node-red-contrib-met-eireann 0.1.3
A Node-RED node that gets the weather report from met.ie
npm install node-red-contrib-met-eireann
A met-eireann node for Node-RED.
Run npm install from your Node-RED user data directory (e.g. ~/.node-red):
$ npm install node-red-contrib-met-eireann
The msg.payload contents are:
name unit description
temperature Celsius Air temperature 2m above the ground
windDirection Cardinal direction Direction of the wind (e.g. S or NW)
windDirectionDeg Degrees Direction of the wind (e.g. 187.7)
windSpeed Meters per second Wind speed
windSpeedBeaufort Beaufort scale Wind speed
globalRadiation Watt per square meter (W/m^2) Solar irradiance
humidity Percentage Relative humidity
pressure hPa Pressure
cloudiness Percentage General level of cloudiness
lowClouds Percentage Low cloud cover
mediumClouds Percentage Medium cloud cover
highClouds Percentage High cloud cover
dewPoint Celsius Dewpoint temperature
rain Millimeters Rainfall accumulation
rainProbability Percentage? Probability of rainfall
The API is part of Ireland's Open Data Portal.
Version: 0.1.3
2 in the last week
  • met-ie
  • weather
  • ireland
