node-red-contrib-mongodb4 3.4.0
A MongoDB node for Node-Red without limitations.
npm install node-red-contrib-mongodb4
A MongoDB driver node for Node-RED that exposes the native MongoDB Node.js driver features without limitations.
npm version install size npm downloads
This package provides two Node-RED nodes:
  • Config Node — manage MongoDB connections and connection pools.
  • Flow Node — perform database and collection operations using the native MongoDB driver API.
Table of Contents
  • Installation
  • Quick Start
  • Compatibility
  • Configuration Node
  • Flow Node
  • BSON Types
  • Development
  • Links
From your ~/.node-red directory run:
npm install --save --omit=dev node-red-contrib-mongodb4
Quick Start
  1. Add a MongoDB Config Node and configure the connection (URI or host/port, database, auth).
  2. Add a MongoDB Flow Node and select the config node, operation and collection.
  3. Pass operation arguments into msg.payload as an array — the array items are passed as function arguments to the driver.
Examples
Insert one document:
msg.payload = [{ name: 'Anna', age: 1 }];
Find with query and options:
const query = { age: 22 };
const options = { sort: { name: 1 }, projection: { name: 1 }, limit: 10, skip: 2 };
msg.payload = [query, options];
Aggregate (pipeline + options):
const pipeline = [ { $sort: { age: 1 } }, { $project: { name: 1 } }, { $limit: 10 } ];
const options = { allowDiskUse: true };
msg.payload = [pipeline, options];
Note: for aggregation you often end up with an array inside the payload array: msg.payload = [pipeline].
Compatibility
  • Node-RED >= v3.0.0
  • Node.js >= v16.20.1
  • Compatible with MongoDB server versions: 4.0, 4.2, 4.4, 5.0, 6.0, 7.0, 8.0 (depending on driver)
Version 3.x of this package uses the MongoDB driver v6.12 and contains breaking changes from earlier driver major versions — see the official MongoDB driver upgrade notes: https://www.mongodb.com/docs/drivers/node/current/upgrade/#version-6.0-breaking-changes
Configuration Node
The config node creates a MongoClient and manages a connection pool. You can configure connection details in two ways:
  • Simple fields: protocol (mongodb / mongodb+srv), hostname, port, database, username/password, auth source/mechanism.
  • Full URI: provide a complete connection string.
Connection-related options available in the node include connectTimeoutMS, socketTimeoutMS, minPoolSize, maxPoolSize, maxIdleTimeMS and other MongoClientOptions (JSON).
TLS options are supported: CA file, client certificate/key file, and an option to disable certificate verification (not recommended).
The config node will automatically generate an application name if you don't provide one (e.g. nodered-xxxxx). The application name is logged and can be used to inspect connections on the server.
Example server-side check:
db.currentOp(true).inprog.reduce((acc, conn) => {
    const appName = conn.appName || 'unknown';
    acc[appName] = (acc[appName] || 0) + 1;
    acc.totalCount = (acc.totalCount || 0) + 1;
    return acc;
}, { totalCount: 0 });
Flow Node
Use the flow node to execute collection or database operations.
Key options
  • Mode / msg.mode: collection or db (selects whether you call collection APIs or database APIs)
  • Collection / msg.collection: target collection name
  • Operation / msg.operation: driver operation name (e.g. find, findOne, insertOne, updateMany, aggregate, command, stats)
  • msg.payload: an array of arguments passed to the driver method
  • Output: for find and aggregate, choose toArray or forEach
  • maxTimeMS: server-side operation timeout
Common collection operations: find, findOne, insertOne, insertMany, updateOne, updateMany, deleteOne, deleteMany, aggregate.
Deprecated: the legacy insert, update, delete helper methods are not supported by modern drivers — use the newer specific methods instead.
The node returns the driver's response in msg.payload.
BSON Types
If you need BSON types (e.g. ObjectId, Double, Timestamp) from the driver inside function nodes, add the driver to functionGlobalContext in your Node-RED settings.js:
functionGlobalContext: {
    mongodb: require('node-red-contrib-mongodb4/node_modules/mongodb')
Then in a function node:
const { ObjectId } = global.get('mongodb');
msg.payload = [{ _id: new ObjectId('624b527d08e23628e99eb963') }];
The flow node can optionally convert string _id fields that look like valid ObjectIds to real ObjectId instances (deprecated feature — prefer explicit BSON types).
Development
Start a local development environment (Node-RED + MongoDB) using the included docker-compose.yml:
docker compose up -d
Stop and remove containers:
docker compose down
Node-RED will be available at http://localhost:1880 by default. Replace environment variables in docker-compose.yml with secure values for CI or production.
Links
Collection-API v6.21
Payload Output
The node will output the database driver response as message payload. The operations aggregate and find can output with toArray or forEach.
How to use BSON data types with this Node
You can use BSON types with this node.
First enable "mongodb" in your function global context. Add this to your settings.js file - typically this file located in ~/.node-red:
    mongodb: require("node-red-contrib-mongodb4/node_modules/mongodb")
This kind of require statement ensures that we use the BSON types from the mongodb driver used in this node. Otherwise we could run into compatibilty issues.
You can now use BSON types in your function node like so:
// get BSON types
const {ObjectId, Double, Timestamp} = global.get("mongodb");
// write your query
msg.payload = [{
    _id: new ObjectId() ,
    value: new Double(1.4),
    ts: new Timestamp()
// send them to the mongodb node
Node Status
Node status information is displayed below the node:
  • s : Number of successful executions
  • err : Number of failed executions
  • rt : Last execution runtime in ms
Colors
  • green : Last execution was successful
  • blue : Node execution in progress
  • red : Last execution failed
More general driver information
Visit the MongoDB Driver Docs
Development: Run with Docker Compose
You can start a local development environment with Node-RED and MongoDB using the included docker-compose.yml file. This starts two containers on a shared network and uses named Docker volumes for persistence.
Start the stack:
docker compose down
Environment variables are set inside docker-compose.yml with example values. For production or CI, replace them with secure values or set them in a .env file.
Node-RED will be available on http://localhost:1880.
Version: 3.4.0
Updated 11 months, 3 weeks ago
Rating: 5.0 5
614 in the last week
  • mongodb4-client
  • mongodb4
  • nodes
  • mongodb
