node-red-contrib-mikronode-ng 0.1.1
Node-RED node for monitoring MikroTik RouterOS devices (traffic, wifi registration, routes, OVPN clients) via mikronode-ng
npm install node-red-contrib-mikronode-ng
Node-RED nodes for monitoring MikroTik RouterOS devices, built on @thatoneneji/mikronode-ng.
v1 scope: monitoring only (no config/write actions).
  • mikrotik-config — a device (host/port/TLS + API credentials), shared by any number of action nodes below. Picked from a dropdown on each action node, not wired — the standard Node-RED config-node pattern (like mqtt-broker). One underlying connection is opened per config node; every action node pointed at it opens its own channel on that same connection. Like any config node, it never appears in the main palette and can't be wired on canvas (Node-RED doesn't render config nodes there, full stop) - use mikrotik-status below if you want its connection status visible on a flow.
  • mikrotik-status — an ordinary, palette-visible action node (same device-dropdown as the others) that reports its device's connection status as messages - the ordinary node to wire to a debug node while troubleshooting a device's connection. Topic status, payload.state is one of connected / reconnecting / disconnected / error / login-failed.
  • mikrotik-traffic — interface traffic (/interface/monitor-traffic), topic monitor-traffic
  • mikrotik-wifi-registration — wifi registration table, old or new CAPsMAN (/caps-man/registration-table or /interface/wifi/registration-table), topic wifi-reg-old or wifi-reg-new
  • mikrotik-routes — active routes (/ip/route), topic routes
  • mikrotik-ovpn-client — OVPN client connections (/interface/ovpn-client/monitor), topic ovpn-client. Once a Device is selected, its edit dialog queries the device live for configured OVPN client interfaces (including disabled ones) and lets you pick from a checkbox list instead of typing names by hand - use "Refresh from device" if you add this node before the device has deployed/connected.
mikrotik-routes and mikrotik-wifi-registration both take an optional Interval (1-60s): left blank, they print the current state once then only emit again when something actually changes; set, they instead re-emit the full table on that repeating cadence (confirmed against a real device: RouterOS's print =interval=N does this - listen does not).
mikrotik-wifi-registration also has an optional Transform raw fields checkbox, old CAPsMAN only: RouterOS packs several distinct values into single delimited strings here (a "tx,rx" comma-pair for bytes/packets, a combined rate+width string like "150Mbps-40MHz/1S/SGI", a space-separated rate-set blob) - enabling it reshapes each row into {tx: {...}, rx: {...}, ...} with those pulled apart. Best-effort: a row that doesn't match the expected shape is left raw rather than dropped or erroring. Not available for new CAPsMAN, which uses different field names entirely.
If a data node's command traps (e.g. an interface that doesn't currently exist), it retries automatically every 30 seconds rather than staying silent forever - useful for a target that may only exist some of the time (a VPN peer, a dynamically created interface).
Output
Each action node emits one message per update:
  • msg.topic — a short name for the feature (see above), not the underlying channel id
  • msg.name — the device's configured name (falls back to its host)
  • msg.hostname — the device's host
  • msg.timestamp — when this plugin captured the message, epoch milliseconds (Date.now()) - RouterOS's own payload has no notion of "when," only relative per-second counters
  • msg.payload — the parsed rows for that update (an array of objects). Values that are unambiguously numbers on the wire (plain integers/decimals) come through as real numbers, not strings - everything else (MAC addresses, .id values, IP/CIDR addresses, true/false, ...) stays a string, since those don't round-trip safely through Number().
  "topic": "monitor-traffic",
  "name": "Testing device",
  "hostname": "mikronode-ng.dev",
  "timestamp": 1756468143123,
  "payload": [{ "name": "ether1", "rx-bits-per-second": 101360, "...": "..." }]
Development
npm install
npm test    # mocha + node-red-node-test-helper
npm run lint
See .devcontainer/ for a local Node-RED instance to develop and manually test the nodes against a real device.
Version: 0.1.1
Updated 2 months, 2 weeks ago
141 in the last week
  • mikrotik-config
  • mikrotik-status
  • mikrotik-traffic
  • mikrotik-routes
  • node-red-contrib
  • mikrotik
  • routeros
  • mikronode
