node-red-contrib-modbus-tcp-ip 1.1.5
A simple node for realtime MODBUS TCP/IP Process with added features.
npm install node-red-contrib-modbus-tcp-ip
Node-RED Modbus TCP Flexi Reader
This package enables the user to read data from the modbus enabled devices through TCP/IP.
Getting Started
npm install this module and you can find the block. Example node-red code can be found this repo.
Flow
Flow
Editing Connection
Edit Connection
Injecting Payload
Input Payload
Additial Payload Options
Also you can send the modbus ip and port along with payload instead of giving it at the input of node Eg: { "unitid":5, "functioncode":3, "address":3000, "quantity":100, "modbus_ip":"192.168.10.31", "modbus_port": 3666 }
Authors
This project is licensed under the MIT License - see the LICENSE.md file for details
Version: 1.1.5
Updated 6 years, 1 month ago
Rating: 3.7 3
18 in the last week
  • modbus-tcp-ip
