node-red-contrib-miakapi 3.0.32
MiakAPI V3 for Node-RED
MiakAPI for Node-RED
New: Miakapp 4, the smart home that builds itself. Tell an AI agent what you want: it connects your devices (even the closed ones), writes your automations and builds an app for everyone at home. Get started at https://www.miakapp.com.
npm i node-red-contrib-miakapi
This package is an adaptation of MiakAPI for Node-RED.
Miakapp
Miakapp is an easy way to create complete interfaces for your smart home. A control panel allows you to manage users and their permissions. Instant communications are provided by WebSockets between your clients and your coordinator. A coordinator is used to dynamically edit content of your pages. It communicates using MiakAPI.
MiakAPI
MiakAPI is a Websockets-based protocol that allows communication between clients and the coordinator.
Available methods are :
getUsers=> Get the list of users in your home and their permissionscommit=> Send data (variables) to the clients (you can use restrictions for some users)sendNotif=> Send a push notification to the client (if it hasn't disabled them from their settings)
Events are:
onUpdate=> When an update of home settings happens (user / group / permission update...)onUserLogin=> When a user logs into your homeonUserAction=> When a user clicks a button or types text in an input
Interface builder examples
Interface editor is a web HTML/CSS editor with snippets. Here is an example of what we can build very quickly and without writing CSS.
Screenshots:
Code:
<page id="pagename">
<div class="block small">
<div class="title">Big grid example</div>
<div class="bigGrid">
<div id="btn1" class="bigBtn" @click>
<div class="bigBtnIcon">🔷</div>
<div class="bigBtnText">Normal button</div>
</div>
<div id="btn2" class="bigBtn green" @click>
<div class="bigBtnIcon">✔</div>
<div class="bigBtnText">Green button</div>
</div>
<div id="btn3" class="bigBtn orange" @click>
<div class="bigBtnIcon">🔶</div>
<div class="bigBtnText">Orange button</div>
</div>
<div id="btn4" class="bigBtn red" @click>
<div class="bigBtnIcon">❌</div>
<div class="bigBtnText">Red button</div>
</div>
<div id="btn5" class="bigBtn disabled" @click>
<div class="bigBtnIcon">🔒</div>
<div class="bigBtnText">Disabled button</div>
</div>
</div>
</div>
<div class="separator"></div>
<div class="title">Form example</div>
<div class="simpleInput">
<div>Text example</div>
<input id="textInput1" type="text" placeholder="Text" @watch>
</div>
<!-- Double columns -->
<div class="twoColumns">
<div>Select example</div>
<select id="select1" @watch>
<option value="value1">Choice 1</option>
<option value="value2">Choice 2</option>
<option value="value3">Choice 3</option>
<option value="value4">Choice 4</option>
</select>
</div>
<div>Number example</div>
<input id="numberInput1" type="number" placeholder="Number" @watch>
</div>
</div>
<div>Time example</div>
<input id="timeInput1" type="time" @watch>
</div>
<div>Week example</div>
<input id="weekInput1" type="week" @watch>
</div>
<div>Month example</div>
<input id="monthInput1" type="month" @watch>
</div>
<div>Date example</div>
<input id="dateInput1" type="date" @watch>
</div>
</div>
<div>Datetime example</div>
<input id="datetimeInput1" type="datetime-local" @watch>
</div>
<div id="redBtn" class="button red" @click>Red button</div>
<div id="greenBtn" class="button green" @click>Green button</div>
</div>
</div>
<div class="title">Properties example</div>
<div class="infoItem">
<div>Example of property 1</div>
<div>Value of property 1</div>
</div>
<div>Example of property 2</div>
<div>Value of property 2</div>
</div>
<div>Example of property 3</div>
<div>Value of property 3</div>
</div>
<div>Example of property 4</div>
<div>Value of property 4</div>
</div>
<div>Example of property 5</div>
<div>Value of property 5</div>
</div>
<div id="normalBtn1" class="button" @click>Normal button</div>
<div id="normalBtn2" class="button disabled" @click>Disabled button</div>
</div>
</div>
<div class="title">Table example</div>
<table>
<tr>
<th>Column 1</th>
<th>Column 2</th>
<th>Column 3</th>
</tr>
<tr>
<td>Line 1, Col 1</td>
<td>Line 1, Col 2</td>
<td>Line 1, Col 3</td>
</tr>
<tr class="clickable" id="line2" @click>
<td>Line 2, Col 1</td>
<td>Line 2, Col 2</td>
<td>Line 2, Col 3</td>
</tr>
</table>
<div id="addLineBtn" class="button green plusButton" @click>+</div>
</div>
</page>
<style>
#pagename {
</style>
