node-red-contrib-minio-all 0.0.6
A collection of Node-RED nodes for MinIO.
npm install node-red-contrib-minio-all
NodeRed Node for common MinIO operations, by Colin Payne.
This node utilises the MinIO JavaScript API (please see https://docs.min.io/docs/javascript-client-api-reference.html).
Please Note: This set of nodes (and associated support information) is a work in progress.
The Bucket Notification Operation setBucketNotification is being worked on, and is not currently functioning correctly.
2021/01/29 - Version: 0.0.6 • getObject now working; edits by @macanfa - thank you!
2020/05/06 - Version: 0.0.5 • getPartialObject now working as expected, and README updated accordingly.
2020/04/29 - Version: 0.0.4 • listenBucketNotification now extended to include defined Supported Event Types.
MinIO Operations
Bucket Operations File Object Operations Object Operations
makeBucket fGetObject getObject
listBuckets fPutObject getPartialObject
bucketExists putObject
removeBucket copyObject
listObjects statObject
listObjectsV2 removeObject
listObjectsV2WithMetadata removeObjects
listIncompleteUploads removeIncompleteUpload
Presigned Operations Bucket Notification Operations Bucket Policy Operations
presignedUrl getBucketNotification getBucketPolicy
presignedGetObject setBucketNotification setBucketPolicy
presignedPutObject removeAllBucketNotification
presignedPostPolicy listenBucketNotification
Passing in parameters
For each operation, parameters can either be set in the Edit Node dialogue, or passed in to the node via the node input. Parameters passed in will override any parameters set in the Edit Node dialogue.
The Operation in each case can be passed in to the node by setting the appropriate incoming value of msg.operation
Bucket Operations
1. makeBucket
Description
Creates a new bucket.
Parameters
Name Parameter
(passed in as)
Description
bucketBucket bucketName
(msg.bucketName)
Name of the bucket to be created
regionRegion region
(msg.region)
Region where the bucket is to be created. (optional)
Node Outputs
Name Description
Output The node will output confirmation, in the form of a JS object, as to whether or not the bucket was created, e.g. {"makeBucket":true}
Error Any errors received in response to the request will be passed to the node's 'Error' output.
2. listBuckets
Description
List all buckets.
Parameters
No parameters required.
Node Outputs
Name Description
Output The node will output a JS object in the form {"listBuckets":[...]} containing an array of objects in the form {"name":"bucketname","creationDate": "yyyy-mm-ddThh:mm:ss.sssZ"} for each bucket.
3. bucketExists
Description
Checks if a bucket exists.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket to be checked.
Node Outputs
Name Description
Output The node will output confirmation, in the form of a JS object, as to whether or not the bucket exists, e.g. {"bucketExists":true}
4. removeBucket
Description
Removes a bucket.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket to be removed.
Node Outputs
Name Description
Output The node will output confirmation, in the form of a JS object, as to whether or not the bucket has been removed, e.g. {"removeBucket":true}
5. listObjects
Description
Lists all objects in a bucket.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket for which the objects listing is required.
prefixPrefix prefix
(msg.prefix)
The prefix of the objects that should be listed. (optional).
recursiveRecursive recursive
(msg.recursive)
true indicates recursive style listing and false indicates directory style listing delimited by '/'. (optional, default false).
Node Outputs
Name Description
Output The node will output a JS object in the form {"listObjects":[...]} containing an array of JS objects in the form {"name":"objectname", "lastModified": "yyyy-mm-ddThh:mm:ss.sssZ", "etag":"etagstring", "size":1234} for each object returned.
6. listObjectsV2
Description
Lists all objects in a bucket using S3 listing objects V2 API.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
prefixPrefix prefix
(msg.prefix)
(msg.recursive)
startAfterStart After startAfter
(msg.startAfter)
Specifies the object name to start after, when listing objects in a bucket. (optional).
Node Outputs
Name Description
Output The node will output a JS object in the form {"listObjectsV2":[...]} containing an array of JS objects in the form {"name":"objectname", "lastModified": "yyyy-mm-ddThh:mm:ss.sssZ", "etag":"etagstring", "size":1234} for each object returned.
7. listObjectsV2WithMetadata
Description
Lists all objects and their metadata in a bucket using S3 listing objects V2 API.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
prefixPrefix prefix
(msg.prefix)
(msg.recursive)
(msg.startAfter)
Node Outputs
Name Description
Output The node will output a JS object in the form {"listObjectsV2WithMetadata":[...]} containing an array of JS objects in the form {"name":"objectname", "lastModified": "yyyy-mm-ddThh:mm:ss.sssZ", "etag":"etagstring", "size":1234, "metadata":{...} } for each object returned.
8. listIncompleteUploads
Description
Lists partially uploaded objects in a bucket.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
prefixPrefix prefix
(msg.prefix)
Prefix of the object names that are partially uploaded. (optional).
(msg.recursive)
Node Outputs
Name Description
Output The node will output a JS object in the form {"listIncompleteUploads":[...]} containing an array of JS objects in the form {"key":"objectname", "uploadId": "uploadidstring", "size":1234} for each object returned.
1. fGetObject
Description
Downloads and saves the object as a file in the local filesystem.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
filefile objectName
(msg.objectName)
Name of the object.
pathPath filePath
(msg.filePath)
Path on the local filesystem to which the object data will be written.
Node Outputs
Name Description
Output The node will output confirmation, in the form of a JS object, as to whether or not the object could be downloaded as a file, e.g. {"fGetObject":true}
2. fPutObject
Description
Uploads contents from a file to objectName.
The maximum size of a single object is limited to 5TB. fPutObject transparently uploads objects larger than 64MiB in multiple parts. Uploaded data is carefully verified using MD5SUM signatures.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
filefile objectName
(msg.objectName)
Name of the object.
pathPath filePath
(msg.filePath)
Path of the file to be uploaded.
metaDataMetaData metaData
(msg.metaData)
Metadata of the object (optional).
Node Outputs
Name Description
Output The node will output a JS object, containing confirmation as to whether or not the file object was successfully uploaded, and, if successful, an etag value for the uploaded file object, e.g. {"fPutObject":true,"etag":"etagvaluestring"}
Object Operations
1. getObject
Description
Downloads an object as a stream.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
fileObject objectName
(msg.objectName)
Name of the object.
Node Outputs
Name Description
Output The node will output a JS object. {"getObject":true,"objectData":[Buffer],"opjectSize":size-in-bytes}
2. getPartialObject
Description
Downloads the specified range bytes of an object as a stream.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
(msg.objectName)
Name of the object.
offsetOffset offset
(msg.offset)
Offset of the object from where the stream will start.
lengthLength length
(msg.length)
Length of the object that will be read in the stream (optional, if not specified we read the rest of the file from the offset).
Node Outputs
Name Description
Output The node will output a JS object, containing confirmation as to whether or not thepartial object (chunk) was successfully downloaded, and, if successful, a buffer array for the downloaded partial object stream, e.g. { "getPartialObject": true, "chunk": [...] }
3.putObject
Description
Uploads an object from a stream/Buffer.
The maximum size of a single object is limited to 5TB. putObject transparently uploads objects larger than 64MiB in multiple parts. Uploaded data is carefully verified using MD5SUM signatures.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
(msg.objectName)
Name of the object.
streamStream stream
(msg.stream)
Readable stream.
sizeSize size
(msg.size)
Size of the object (optional).
metaDataMeta Data metaData
(msg.metaData)
Meta data of the object (optional).
Node Outputs
Name Description
Output The node will output confirmation, in the form of a JS object, as to whether or not the object PUT operation was successful, including (if appropriate) the etag reference of the object, , e.g. {"bucketExists":true, "etag":etagstring}
4. copyObject
Description
Copy a source object into a new object in the specified bucket.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
(msg.objectName)
Name of the object.
sourceObjectSource sourceObject
(msg.sourceObject)
Path of the file to be copied, in the format bucketname/objectname
sizeSize size
(msg.size)
Conditions to be satisfied before allowing object copy.
tagETag setMatchEtag
(msg.setMatchEtag)
tagExcept ETag setMatchEtagExcept
(msg.setMatchEtagExcept)
calendarModified setModified
(msg.setModified)
metaDataMetaData setReplaceMetadataDirective
(msg.setReplaceMetadataDirective)
calendarUnmodified setUnmodified
(msg.setUnmodified)
Node Outputs
Name Description
Output The node will output confirmation, in the form of a JS object, as to whether or not the object has been copied, e.g. {"copyObject":true}
5. statObject
Description
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
prefixPrefix prefix
(msg.prefix)
(msg.recursive)
Node Outputs
Name Description
6. removeObject
Description
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
prefixPrefix prefix
(msg.prefix)
(msg.recursive)
(msg.startAfter)
Node Outputs
Name Description
7. removeObjects
Description
Removes all objects in a specified bucket matching an optional prefix value, or a defined list of object names.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
listObjects List objectsList
(msg.objectsList)
Explicit list of objects in the bucket to be removed (Optional). Should be provided as an array of object names, e.g. [ "object_01", "object_02", "object_03" ]. If left blank, then all objects in the specified bucket will be removed (subject to any value specified in the prefix field).
prefixPrefix prefix
(msg.prefix)
The prefix of the objects that should be removed (Optional). If no prefix is provided, then all objects within the specified bucket will be removed, unless an explicit list of objects is provided in the Objects List field.
Node Outputs
Name Description
Output The node will output confirmation, in the form of a JS object, as to whether or not the list of objects have been removed, e.g. {"removeObjects":true}
8. removeIncompleteUpload
Description
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
prefixPrefix prefix
(msg.prefix)
recursiveRecursive recursive (msg.recursive) true indicates recursive style listing and false indicates directory style listing delimited by '/'. (optional, default false).
Node Outputs
Name Description
1. presignedURL
Description
Generates a presigned URL for the provided HTTP method, 'httpMethod'.
Browsers/Mobile clients may point to this URL to directly download objects even if the bucket is private. This presigned URL can have an associated expiration time in seconds after which the URL is no longer valid. The default value is 7 days.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
(msg.objectName)
Name of the object.
expiryExpiry expiry
(msg.expiry)
Expiry time in seconds. Default value is 7 days. (optional)
paramsParams reqParams
(msg.reqParams)
Request parameters. (optional)
calendarIssue Date requestDate
(msg.requestDate)
A date object, the url will be issued at. Default value is now. (optional)
Node Outputs
Name Description
Output If successful, the node will output a JS object, containing the generated presigned URL, e.g. { "presignedURL": presignedUrl }
2. presignedGetObject
Description
Generates a presigned URL for HTTP GET operations. Browsers/Mobile clients may point to this URL to directly download objects even if the bucket is private. This presigned URL can have an associated expiration time in seconds after which the URL is no longer valid. The default value is 7 days.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
(msg.objectName)
Name of the object.
expiryExpiry expiry
(msg.expiry)
headersHeaders respHeaders
(msg.respHeaders)
Response headers to override (optional)
(msg.requestDate)
Node Outputs
Name Description
Output If successful, the node will output a JS object, containing the generated presigned GET object URL, e.g. { "presignedURL": presignedUrl }
3. presignedPutObject
Description
Generates a presigned URL for HTTP PUT operations. Browsers/Mobile clients may point to this URL to upload objects directly to a bucket even if it is private. This presigned URL can have an associated expiration time in seconds after which the URL is no longer valid. The default value is 7 days.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
(msg.objectName)
Name of the object.
expiryExpiry expiry
(msg.expiry)
Node Outputs
Name Description
Output If successful, the node will output a JS object, containing the generated presigned PUT object URL, e.g. { "presignedURL": presignedUrl }
4. presignedPostPolicy
Description
Allows setting policy conditions to a presigned URL for POST operations. Policies such as bucket name to receive object uploads, key name prefixes, expiry policy may be set.
Parameters
Name Parameter
(passed in as)
Description
bucketBucket policy.setBucket
(msg.policy.setBucket)
Policy restricting bucket for upload (optional).
fileKey policy.setKey
(msg.policy.setKey)
Policy restricting object Key for upload (optional).
Key Prefix policy.setKeyStartsWith
(msg.policy.setKeyStartsWith)
Policy restricting object Key prefix for upload (optional).
expiryExpiry policy.setExpires
(msg.policy.setExpires)
Expiry time of the policy, in seconds (optional).
typeType policy.setContentType
(msg.policy.setContentType)
Policy restricting content type for upload, e.g. text/plain (optional).
sizeFromSize: From policy.setContentLengthRange
(msg.policy.setContentLengthRange.from)
The lower end of the range of content length for the upload, in bytes, e.g. 1024 (optional).
sizeToSize: To policy.setContentLengthRange
(msg.policy.setContentLengthRange.to)
The upper end of the range of content length for the upload, in bytes, e.g. 1024*1024 (optional).
Node Outputs
Name Description
Output If successful, the node will output a JS object, containing the details of the submitted policy, e.g. { "presignedPostPolicy": { "postURL": url, "formData": {...} } }
For each operation, paramenters can either be set in the Edit Node dialogue, or passed in to the node via the node input. Parameters passed in will override any parameters set in the Edit Node dialogue.
The bucket Operation can be passed in to the node by setting the appropriate incoming value of msg.operation
1. getBucketNotification
Description
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket to be created.
regionRegion region
(msg.region)
Node Outputs
Name Description
2. setBucketNotification
Description
List all buckets.
Node Outputs
Name Description
3. removeAllBucketNotification
Description
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Node Outputs
Name Description
4. listenBucketNotification
Description
Removes a bucket.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Node Outputs
Name Description
1. getBucketPolicy
Description
Get the bucket policy associated with the specified bucket. If objectPrefix is not empty, the bucket policy will be filtered based on object permissions as well.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
Node Outputs
Name Description
Output The node will output confirmation, in the form of a JS object, as to whether or not the bucket policy exists, and if it does, the details of the policy, e.g. {"getBucketPolicy":true, "policy":{...} }
2. setBucketPolicy
Description
Set the bucket policy on the specified bucket. bucketPolicy is detailed here.
Parameters
Name Parameter
(passed in as)
Description
(msg.bucketName)
Name of the bucket.
policyPolicy bucketPolicy
(msg.bucketPolicy)
Bucket policy.
Node Outputs
Name Description
Output The node will output confirmation, in the form of a JS object, as to whether or not the bucket policy has been set, e.g. {"setBucketPolicy":true}
Copyright © 2020 Colin Payne
Version: 0.0.6
Updated 6 years, 4 months ago
Rating: 4.7 6
68 in the last week
  • minio-config
  • buckets
  • files
  • objects
  • presigned
  • notifications
  • policies
  • minio
  • s3
