node-red-contrib-mewtocol 0.0.12
Panasonic PLC MEWTOCOL COM over TCP implementation for Node-Red
npm install node-red-contrib-mewtocol
Panasonic MEWTOCOL COM protocol implementation for Node-Red
Please use official MEWTOCOL manual as a reference: MEWTOCOL.pdf
At the moment only few read nodes are implemented:
  • RD - Read Registers as 16bit values
  • RCS - Read single Contact binary value
  • RCC - Read Contact values as 16bit integers
  • RT - Read PLC status
  • RR - Read System Register values as 16bit integers
  • RS - Read Timer Set values as 16bit integers
  • RK - Read Timer Elapsed values as 16bit integers
... more are coming ...
Run the following command for global install:
npm install -g node-red-contrib-mewtocol
Version: 0.0.12
Updated 4 years, 3 months ago
License: MIT-feh
6 in the last week
  • mewtocol-client
  • mewtocol-rd
  • mewtocol-rcc
  • mewtocol-rcs
  • mewtocol-rt
  • mewtocol-rr
  • mewtocol-rs
  • mewtocol-rk
  • plusfornodered
  • mewtocol
  • panasonic
  • plc
  • automation
