node-red-contrib-metabase-embed 1.0.5
Embed Metabase dashboards into Node-Red UI
npm install node-red-contrib-metabase-embed
A simple node to embed Metabase Dashboards and Queries for the Node-RED Dashboard
These nodes uses jsonwebtoken.
install
To install the node run the following from your Node-RED user directory (~/.node-red):
or
Or install the node from the Palette section of your Node-RED editor by searching by name (node-red-contrib-metabase-embed).
configuration
images
  • Name === Node Name - Default Metabase
  • URL === Web address of Metabase - Default http://localhost:3000
  • Token === Token created by Metabase - Default xxxx
  • Expire === Minuites before link expires - Default 100
  • Theme === Theme mode - Default Light mode
  • Title === Show title - Default false
  • Border === Show border - Default false
Setup Metabase for embedded applications
images
Exsample flow
images
[{"id":"19029a14.b18e5e","type":"template","z":"8d02a363.e02f2","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<iframe\n src=\"{{iframeUrl}}\"\n frameborder=\"0\"\n width=\"1560\"\n height=\"1600\"\n allowtransparency\n></iframe>","x":740,"y":1340,"wires":[["fc355a63.865528"]]},{"id":"fc355a63.865528","type":"ui_template","z":"8d02a363.e02f2","group":"997d0400.2287f8","name":"metabase","order":1,"width":30,"height":30,"format":"<div ng-bind-html=\"msg.payload | trusted\"></div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":960,"y":1340,"wires":[[]]},{"id":"30c6b1f7.49e09e","type":"inject","z":"8d02a363.e02f2","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":310,"y":1340,"wires":[["1f5f37a6.4fddf"]]},{"id":"a045de10.dd5228","type":"debug","z":"8d02a363.e02f2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":530,"y":1300,"wires":[]},{"id":"1f5f37a6.4fddf","type":"mb","z":"8d02a363.e02f2","name":"","url":"http://localhost:3000","token":"32147d2dc0ec7f44bd8bcddd9110d2d50e3f32987fe9dce1405d631af711659a","expire":"10","theme":"theme=night&","title":true,"border":false,"x":520,"y":1340,"wires":[["a045de10.dd5228","19029a14.b18e5e"]]},{"id":"997d0400.2287f8","type":"ui_group","name":"Trend Integer","tab":"e55e7242.05ce4","order":3,"disp":true,"width":"30","collapse":true},{"id":"e55e7242.05ce4","type":"ui_tab","name":"Trends","icon":"fa-line-chart","order":2,"disabled":false,"hidden":false}]
Version: 1.0.5
22 in the last week
  • mb
  • metabase
  • jsonwebtoken
  • ui
