node-red-contrib-mios 0.2.0
A node for mios/Vera
npm install node-red-contrib-mios
Node-RED nodes to get events from and control your MIOS/Vera unit.
Run the following command in your Node-RED user directory - typically ~/.node-red:
Get events from your MIOS/Vera unit and control items in the same.
Incoming events can be filtered so you can use one mios-in node for all events, events from one room or a specific item. The value from the events is stored in msg.payload
To set items you send the value in msg.payload and use the mios-out node to specify the item, ie Bedroom:Bed Light:Status, or define the item in msg.topic.
Version: 0.2.0
Updated 8 years, 9 months ago
14 in the last week
  • mios-server
  • mios-in
  • mios-out
  • mios
  • Vera
  • Z-wave
  • Zwave
