node-red-contrib-mihome 1.1.1
Get Xiaomi device information from Mi Home
npm install node-red-contrib-mihome
platform npm npm GitHub
Add nodes to get data from devices connected to Mi Home using node-mihome. See changelog for the latest changes.
Requirements
  • node v12.22.0 or higher
  • node-red v1.3.0 or higher
Run npm i node-red-contrib-mihome in ~/.node-red directory or search node-red-contrib-mihome and install from Palette Manager.
Supported devices
Device Models Tested Node info
Mi Temperature and
Humidity Monitor 2
LYWSD03MMC (China)
NUN4126GL (Global, should be checked)
Palette name: th monitor
Node name: mihome-th-monitor
Mi Temperature and
Humidity Sensor
WSDCGQ01LM Palette name: th sensor
Node name: mihome-th-sensor
Adding device support
If you want to add device support, you can make a PR or add request in discussions. Check supported devices in node-mihome package and use node template for boost development. Additional information you can find in contributing guide.
Available nodes
mihome-cloud
Provide authorization for Mi Home.
Settings
Setting Required Description
Username Mi Home account username
Password Mi Home account password
Country Which server use to connect
Aqara Should it be Aqara protocol initiated
Setting preview
mihome-cloud
Aqara protocol limitations: you can set up only one mihome-cloud node with Aqara protocol enabled, all another may cause errors (in short explanation it's because node-mihome open socket connection in exclusive mode).
mihome-devices
Returns all devices connected to Mi Home.
Palette name: devices.
Statuses
Statuses Preview
Node not connected to cloud mihome-devices
Node connected to cloud mihome-devices
Settings
Cloud Mi Home account settings
Name Node display name
Setting preview
mihome-devices
Setup
Description
Input payload with true value
Output payload as array of objects
mihome-th-monitor
Returns climate data.
Palette name: th monitor.
Statuses
Statuses Preview
Node not connected to cloud mihome-th-monitor
Node connected to cloud but not configured mihome-th-monitor
Node connected to cloud and configured mihome-th-monitor
Settings
Device ID Unique device ID from Mi Home, you can get it by checking did field from mihome-devices output
Setting preview
mihome-th-monitor
Setup
Description
Output payload as object contains temperature, humidity, battery level (could be null) and timestamps
Version: 1.1.1
Updated 5 years, 9 months ago
Rating: 2.5 2
12 in the last week
  • mihome-cloud
  • mihome-devices
  • mihome-th-monitor
  • mihome-th-sensor
  • node-red-contrib
  • mi
  • miio
  • mihome
  • xiaomi
