node-red-contrib-mi-miio 0.0.4
Node-RED contrib for mi miio device.
npm install node-red-contrib-mi-miio
npm version
这是一个Node-RED的小米MiIO设备的插件。
Bug反馈/建议等请提交issuesQQ群: 107927710
支持设备
设备名称 Device Name MiIO model
1 米家智能插线板 MiIntelligencePinboard zimi.powerstrip.v2
2 Yeelight彩光灯带 YeelightColorLedStrip yeelink.light.strip1
yeelink.light.strip2
3 智米直流变频落地扇 ZhiMiDCVariableFrequencyFan zhimi.fan.v3
更多设备待添加中。。。
安装
确认安装好Node-RED之后,执行如下命令:
npm install -g node-red-contrib-mi-miio
输入/输出消息说明
获取设备属性列表
输入内容:
    "cmd": "list"
输出内容:
    "cmd": "list_response",
    "attributes": ["power", "power_consume_rate", "temperature", "wifi_led"]
获取设备属性值
输入内容:
    "cmd": "get"
输出内容:
    "cmd": "get_response",
    "values": {
        "power": "off",
        "power_consume_rate": 0,
        "temperature": 41.11,
        "wifi_led": "on"
    "msg": "success"
修改设备属性值
输入内容:
    "cmd": "set",
    "attribute": "要修改的属性",
    "value": "要修改的值"
输出内容:
    "cmd": "set_response",
    "result": "success",
    "msg": ["ok"]
属性值变动通知
当某个属性的值有变动时,通知如下消息:
attributes为值有变动的属性,oldValues为变动前各属性的值,newValues为变动后各属性的值。
    "cmd": "report",
    "attributes": ["power", "temperature"],
    "oldValues": {
        "power": "on",
        "temperature": 49.66,
        "wifi_led": "on"
    "newValues": {
        "power": "off",
        "temperature": 49.59,
        "wifi_led": "on"
与Dashboard配合的例子
Yeelight灯带与Dashboard配合的例子
[{"id":"fea09c3e.87c1e","type":"Mi-YeelightColorLedStrip","z":"ec7c6746.2fe518","name":"书房书架灯带","device":"5d4b1236.d0ce0c","x":200,"y":980,"wires":[["24b1fdf1.2270b2"]]},{"id":"b3f76830.389b08","type":"function","z":"ec7c6746.2fe518","name":"report-power","func":"var attribute = \"power\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0) {\n    return;\n}\n\nreturn {\n    'payload': msg.payload.newValues[attribute]\n};","outputs":1,"noerr":0,"x":630,"y":840,"wires":[["6ddd8e6c.53414"]]},{"id":"6ddd8e6c.53414","type":"ui_switch","z":"ec7c6746.2fe518","name":"","label":"电源","group":"51432a30.c95924","order":1,"width":"6","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"on","onvalueType":"str","onicon":"fa-lightbulb-o","oncolor":"yellow","offvalue":"off","offvalueType":"str","officon":"fa-lightbulb-o","offcolor":"black","x":780,"y":840,"wires":[["6c770464.80150c"]]},{"id":"6c770464.80150c","type":"function","z":"ec7c6746.2fe518","name":"set-power","func":"if(msg.socketid) {\n    return {\n        \"payload\": {\n            \"cmd\": \"set\",\n            \"attribute\": \"power\",\n            \"value\": msg.payload\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":920,"y":840,"wires":[["5dff5943.ebe178"]]},{"id":"bdf64493.85a798","type":"function","z":"ec7c6746.2fe518","name":"report-bright","func":"var attribute = \"bright\";\nvar power = \"power\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0 &&\nmsg.payload.attributes.indexOf(power) < 0\n) {\n    return;\n}\n\nreturn {\n    'payload': msg.payload.newValues[attribute],\n    'enabled': msg.payload.newValues[power] == \"on\" ? true : false\n};","outputs":1,"noerr":0,"x":630,"y":890,"wires":[["a7712231.a5246"]]},{"id":"e67fdd62.aa436","type":"function","z":"ec7c6746.2fe518","name":"set-bright","func":"if(msg.socketid) {\n    return {\n        \"payload\": {\n            \"cmd\": \"set\",\n            \"attribute\": \"bright\",\n            \"value\": msg.payload\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":920,"y":890,"wires":[["5dff5943.ebe178"]]},{"id":"a7712231.a5246","type":"ui_slider","z":"ec7c6746.2fe518","name":"","label":"亮度","group":"51432a30.c95924","order":0,"width":"6","height":"1","passthru":true,"outs":"all","topic":"","min":0,"max":"100","step":1,"x":780,"y":890,"wires":[["e67fdd62.aa436"]]},{"id":"8635397e.a2e6a8","type":"ui_colour_picker","z":"ec7c6746.2fe518","name":"","label":"颜色","group":"51432a30.c95924","format":"rgb","outformat":"object","showSwatch":true,"showPicker":false,"showValue":false,"showHue":true,"showAlpha":false,"showLightness":true,"dynOutput":"false","order":0,"width":"6","height":"1","passthru":true,"topic":"","x":780,"y":940,"wires":[["d875395.66a3bc8"]]},{"id":"a1b7c6c4.022f28","type":"function","z":"ec7c6746.2fe518","name":"report-rgb","func":"var attribute = \"rgb\";\nvar power = \"power\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0 &&\nmsg.payload.attributes.indexOf(power) < 0) {\n    return;\n}\n\nvar argb = msg.payload.newValues[attribute];\nreturn {\n    'payload': {\n        'a': (argb >>> 24),\n        'r': (argb >>  16) & 0xFF,\n        'g': (argb >>   8) & 0xFF,\n        'b': (argb)        & 0xFF\n    },\n    \"enabled\": msg.payload.newValues[power] == \"on\" ? true : false\n};","outputs":1,"noerr":0,"x":620,"y":940,"wires":[["8635397e.a2e6a8"]]},{"id":"d875395.66a3bc8","type":"function","z":"ec7c6746.2fe518","name":"set-rgb","func":"if(msg.socketid) {\n    var argb = msg.payload;\n    return {\n        \"payload\": {\n            \"cmd\": \"set\",\n            \"attribute\": \"rgb\",\n            \"value\": argb.r * 65536 + argb.g * 256 + argb.b\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":920,"y":940,"wires":[["5dff5943.ebe178"]]},{"id":"24b1fdf1.2270b2","type":"switch","z":"ec7c6746.2fe518","name":"switch cmd","property":"payload.cmd","propertyType":"msg","rules":[{"t":"eq","v":"report","vt":"str"},{"t":"eq","v":"list_response","vt":"str"},{"t":"eq","v":"get_response","vt":"str"},{"t":"eq","v":"set_response","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":5,"x":410,"y":900,"wires":[["b3f76830.389b08","bdf64493.85a798","a1b7c6c4.022f28"],[],[],[],[]]},{"id":"41c94704.a0ac18","type":"link in","z":"ec7c6746.2fe518","name":"input-书房书架灯带-set","links":["5dff5943.ebe178"],"x":65,"y":980,"wires":[["fea09c3e.87c1e"]]},{"id":"5dff5943.ebe178","type":"link out","z":"ec7c6746.2fe518","name":"output-书房书架灯带-set","links":["41c94704.a0ac18"],"x":1035,"y":890,"wires":[]},{"id":"5d4b1236.d0ce0c","type":"Mi-YeelightColorLedStrip-Device","z":"","deviceName":"书房书架灯带","deviceIP":"10.3.3.10","deviceToken":"247a3fc7b8c784ea7343e1f78868da7b","deviceSyncInterval":"3000"},{"id":"51432a30.c95924","type":"ui_group","z":"","name":"书架灯带","tab":"a9eaf9a9.529d58","order":2,"disp":true,"width":"6","collapse":true},{"id":"a9eaf9a9.529d58","type":"ui_tab","z":"","name":"书房","icon":"work","order":5}]
智米直流变频落地扇与Dashboard配合的例子
[{"id":"2deacc39.7c3574","type":"Mi-ZhiMiDCVariableFrequencyFan","z":"ec7c6746.2fe518","name":"智米直流变频落地扇","device":"631357c0.f44fe8","x":210,"y":2250,"wires":[["19f3bf5b.56f711"]]},{"id":"dd1ec1aa.697ee","type":"ui_switch","z":"ec7c6746.2fe518","name":"","label":"电源","group":"6eac6248.a6ddac","order":1,"width":"2","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"on","onvalueType":"str","onicon":"fa-power-off","oncolor":"yellow","offvalue":"off","offvalueType":"str","officon":"fa-power-off","offcolor":"black","x":920,"y":1640,"wires":[["6d93649b.fe723c"]]},{"id":"cae11a76.1c69d8","type":"function","z":"ec7c6746.2fe518","name":"report-power","func":"var attribute = \"power\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0) {\n    return;\n}\n\nreturn {\n    'payload': msg.payload.newValues[attribute]\n};","outputs":1,"noerr":0,"x":630,"y":1640,"wires":[["dd1ec1aa.697ee"]]},{"id":"6d93649b.fe723c","type":"function","z":"ec7c6746.2fe518","name":"set-power","func":"if(msg.socketid) {\n    return {\n        \"payload\": {\n            \"cmd\": \"set\",\n            \"attribute\": \"power\",\n            \"value\": msg.payload\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":1060,"y":1640,"wires":[["d7672c0e.d7477"]]},{"id":"56f8d8b2.0a5f08","type":"ui_text","z":"ec7c6746.2fe518","group":"6eac6248.a6ddac","order":9,"width":"3","height":"1","name":"温度","label":"温度","format":"{{msg.payload}} °C","layout":"row-spread","x":920,"y":2040,"wires":[]},{"id":"fecf41b2.bedbb","type":"ui_text","z":"ec7c6746.2fe518","group":"6eac6248.a6ddac","order":10,"width":"3","height":"1","name":"湿度","label":"湿度","format":"{{msg.payload}} %","layout":"row-spread","x":920,"y":2090,"wires":[]},{"id":"1a361fc0.bd788","type":"function","z":"ec7c6746.2fe518","name":"report-temp_dec","func":"var attribute = \"temp_dec\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0) {\n    return;\n}\n\nreturn {\n    'payload': msg.payload.newValues[attribute] / 10\n};","outputs":1,"noerr":0,"x":640,"y":2040,"wires":[["56f8d8b2.0a5f08"]]},{"id":"c3bbb01b.f1f73","type":"function","z":"ec7c6746.2fe518","name":"report-humidity","func":"var attribute = \"humidity\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0) {\n    return;\n}\n\nreturn {\n    'payload': msg.payload.newValues[attribute]\n};","outputs":1,"noerr":0,"x":640,"y":2090,"wires":[["fecf41b2.bedbb"]]},{"id":"c6c3b278.c414f","type":"ui_switch","z":"ec7c6746.2fe518","name":"","label":"蜂鸣器","group":"6eac6248.a6ddac","order":11,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"on","onvalueType":"str","onicon":"fa-bell-o","oncolor":"yellow","offvalue":"off","offvalueType":"str","officon":"fa-bell-slash-o","offcolor":"black","x":920,"y":2140,"wires":[["3c5769ca.d81096"]]},{"id":"1ad1f0f2.1a16cf","type":"function","z":"ec7c6746.2fe518","name":"report-buzzer","func":"var attribute = \"buzzer\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0) {\n    return;\n}\n\nreturn {\n    'payload': msg.payload.newValues[attribute]\n};","outputs":1,"noerr":0,"x":640,"y":2140,"wires":[["c6c3b278.c414f"]]},{"id":"3c5769ca.d81096","type":"function","z":"ec7c6746.2fe518","name":"set-buzzer","func":"if(msg.socketid) {\n    return {\n        \"payload\": {\n            \"cmd\": \"set\",\n            \"attribute\": \"buzzer\",\n            \"value\": msg.payload\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":1080,"y":2140,"wires":[["d7672c0e.d7477"]]},{"id":"58e764c4.45bb0c","type":"ui_switch","z":"ec7c6746.2fe518","name":"","label":"童锁","group":"6eac6248.a6ddac","order":12,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"on","onvalueType":"str","onicon":"fa-lock","oncolor":"yellow","offvalue":"off","offvalueType":"str","officon":"fa-unlock","offcolor":"black","x":920,"y":2190,"wires":[["276ccda0.fa95e2"]]},{"id":"b35afa04.d529c8","type":"function","z":"ec7c6746.2fe518","name":"report-child_lock","func":"var attribute = \"child_lock\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0) {\n    return;\n}\n\nreturn {\n    'payload': msg.payload.newValues[attribute]\n};","outputs":1,"noerr":0,"x":640,"y":2190,"wires":[["58e764c4.45bb0c"]]},{"id":"276ccda0.fa95e2","type":"function","z":"ec7c6746.2fe518","name":"set-child_lock","func":"if(msg.socketid) {\n    return {\n        \"payload\": {\n            \"cmd\": \"set\",\n            \"attribute\": \"child_lock\",\n            \"value\": msg.payload\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":1090,"y":2190,"wires":[["d7672c0e.d7477"]]},{"id":"d7001267.94c03","type":"function","z":"ec7c6746.2fe518","name":"*report-natural_level&speed_level-1","func":"var attribute1 = \"natural_level\";\nvar attribute2 = \"speed_level\";\nvar power = \"power\";\n\nif(msg.payload.attributes.indexOf(attribute1) < 0 &&\nmsg.payload.attributes.indexOf(attribute2) < 0 &&\nmsg.payload.attributes.indexOf(power) < 0) {\n    return;\n}\n\nflow.set(\"a_\" + attribute1, msg.payload.newValues[attribute1]);\nflow.set(\"a_\" + attribute2, msg.payload.newValues[attribute2]);\n\nvar result = \"\";\nif(msg.payload.newValues[attribute1] > 0) {\n    result = msg.payload.newValues[attribute1];\n} else {\n    result = msg.payload.newValues[attribute2];\n}\n\nreturn {\n    'payload': result,\n    'enabled': msg.payload.newValues[power] == \"on\" ? true : false\n};\n","outputs":1,"noerr":0,"x":700,"y":1740,"wires":[["fc0716d3.039d48"]]},{"id":"fc0716d3.039d48","type":"ui_slider","z":"ec7c6746.2fe518","name":"","label":"风速","group":"6eac6248.a6ddac","order":3,"width":"6","height":"1","passthru":true,"outs":"all","topic":"","min":"1","max":"100","step":1,"x":920,"y":1740,"wires":[["9e9c2120.81937"]]},{"id":"88e384e1.dd3998","type":"ui_numeric","z":"ec7c6746.2fe518","name":"","label":"LED指示灯亮度","group":"6eac6248.a6ddac","order":13,"width":"6","height":"1","passthru":true,"topic":"","format":"{{value}}","min":0,"max":"2","step":1,"x":950,"y":2240,"wires":[["72e97460.66403c"]]},{"id":"e62d9cce.4403a","type":"function","z":"ec7c6746.2fe518","name":"report-led_b","func":"var attribute = \"led_b\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0) {\n    return;\n}\n\nvar value = 2;\nswitch(msg.payload.newValues[attribute]) {\n    case 0:\n        value = 2;\n        break;\n    case 1:\n        value = 1;\n        break;\n    case 2:\n        value = 0;\n        break;\n    default:\n        break;\n}\nreturn {\n    'payload': value\n};","outputs":1,"noerr":0,"x":630,"y":2240,"wires":[["88e384e1.dd3998"]]},{"id":"72e97460.66403c","type":"function","z":"ec7c6746.2fe518","name":"set-led_b","func":"if(msg.socketid) {\n    var value = 2;\n    switch(msg.payload) {\n        case 0:\n            value = 2;\n            break;\n        case 1:\n            value = 1;\n            break;\n        case 2:\n            value = 0;\n            break;\n        default:\n            break;\n    }\n    \n    return {\n        \"payload\": {\n            \"cmd\": \"set\",\n            \"attribute\": \"led_b\",\n            \"value\": value\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":1120,"y":2240,"wires":[["d7672c0e.d7477"]]},{"id":"d5eec84b.77d558","type":"ui_text","z":"ec7c6746.2fe518","group":"6eac6248.a6ddac","order":2,"width":"4","height":"1","name":"电量","label":"","format":"{{msg.payload}}","layout":"row-right","x":920,"y":1690,"wires":[]},{"id":"72aaeb4f.0fdb94","type":"function","z":"ec7c6746.2fe518","name":"report-ac_power&battery","func":"var attribute1 = \"ac_power\";\nvar attribute2 = \"battery\";\n\nif(msg.payload.attributes.indexOf(attribute1) < 0 &&\nmsg.payload.attributes.indexOf(attribute2) < 0) {\n    return;\n}\n\nvar result = \"\";\nif(msg.payload.newValues[attribute1] == \"on\" && msg.payload.newValues[attribute2] == \"100\") {\n    result = \"电源供电\";\n} else if(msg.payload.newValues[attribute1] == \"off\") {\n    result = \"电池供电(电量\" + msg.payload.newValues[attribute2] + \"%)\";\n} else if(msg.payload.newValues[attribute1] == \"on\" && msg.payload.newValues[attribute2] != \"100\") {\n    result = \"充电中(电量\" + msg.payload.newValues[attribute2] + \"%)\";\n}\n\nreturn {\n    'payload': result\n};","outputs":1,"noerr":0,"x":670,"y":1690,"wires":[["d5eec84b.77d558"]]},{"id":"f990fb4d.2623e8","type":"function","z":"ec7c6746.2fe518","name":"report-angle_enable","func":"var attribute = \"angle_enable\";\nvar power = \"power\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0 &&\nmsg.payload.attributes.indexOf(power) < 0) {\n    return;\n}\n\nreturn {\n    'payload': msg.payload.newValues[attribute],\n    'enabled': msg.payload.newValues[power] == \"on\" ? true : false\n};","outputs":1,"noerr":0,"x":660,"y":1840,"wires":[["c38c2da9.a09d2"]]},{"id":"c38c2da9.a09d2","type":"ui_switch","z":"ec7c6746.2fe518","name":"","label":"摇头","group":"6eac6248.a6ddac","order":5,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","x":920,"y":1840,"wires":[["6dfe6fb9.a46b4"]]},{"id":"6dfe6fb9.a46b4","type":"function","z":"ec7c6746.2fe518","name":"set-angle_enable","func":"if(msg.socketid) {\n    return {\n        \"payload\": {\n            \"cmd\": \"set\",\n            \"attribute\": \"angle_enable\",\n            \"value\": msg.payload\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":1090,"y":1840,"wires":[["d7672c0e.d7477"]]},{"id":"d8a8a203.9d00b","type":"ui_button","z":"ec7c6746.2fe518","name":"左转","group":"6eac6248.a6ddac","order":6,"width":"3","height":"1","passthru":false,"label":"左转","color":"","bgcolor":"","icon":"fa-arrow-left","payload":"left","payloadType":"str","topic":"","x":920,"y":1890,"wires":[["aca4b565.99b0b8"]]},{"id":"ddd4be71.e4a81","type":"ui_button","z":"ec7c6746.2fe518","name":"","group":"6eac6248.a6ddac","order":7,"width":"3","height":"1","passthru":false,"label":"右转","color":"","bgcolor":"","icon":"fa-arrow-right","payload":"right","payloadType":"str","topic":"","x":920,"y":1930,"wires":[["aca4b565.99b0b8"]]},{"id":"51a1f10a.99562","type":"function","z":"ec7c6746.2fe518","name":"set-angle","func":"if(msg.socketid) {\n    return {\n        \"payload\": {\n            \"cmd\": \"set\",\n            \"attribute\": \"angle\",\n            \"value\": msg.payload\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":1090,"y":2010,"wires":[["d7672c0e.d7477"]]},{"id":"2a617ba6.784ec4","type":"ui_slider","z":"ec7c6746.2fe518","name":"","label":"摇头角度","group":"6eac6248.a6ddac","order":8,"width":"5","height":"1","passthru":true,"outs":"all","topic":"","min":"30","max":"118","step":1,"x":930,"y":1990,"wires":[["51a1f10a.99562","9021790c.dceb98"]]},{"id":"2a417260.eac1ae","type":"function","z":"ec7c6746.2fe518","name":"report-angle","func":"var power = \"power\";\nvar angle_enable = \"angle_enable\";\nvar attribute = \"angle\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0 &&\nmsg.payload.attributes.indexOf(power) < 0 &&\nmsg.payload.attributes.indexOf(angle_enable) < 0) {\n    return;\n}\n\nvar enable = false;\nif(msg.payload.newValues[power] == \"on\" &&\nmsg.payload.newValues[angle_enable] == \"on\") {\n    enable = true;\n}\n\nreturn {\n    \"enabled\": enable,\n    'payload': msg.payload.newValues[attribute]\n};","outputs":1,"noerr":0,"x":630,"y":1940,"wires":[["2a617ba6.784ec4","9021790c.dceb98"]]},{"id":"9021790c.dceb98","type":"ui_text","z":"ec7c6746.2fe518","group":"6eac6248.a6ddac","order":14,"width":"1","height":"1","name":"摇头角度显示","label":"","format":"{{msg.payload}}","layout":"row-center","x":1110,"y":1970,"wires":[]},{"id":"db4894fe.f75968","type":"ui_switch","z":"ec7c6746.2fe518","name":"自然风","label":"{{msg.label}}","group":"6eac6248.a6ddac","order":4,"width":"3","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-leaf","oncolor":"green","offvalue":"false","offvalueType":"bool","officon":"fa-bars","offcolor":"blue","x":920,"y":1790,"wires":[["839781ab.eb099"]]},{"id":"9d87aaa7.d71cd8","type":"function","z":"ec7c6746.2fe518","name":"report-natural_level&speed_level-2","func":"var attribute = \"natural_level\";\nvar power = \"power\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0 &&\nmsg.payload.attributes.indexOf(power) < 0) {\n    return;\n}\n\nif(msg.payload.newValues[attribute] > 0) {\n    return {\n        'payload': true,\n        'label': \"自然风\",\n        'enabled': msg.payload.newValues[power] == \"on\" ? true : false\n    };\n} else {\n    return {\n        'payload': false,\n        'label': \"直吹风\",\n        'enabled': msg.payload.newValues[power] == \"on\" ? true : false\n    };\n}","outputs":1,"noerr":0,"x":700,"y":1790,"wires":[["db4894fe.f75968"]]},{"id":"19f3bf5b.56f711","type":"switch","z":"ec7c6746.2fe518","name":"switch cmd","property":"payload.cmd","propertyType":"msg","rules":[{"t":"eq","v":"report","vt":"str"},{"t":"eq","v":"list_response","vt":"str"},{"t":"eq","v":"get_response","vt":"str"},{"t":"eq","v":"set_response","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":5,"x":400,"y":1920,"wires":[["cae11a76.1c69d8","72aaeb4f.0fdb94","f990fb4d.2623e8","2a417260.eac1ae","1a361fc0.bd788","c3bbb01b.f1f73","1ad1f0f2.1a16cf","b35afa04.d529c8","e62d9cce.4403a","b5c23bb6.a6ee58","9d87aaa7.d71cd8","d7001267.94c03"],[],[],[],[]]},{"id":"38c95806.988b68","type":"link in","z":"ec7c6746.2fe518","name":"input-智米直流变频落地扇-set","links":["d7672c0e.d7477"],"x":65,"y":2250,"wires":[["2deacc39.7c3574"]]},{"id":"d7672c0e.d7477","type":"link out","z":"ec7c6746.2fe518","name":"output-dashboard-智米直流变频落地扇-set","links":["38c95806.988b68"],"x":1285,"y":1890,"wires":[]},{"id":"b5c23bb6.a6ee58","type":"function","z":"ec7c6746.2fe518","name":"report-angle","func":"var power = \"power\";\nvar angle_enable = \"angle_enable\";\n\nif(msg.payload.attributes.indexOf(power) < 0 &&\nmsg.payload.attributes.indexOf(angle_enable) < 0) {\n    return;\n}\n\nvar enable = false;\nif(msg.payload.newValues[power] == \"on\" && \nmsg.payload.newValues[angle_enable] == \"off\") {\n    enable = true;\n}\n\nreturn {\n    \"enabled\": enable\n};","outputs":1,"noerr":0,"x":630,"y":1890,"wires":[["d8a8a203.9d00b","ddd4be71.e4a81"]]},{"id":"9e9c2120.81937","type":"function","z":"ec7c6746.2fe518","name":"*set-natural_level/speed_level-1","func":"if(msg.socketid) {\n    var natural_level = flow.get(\"a_\" + \"natural_level\");\n    var speed_level = flow.get(\"a_\" + \"speed_level\");\n    \n    if(natural_level > 0) {\n        return {\n            \"payload\": {\n                \"cmd\": \"set\",\n                \"attribute\": \"natural_level\",\n                \"value\": msg.payload\n            }\n        }\n    } else {\n        return {\n            \"payload\": {\n                \"cmd\": \"set\",\n                \"attribute\": \"speed_level\",\n                \"value\": msg.payload\n            }\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":1130,"y":1740,"wires":[["d7672c0e.d7477"]]},{"id":"839781ab.eb099","type":"function","z":"ec7c6746.2fe518","name":"set-natural_level/speed_level-2","func":"if(msg.socketid) {\n    var natural_level = flow.get(\"natural_level\");\n    var speed_level = flow.get(\"speed_level\");\n    \n    if(natural_level > 0) {\n        if(msg.payload) {\n            return;\n        } else {\n            return {\n                \"payload\": {\n                    \"cmd\": \"set\",\n                    \"attribute\": \"speed_level\",\n                    \"value\": natural_level\n                }\n            }\n        }\n    } else {\n        if(msg.payload) {\n            return {\n                \"payload\": {\n                    \"cmd\": \"set\",\n                    \"attribute\": \"natural_level\",\n                    \"value\": speed_level\n                }\n            };\n        } else {\n            return;\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":1130,"y":1790,"wires":[["d7672c0e.d7477"]]},{"id":"aca4b565.99b0b8","type":"function","z":"ec7c6746.2fe518","name":"set-move","func":"if(msg.socketid) {\n    return {\n        \"payload\": {\n            \"cmd\": \"miio\",\n            \"method\": \"set_move\",\n            \"value\": [msg.payload]\n        }\n    }\n}\n\nreturn;","outputs":1,"noerr":0,"x":1060,"y":1910,"wires":[["d7672c0e.d7477"]]},{"id":"631357c0.f44fe8","type":"Mi-ZhiMiDCVariableFrequencyFan-Device","z":"","deviceName":"智米直流变频落地扇","deviceIP":"10.3.6.1","deviceToken":"672fa1b99c6e712f1fd23d7350149cdf","deviceSyncInterval":"3000"},{"id":"6eac6248.a6ddac","type":"ui_group","z":"","name":"智米直流变频落地扇","tab":"e32679b8.928d88","order":3,"disp":true,"width":"6","collapse":true},{"id":"e32679b8.928d88","type":"ui_tab","z":"","name":"主卧","icon":"fa-bed","order":3}]
与HomeKit配合的例子
Yeelight灯带与HomeKit配合的例子
[{"id":"3f2db9c4.3cc936","type":"Mi-YeelightColorLedStrip","z":"a676629d.b9206","name":"书房书架灯带","device":"5d4b1236.d0ce0c","x":280,"y":700,"wires":[["5d165910.a18ac8"]]},{"id":"b894e8f3.5c9dd8","type":"function","z":"a676629d.b9206","name":"格式转换-power","func":"var attribute = \"power\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0) {\n    return;\n}\n\nreturn {\n    'payload': {\n        'On': msg.payload.newValues[attribute] == \"on\" ? true : false,\n        \"Context\": {\n            \"isReport\": true\n        }\n    }\n};","outputs":1,"noerr":0,"x":660,"y":600,"wires":[["be16396.521f8c8"]]},{"id":"2f32503c.a2d28","type":"function","z":"a676629d.b9206","name":"set-power","func":"if(msg.hap.context && msg.hap.context.isReport) {\n    return;\n}\n\nif(null === msg.payload[\"On\"] || undefined === msg.payload[\"On\"]) {\n    return;\n}\n\nvar attribute = \"power\";\nreturn {\n    \"payload\": {\n        \"cmd\": \"set\",\n        \"attribute\": attribute,\n        \"value\": msg.payload['On'] ? \"on\" : \"off\"\n    }\n}","outputs":1,"noerr":0,"x":1040,"y":600,"wires":[["66e9b34d.ab2e8c"]]},{"id":"49c64df3.309c74","type":"function","z":"a676629d.b9206","name":"格式转换-bright","func":"var attribute = \"bright\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0) {\n    return;\n}\n\nreturn {\n    'payload': {\n        'Brightness': msg.payload.newValues[attribute],\n        \"Context\": {\n            \"isReport\": true\n        }\n    }\n};","outputs":1,"noerr":0,"x":660,"y":640,"wires":[["be16396.521f8c8"]]},{"id":"943f6d45.a46a3","type":"function","z":"a676629d.b9206","name":"格式转换-rgb","func":"var attribute = \"rgb\";\n\nif(msg.payload.attributes.indexOf(attribute) < 0) {\n    return;\n}\n\nvar hue = msg.payload.newValues[\"hue\"];\nvar sat = msg.payload.newValues[\"sat\"];\nreturn {\n    'payload': {\n        \"Hue\": hue,\n        \"Saturation\": sat,\n        \"Context\": {\n            \"isReport\": true\n        }\n    }\n};\n","outputs":1,"noerr":0,"x":650,"y":680,"wires":[["be16396.521f8c8"]]},{"id":"5d165910.a18ac8","type":"switch","z":"a676629d.b9206","name":"switch cmd","property":"payload.cmd","propertyType":"msg","rules":[{"t":"eq","v":"report","vt":"str"},{"t":"eq","v":"list_response","vt":"str"},{"t":"eq","v":"get_response","vt":"str"},{"t":"eq","v":"set_response","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":5,"x":470,"y":660,"wires":[["b894e8f3.5c9dd8","49c64df3.309c74","943f6d45.a46a3"],[],[],[],[]]},{"id":"be16396.521f8c8","type":"homekit-service","z":"a676629d.b9206","bridge":"9c1342f5.47d6b","name":"书房书架灯带","serviceName":"Lightbulb","manufacturer":"Yeelight","model":"Color LED Strip","serialNo":"7C:49:EB:B6:76:2B","characteristicProperties":"{}","x":860,"y":640,"wires":[["2f32503c.a2d28","91af0554.81d8f8","1380e9.6e000f18"]]},{"id":"91af0554.81d8f8","type":"function","z":"a676629d.b9206","name":"set-bright","func":"if(msg.hap.context && msg.hap.context.isReport) {\n    return;\n}\n\nif(null === msg.payload[\"Brightness\"] || undefined === msg.payload[\"Brightness\"]) {\n    return;\n}\n\nvar attribute = \"bright\";\nreturn {\n    \"payload\": {\n        \"cmd\": \"set\",\n        \"attribute\": attribute,\n        \"value\": msg.payload['Brightness']\n    }\n}","outputs":1,"noerr":0,"x":1040,"y":640,"wires":[["66e9b34d.ab2e8c"]]},{"id":"1380e9.6e000f18","type":"function","z":"a676629d.b9206","name":"set-rgb","func":"var hue = msg.payload[\"Hue\"];\nvar sat = msg.payload[\"Saturation\"];\n\nif(hue) {\n    context.set(\"hue\", hue);\n}\nif(sat) {\n    context.set(\"sat\", sat);\n}\n\nif(msg.hap.context && msg.hap.context.isReport) {\n    return;\n}\n\nif(\n(null === hue || undefined === hue) &&\n(null === sat || undefined === sat)\n) {\n    return;\n}\n\n/* accepts parameters\n * h  Object = {h:x, s:y, v:z}\n * OR \n * h, s, v\n*/\nfunction HSVtoRGB(h, s, v) {\n    var r, g, b, i, f, p, q, t;\n    if (arguments.length === 1) {\n        s = h.s, v = h.v, h = h.h;\n    }\n    i = Math.floor(h * 6);\n    f = h * 6 - i;\n    p = v * (1 - s);\n    q = v * (1 - f * s);\n    t = v * (1 - (1 - f) * s);\n    switch (i % 6) {\n        case 0: r = v, g = t, b = p; break;\n        case 1: r = q, g = v, b = p; break;\n        case 2: r = p, g = v, b = t; break;\n        case 3: r = p, g = q, b = v; break;\n        case 4: r = t, g = p, b = v; break;\n        case 5: r = v, g = p, b = q; break;\n    }\n    return {\n        r: Math.round(r * 255),\n        g: Math.round(g * 255),\n        b: Math.round(b * 255)\n    };\n}\n\nvar rgb = HSVtoRGB(\n    parseFloat(context.get(\"hue\")/360), \n    parseFloat(context.get(\"sat\")/100), \n    parseFloat(1)\n);\nreturn {\n    \"payload\": {\n        \"cmd\": \"set\",\n        \"attribute\": \"rgb\",\n        \"value\": rgb.r * 65536 + rgb.g * 256 + rgb.b\n    }\n}","outputs":1,"noerr":0,"x":1040,"y":680,"wires":[["66e9b34d.ab2e8c"]]},{"id":"81c197f0.94ca38","type":"link in","z":"a676629d.b9206","name":"input-homekit-书房书架灯带-set","links":["66e9b34d.ab2e8c"],"x":155,"y":700,"wires":[["3f2db9c4.3cc936"]]},{"id":"66e9b34d.ab2e8c","type":"link out","z":"a676629d.b9206","name":"output-homekit-书房书架灯带-set","links":["81c197f0.94ca38"],"x":1155,"y":640,"wires":[]},{"id":"5d4b1236.d0ce0c","type":"Mi-YeelightColorLedStrip-Device","z":"","deviceName":"书房书架灯带","deviceIP":"10.3.3.10","deviceToken":"247a3fc7b8c784ea7343e1f78868da7b","deviceSyncInterval":"3000"},{"id":"9c1342f5.47d6b","type":"homekit-bridge","z":"","bridgeName":"NR-Yeelight","pinCode":"100-01-002","port":"63002","manufacturer":"Default Manufacturer","model":"Default Model","serialNo":"Default Serial Number"}]
版本说明
0.0.4 (2018-11-27)
  1. 修复了set设备值,有些node结点收不到report消息的bug。
0.0.3 (2018-11-15)
  1. 修复了设备同步时间为0的时候的一些bug。
  2. 增加了一种自定义设备的模式。因为miio的设备比较多,插件会一点点增加支持的设备,这需要一个时间过程,所以做了一种自定义的方式,可以自己给设备定义属性,在插件没有支持某些设备之前可以先采用这种方式使用。
0.0.2 (2018-11-15)
  1. 增加支持智米直流变频落地扇。
  2. 因为某些情况下需要多个属性同时计算,不得不修改report的格式规则。
0.0.1 (2018-11-13)
  1. 增加支持米家智能插线板。
  2. 增加支持Yeelight彩光灯带。
Version: 0.0.4
Updated 8 years, 5 months ago
10 in the last week
  • Mi-MiIntelligencePinboard-Device
  • Mi-YeelightColorLedStrip-Device
  • Mi-ZhiMiDCVariableFrequencyFan-Device
  • Mi-Other-Device
  • Mi-Other
  • Node-RED
  • node-red-contrib
  • xiaomi
  • mi
  • miio
