node-red-contrib-midea-local 0.1.2
Node-RED nodes for local control of Midea smart air conditioners
npm install node-red-contrib-midea-local
Node-RED nodes for local network control of Midea smart air conditioners. No cloud dependency at runtime — everything talks directly to the device over your LAN.
Based on midea-local.
Then restart Node-RED. The nodes will appear in the midea category in the palette.
midea device (config)
Configuration node that manages the connection to a single Midea AC device.
  • Scan Network — discovers Midea devices on your local network via UDP broadcast. If your network is segmented into VLANs or subnets (broadcast cannot cross those boundaries), enter the device IP first and press Scan Network to probe that device directly
  • Authorize — one-time cloud authentication for V3 devices to fetch the device token and key. Your Midea account credentials are used only during this step and are never stored
  • Auto-reconnect — connection is automatically re-established with exponential backoff (1s → 60s)
midea in
Reads the current device state when triggered by an input message. Use an inject node upstream to poll at your desired interval.
Output msg.payload:
Property Type Description
powerState boolean Power on/off
targetTemperature number Set temperature in °C
indoorTemperature number | null Measured indoor temp
outdoorTemperature number | null Measured outdoor temp
operationalMode string "auto", "cool", "dry", "heat", "fan_only"
fanSpeed string "auto", "max", "high", "medium", "low", "silent"
swingMode string "off", "vertical", "horizontal", "both"
turboMode boolean Turbo on/off
ecoMode boolean Eco on/off
sleepMode boolean Sleep on/off
indoorHumidity number | null Indoor humidity %
displayOn boolean | null LED display state
filterAlert boolean | null Filter needs cleaning
realTimePower number | null Current power draw (W)
midea out
Sends commands to the device. Set properties in msg.payload — only specified properties are changed.
Example — turn on and cool to 22°C:
  "powerState": true,
  "operationalMode": "cool",
  "targetTemperature": 22
Example — just change the fan speed:
  "fanSpeed": "low"
Accepted properties:
Property Type Values
powerState boolean true / false
targetTemperature number 16.0 – 30.0 (0.5 steps)
operationalMode string | number "auto", "cool", "dry", "heat", "fan_only"
fanSpeed string | number "auto", "max", "high", "medium", "low", "silent"
swingMode string | number "off", "vertical", "horizontal", "both"
turboMode boolean Enable turbo
ecoMode boolean Enable eco
sleepMode boolean Enable sleep
fahrenheit boolean Display in Fahrenheit
displayOn boolean Toggle LED display
beep boolean Beep on command
String values are case-insensitive. Numeric enum values are also accepted.
Credits
All reverse-engineering and protocol analysis credit goes to Tucker Kern and midea-msmart.
MIT
Version: 0.1.2
Updated 2 months ago
15 in the last week
  • midea-device
  • midea-in
  • midea-out
  • midea
  • air-conditioner
  • smart-home
  • hvac
  • iot
  • local-control
