node-red-contrib-mjpgcamera 2.0.0
Node-RED nodes for mjpg_streamer
npm install node-red-contrib-mjpgcamera
Node-Red nodes for mjpg-streamer.
Visit https://github.com/jacksonliam/mjpg-streamer for more details.
mjpg-consumer
A node that consumes a mjpeg stream and outputs the latest saved frame as buffer
Stream should be the address of the stream
Streaming interval should be the number of seconds between buffer outputs
To enable output send "start" as payload (Can use an inject node or a dashboard switch). To disable, send "stop".
  1. Install from npm
    cd %Node-RED%
  2. To install from git:
    git clone https://github.com/electronicplayground/node-red-contrib-mjpgcamera.git
    cd node-red-contrib-mjpgcamera
    npm link
    cd %Node-RED%
    npm link node-red-contrib-mjpgcamera
Import the JSON below after installing the node to output the frame buffer to debug node and save frame as file. Edit mjpgConsumer to match your values (stream uri and output interval) and the file node to match the location to save the stream to as .JPG.
[{"id":"6d6c7312.2ff31c","type":"mjpg-consumer","z":"ddc693d5.dbc2a","name":"MjpgConsumer","stream":"http://192.168.0.104:8080/?action=stream","interval":"2","x":517,"y":134,"wires":[["18a0339c.da93ec","657e92c5.2219fc"]]},{"id":"68133e2.b94f7c","type":"inject","z":"ddc693d5.dbc2a","name":"Start Consumer","topic":"","payload":"start","payloadType":"str","repeat":"","crontab":"","once":true,"x":218,"y":103,"wires":[["6d6c7312.2ff31c"]]},{"id":"11674ce7.4dfc33","type":"inject","z":"ddc693d5.dbc2a","name":"Stop Consumer","topic":"","payload":"stop","payloadType":"str","repeat":"","crontab":"","once":false,"x":216,"y":170,"wires":[["6d6c7312.2ff31c"]]},{"id":"18a0339c.da93ec","type":"debug","z":"ddc693d5.dbc2a","name":"","active":true,"console":"false","complete":"false","x":756,"y":133,"wires":[]},{"id":"657e92c5.2219fc","type":"file","z":"ddc693d5.dbc2a","name":"Camera Capture","filename":"E:\capture.jpg","appendNewline":false,"createDir":false,"overwriteFile":"true","x":767,"y":199,"wires":[]}]
Version: 2.0.0
Updated 4 years, 9 months ago
Rating: 1.0 1
27 in the last week
  • mjpg-consumer
