node-red-contrib-mfrc522-rfid 1.0.0
Simple Node-RED node for the Raspberry Pi to read NFC tags via a RC522 NFC reader. It can return the UID and optionaly a data block. Chip Select (SDA) pin is also configurable (defaults to CE0, 24).
npm install node-red-contrib-mfrc522-rfid
node-red-contrib-rc522-extra
A [Node-Red][1] node that allows you to read NFC tags with an RC522 card reader. Tested the node on a Raspberry Pi.
This is a fork of: https://github.com/LennartHennigs/node-red-contrib-rc522
I needed to be able to configure the Chip Select (SDA) pin and to read a block of data, so I have added these options ;)
You need to connect to RC522 card reader to the following pins:
SDA(CS)	24 (BCM 8) (default, can be configured)
SCK	23 (BCM 11)
MOSI	19 (BCM 10)
MISO	21 (BCM 9)
IRQ	-
GND	20
RST	22 (BCM 25)
VCC	17 (3v3 PWR)
See [pinout.xyz][2] to identify the proper pins.
The node ist based on the [mfrc522-rpi][3] node package.
[1]: https://nodered.org [2]: https://pinout.xyz/ [3]: https://github.com/firsttris/mfrc522-rpi
Version: 1.0.0
Updated 6 years, 4 months ago
Rating: 0.0
13 in the last week
  • rc522-extra
  • rc522
  • nfc
