node-red-contrib-message-queues 1.0.4
## Overview This Node-RED custom node provides a message queue. It allows users to add messages to a queue and process them one at a time.
npm install node-red-contrib-message-queues
Node-RED Custom Node: Message Queue
Overview
  • Message Queue Management: Add and consume messages with a structured queue.
  • Simple API: Easily interact with the queue using predefined message types.
  1. Clone the repository or download the source code.
  2. Navigate to your Node-RED user directory (usually ~/.node-red).
  3. Run the following command to install the node:
  4. Restart Node-RED.
Input Messages
The node processes input messages with the following structure:
  • Add a Message to the Queue:
      "type": "add",
      "payload": "message ID"
    • type: Indicates the operation to perform (add).
    • payload: The unique ID of the message to add to the queue.
  • Consume the Current Message:
      "type": "consume",
    • type: Indicates the operation to perform (consume).
    • payload: The unique ID of the message currently being processed. Only the active message can be consumed.
Node Configuration
  1. Drag and drop the custom node into your Node-RED flow.
  2. Configure any optional settings in the node properties.
  3. Connect the node to other nodes for input and output processing.
Example Workflow
  1. Add Messages: Send multiple add messages to populate the queue.
  2. Process Messages: Use the consume message to process the current message. Upon successful processing, the next message in the queue will be activated.
Example Screenshot
Example Workflow
Output
  • Outputs the current message being processed.
  • Emits errors or status updates in case of invalid operations.
Version: 1.0.4
Updated 1 year, 11 months ago
License: AGPL-3.0
Rating: 2.0 1
4 in the last week
  • Message Queues
  • Message Resend
