node-red-contrib-mentor-capturer 2.0.0
Toolkit for Node-RED: Modbus, production reporting, random generation, and device reporting nodes
npm install node-red-contrib-mentor-capturer
A set of custom Node-RED nodes: Modbus read/write, production reporting, pulse counting, and data simulation.
Included nodes
Node Description
device-reporter Reports IoT device statistics at configurable intervals (seconds/minutes/hours)
modbus-variable Reads Modbus variables with built-in alarms
modbus-registers-to-number Converts raw Modbus registers into numeric values
number-to-modbus-registers Converts numeric values into Modbus registers
module-production Pulse counting for industrial production
production-reporter Generates periodic production reports
random-generator Random value generator for testing and simulation
alarm-generator Turns one threshold of one variable into an alarm, with hysteresis, release margin, severity and its own alarm_uuid
alarm-publisher Publishes every alarm change at once as an alarm-event/v1 message for a standard mqtt out node
From the Node-RED Palette Manager (Menu → Manage palette → Install), search for node-red-contrib-mentor-capturer.
Or via terminal:
Dependencies
  • modbus-serial — used by the Modbus communication nodes.
  • node-red-contrib-modbus — provides the "Modbus Client" config node required by the modbus-variable node.
    ⚠️ Intentionally pinned to version 5.45.2, since later versions (5.46+) require Node.js >= 22. If your environment already runs Node.js 22 or later, you can manually install a newer version of node-red-contrib-modbus without issues.
Requirements
  • Node-RED >= 2.0.0
  • Node.js >= 14
Languages
Every node is available in English (en-US, the base) and Spanish (es-ES) through the standard Node-RED locales/ mechanism: labels, statuses, editor notices and help. Data is never translated: alarm names, threshold names and the fields and values of the messages (catalog, severity, ...) are the same in every language.
Alarms (Mentor patch)
  • Every alarm message carries catalog (module-production, modbus-variable or alarm-generator) and alarm_uuid (a uuid v4 for alarm-generator; reserved uuids 00000000-0000-0000-<catalog>-<n> for the nine known alarms) instead of the numeric alarm_id. The reporters group alarms by (device_uuid, catalog, alarm_uuid).
  • alarm-generator watches one threshold of one variable chosen in the editor from the node wired to its input, with activation and release delays (5 s / 10 s by default), a release margin, severity and the real instant of the change.
  • alarm-publisher sends the alarm to mentor_alarms/<device_uuid> (QoS 1, not retained) through a standard mqtt out.
  • modbus-variable opens its communication alarm after N failed cycles in a row (3 by default).
  • module-production has a configurable sample interval (1 to 60 s, a divisor of 60, 1 s by default).
Recent changes (1.1.0)
  • Added the alarm-generator node: raises state: 1/0 alarms by matching a configured name against the thresholds[] emitted by module-production or modbus-variable, supporting gt, gte, lt, lte, eq, neq, and between conditions.
  • device-reporter and production-reporter now also emit sum_squares (Σx²) alongside standard_deviation in each variable's summary and in every threshold range — this makes exact re-aggregation of standard deviation across larger time windows (e.g. minute → hour → day) possible, since averaging standard deviations directly is not mathematically valid.
  • production-reporter now rounds sum, average, max, min, standard_deviation, and sum_squares to 2 decimal places, matching the precision already used by device-reporter.
MIT © Mentor Monitor
Version: 2.0.0
Updated 2 weeks, 5 days ago
11 in the last week
  • device-reporter
  • modbus-variable
  • modbus-registers-to-number
  • number-to-modbus-registers
  • module-production
  • random-generator
  • alarm-generator
  • alarm-publisher
  • mentor
  • mentor-monitor
  • modbus
  • production
  • report
  • random
  • iot
  • historian
  • counter
  • device
  • alarm
