node-red-contrib-message-sequencer 1.0.1
Record and play nodes for Node-RED message sequences.
npm install node-red-contrib-message-sequencer
Description
"Message Sequencer" nodes allows you to record and replay message sequences within Node-RED. For each message a delay is specified, which is the time relative to the start of the sequence.
This module is based on node-red-contrib-sequencer but with a completely different approach on how delays are handled. (https://github.com/tedstriker/node-red-contrib-sequencer)
Install via NPM
From inside your node-red directory:
How to?
The module comes with the following nodes:
  1. Sequence Recorder : with this node you can record sequences of messages, returns a sequence object which then can be replayed by the player node.
  2. Sequence Player : this node takes a sequence object and send messages at the intervals specified in the sequence. With this node you can easily replay and send messages previously recorded with the Sequence Recorder node.
The player can replay multiple sequences in parallel.
The sequence recorder returns a sequence object in the following format:
  "name": "Example",
  "sequence": [
      "data": {
        "topic": "Topic_1",
        "payload": "A"
      "delay": 0
      "data": {
        "topic": "Topic_2",
        "payload": "B"
      "delay": 1000
      "data": {
        "topic": "Topic_1",
        "payload": "C"
      "delay": 2000
  • name the name of the sequence. Use this name to specify the sequence to play or stop in Sequence Player.
  • sequence the array of objects and the delay.
  • data this object will be output as a new message when being replayed.
  • delay the time in milliseconds since the sequence started.
Recorder
For Recorder node, the following commands are available:
  • msg.start records a new sequence
  • msg.stop stops current recording and return already recorded sequence
When recording is stopped, the recorded sequence will be returned as a single message. The payload contains the sequence object.
Player
A player node is able to run multiple sequences in parallel. These are identified by the sequence name. Following commands are available:
  • msg.name The name of the sequence to be played or stopped.
  • msg.sequence load sequences into player (format: JSON or sequence object)
  • msg.play plays a sequence. Property value = sequence name
  • msg.stop stops the currently played sequence
  • msg.remove removes a sequence from the player
  • msg.enumerate returns an array with all names of currently loaded sequences
play, stop and remove properties take either a string or an array containing the name(s). If the value is an empty string it is assumed, that all loaded sequences shall be played, stopped or removed.
Version: 1.0.1
Updated 9 years, 3 months ago
Rating: 1.0 1
13 in the last week
  • sequencer-player
  • sequencer-recorder
  • sequencer
  • automation
