node-red-contrib-mixing-station 1.0.0
Node-RED nodes to interact with Mixing Station via REST API and WebSockets
npm install node-red-contrib-mixing-station
Node-RED Mixing Station Integration
This is a work in progress
A Node-RED module to interact with Mixing Station's APIs, allowing you to control audio mixers through Mixing Station.
Overview
This module provides nodes for Node-RED that connect to Mixing Station's REST API and WebSocket interface. It allows you to:
  • Subscribe to mixer parameters and receive real-time updates
  • Send commands to get or set mixer parameters
  • Create automation and integration with other systems
Prerequisites
  • Node-RED (version 2.0.0 or later)
  • Mixing Station (Desktop version recommended for full API support)
  • Network connectivity between Node-RED and Mixing Station
Install via the Node-RED Palette Manager or run the following command in your Node-RED user directory:
Before using the nodes, you need to:
  1. Enable the REST API in Mixing Station:
    • Open Mixing Station
    • Go to global app settings
    • Enable "HTTP REST"
    • Note the port number (default: 8080)
  2. Configure the Mixing Station server in Node-RED:
    • Add a "Mixing Station Config" node
    • Set the host (e.g., "localhost" if running on the same machine)
    • Set the port to match the one configured in Mixing Station
Configuration node that stores connection details for the Mixing Station server.
  • Host: The hostname or IP address of the machine running Mixing Station
  • Port: The port number for the REST API (default: 8080)
  • Reconnect Interval: Time in milliseconds to wait before attempting to reconnect (default: 5000)
MS Subscribe
Subscribes to parameter updates from Mixing Station via WebSocket.
  • Server: The Mixing Station Config node to use
  • Path: The parameter path to subscribe to (e.g., "ch.*.mix.lvl" for all channel faders)
  • Format: Value format - "val" for plain values (e.g., -5dB) or "norm" for normalized values (0-1)
The node outputs messages containing parameter updates, with the parameter values in the payload property.
You can also dynamically change the subscription by sending a message with:
  • path: The new parameter path to subscribe to
  • format: Optional. The value format to use ("val" or "norm")
MS Command
Sends commands to Mixing Station via REST API or WebSockets.
  • Path: The API endpoint path (e.g., "/console/data/ch.0.mix.lvl")
  • Method: HTTP method to use (GET, POST, PUT, DELETE)
  • Use WebSocket: Whether to use WebSockets instead of HTTP
The node accepts messages with:
  • payload: The body of the request (for POST/PUT)
  • path: Optional. Overrides the configured path
  • method: Optional. Overrides the configured method
  • useWebSocket: Optional. Overrides whether to use WebSocket
Parameter Paths
Mixing Station uses a unified path format for all mixer parameters. Some examples:
  • ch.0.mix.lvl - Channel 1 fader level
  • ch.*.mix.lvl - All channel fader levels (using wildcard)
  • ch.0.mix.on - Channel 1 mute state (inverted - true means unmuted)
  • ch.0.name - Channel 1 name
  • ch.0.eq.0.gain - Channel 1 EQ band 1 gain
  • bus.0.mix.lvl - Bus 1 fader level
For a complete list of available parameters, use the REST API documentation page in Mixing Station:
  • Enable the REST API in Mixing Station
  • Open http://localhost:<port> in a web browser
  • Explore the available endpoints and parameter paths
Examples
Here are some common usage examples:
Example 1: Monitor all channel faders
  1. Add an "MS Subscribe" node
  2. Configure it with path ch.*.mix.lvl and format val
  3. Connect to a Debug node to see the values
Example 2: Set a channel fader level
  1. Add an Inject node with payload = -6 (for -6dB)
  2. Set the Inject node's path property to /console/data/ch.0.mix.lvl
  3. Connect to an "MS Command" node configured with method = POST
  4. The Command node will set Channel 1's fader to -6dB when triggered
Example 3: Mute/unmute a channel
  1. Add an Inject node with payload = false (for muted)
  2. Set the Inject node's path property to /console/data/ch.0.mix.on
  4. The Command node will mute Channel 1 when triggered
Troubleshooting
  • Connection Issues: Ensure Mixing Station has the REST API enabled and the port matches your configuration
  • No Data Received: Check that you're using the correct parameter paths and that the mixer is connected
  • Command Errors: Verify that you're sending the correct data type for the parameter
Version: 1.0.0
Updated 1 year, 9 months ago
  • mixing-station-config
  • mixing-station-subscribe
  • mixing-station-command
  • mixing-station
  • audio
  • mixer
  • websocket
  • api
