node-red-contrib-mgrs 1.1.5
A Node-RED node to convert co-ordinates to and from mgrs
npm install node-red-contrib-mgrs
A Node-RED node to convert co-ordinates in Latitude and Longitude to and from MGRS format.
Either use the Node-RED menu - manage palette - install option, or run the following command in your Node-RED user directory - typically ~/.node-red
npm i node-red-contrib-mgrs
If the selected msg property contains .lat and .lon properties, this node adds a corresponding MGRS location as .mgrs.
If the object contains a .mgrs property as below, and not .lat and .lon they will be created.
msg.payload.mgrs - string - e.g. 30U XB 15652 56680
The MGRS may contain less precision if required, e.g. 30U XB 1 5
Version: 1.1.5
Updated 1 year ago
4 in the last week
  • mgrs
  • map
  • world
  • mgrs
