr":null,"apiv":"v2","x":360,"y":480,"wires":[["9a30ad5ed87bef3c"]]},{"id":"d969950ceac03694","type":"inject","z":"c9634fa8db54069b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":480,"wires":[["5fe8c2fa916dbbbb"]]},{"id":"9a30ad5ed87bef3c","type":"function","z":"c9634fa8db54069b","name":"","func":"console.log(msg.payload)\nmsg.payload =D NodeREDTest10 Hello ${JSON.stringify(msg.payload)};\nnode.send(msg);","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":480,"wires":[["33966ca71ec197f6"]]},{"id":"8bb2a9c81bae9f00","type":"user-config","name":"ADMIN","username":"mqadmin","password":"mqadmin"},{"id":"c813686f07868d8b","type":"server-config","name":"","host":"localhost","port":"9443","allowSelfSigned":true}]
Version: 0.2.0
Updated 4 years, 7 months ago
9 in the last week
  • mqrest-messaging
  • mqrest-channel
  • mqrest-installation
  • user-config
  • mqrest-login
  • server-config
  • mft-agent
  • mft-transfer
  • mft-monitor
  • mqrest-qmgr
  • qmgr-mqsc
  • mqrest-queue
  • mqrest-sub
  • mqi
  • mq
  • Soheel Chughtai
  • Hayden Banes
