node-red-contrib-mongodb-variable 0.0.6
MongoDB node for Node-RED
npm install node-red-contrib-mongodb-variable
A Node-RED node to query MongoDB.
Edited by Andrii Lototskyi
MongoDB node driver 3.1.13 interface for Node-RED based on node-red-bluemix-nodes and MongoDB 3 Driver Please refer to the mongoDB node driver 'Collection' documentation to read about each operation.
Set Credentials
add data to settings.js
mongoConnects:
   uri: "mongodb://login:password@host:27017/dbName"
Example For Request
set data in function node
msg.payload = {"login": "login"};
Example node-red flowgit
Import the flow below in an empty sheet in nodered
[{"id":"f40a8af5.55fed8","type":"mongodb-var in","z":"1797a27a.5d0c6e","service":"_ext_","configNode":"49d0a8a1.8be078","name":"MongoDB","collection":"","operation":"find.toArray","x":464.5,"y":262,"wires":[["de8e6bf4.a24618"]]},{"id":"5c17003c.47d0d","type":"inject","z":"1797a27a.5d0c6e","name":"Start","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":143.5,"y":262,"wires":[["ced363e1.72367"]]},{"id":"ced363e1.72367","type":"function","z":"1797a27a.5d0c6e","name":"Request","func":"msg.payload = {};\nmsg.collection = 'collection_name';\nreturn msg;","outputs":1,"noerr":0,"x":294.5,"y":262,"wires":[["f40a8af5.55fed8"]]},{"id":"de8e6bf4.a24618","type":"debug","z":"1797a27a.5d0c6e","name":"Log Out","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":635.5,"y":262,"wires":[]},{"id":"49d0a8a1.8be078","type":"mongodb-var","z":"","uri":"mongodb://localhost:27017/dbName","name":"connect","options":"","parallelism":"-1"}]
Version: 0.0.6
Updated 7 years, 4 months ago
Rating: 5.0 2
8 in the last week
  • mongodb-var
  • mongodb-var in
  • bluemix
  • mongodb
