node-red-contrib-monogoto-operator 0.9.2
Allows communicating with the Monogoto Operator API from node-red.
npm install node-red-contrib-monogoto-operator
Monogoto Operator module for node-red
This assumes you have Node-RED already installed and working, if you need to install Node-RED see here
NOTE: This requires Node.js v8.11.1+ and Node-RED v0.19+.
Install via Node-RED Manage Palette
Install via npm
$ cd ~/.node-red
$ npm node-red-contrib-monogoto-operator
# Restart node-red
  • Drag the monogoto operator node from the Monogoto category of the node pallet, into your flow.
  • Double tap the node instance and configure your username & password via the server configuration config-node.
  • Choose the api & operation you would like to execute & fill in required parameters for the chosen API operation.
  • Note in case the API request ended with an error, it will be passed on to a Node-RED catch node.
Documentation
You may find documentation for each operation in the API by viewing the node info section in Node-RED
Version: 0.9.2
Updated 5 years, 8 months ago
5 in the last week
  • monogoto-operator
  • monogoto-operator-server
  • monogoto
  • operator
